文档中心 > GR551x Datasheet/ Pinout/ GR5513BENDU QFN40 Copy URL
GR5513BENDU QFN40
Figure 6 shows the pinout of GR5513BENDU QFN40 package (top view).
Figure 6 GR5513BENDU QFN40 package pinout
Table 6 shows pin descriptions of GR5513BENDU QFN40 package.
Table 6 GR5513BENDU QFN40 pin descriptions
Pin # Pin Name Pin Type Description/Default Function Voltage Domain
1 VDD_VCO/VDD_RF Analog/RF supply
Synthesizer VCO supply/RF supply: 1.1 V; connect to VREG.
2 TRX Analog/RF RX input and TX output
3 VBATT_RF Analog/RF Connect to VBATL.
4 GPIO_0 Digital I/O General purpose I/O; default: SWD_CLK; pad drive level is 2 mA. VDDIO1
5 GPIO_1 Digital I/O General purpose I/O; default: SWD_IO; pad drive level is 2 mA. VDDIO1
6 GPIO_2 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
7 GPIO_3 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
8 GPIO_4 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
9 GPIO_5 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
10 GPIO_6 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
11 GPIO_7 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
12 VDDIO_1 Digital I/O Supply I/O supply voltage. Support external 1.8 V–3.3 V input voltage. VDDIO1
13 GPIO_10 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
14 CHIP_EN Mixed Signal IN
Master Enable for chip reset pin.
The high value of CHIP_EN equals VBATL.
15 VIO_LDO_OUT Analog/PMU Output of on-chip I/O supply regulator.
For GR5513BENDU, power input pin of VDDIO0 digital IO domain. When VDDIO0 is set to 3.3 V/VBATL, VIO_LDO_OUT should be connected to 3.3 V/VBATL.
Connected internally to VDDIO0
16 VDD_DIGCORE_1V Analog/PMU On-chip LDO output for digital core. Connect to a 1 µF capacitor.
17 VREG Analog/PMU Feedback pin from switching regulator
18 VSW Analog/PMU DC/DC converter switching node
19 VSS_BUCK Analog/PMU DC/DC converter supply and general battery GND
20 VBATL Analog/PMU Power supply: 2.2 V to 3.8 V
21 RTC_IN Analog/PMU Input of inverting amplifier connected to 32.768 kHz crystal
22 RTC_OUT Analog/PMU Output of inverting amplifier connected to 32.768 kHz crystal
23 MSIO1 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
24 MSIO0 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
25 TEST_MODE Digital I/O Factory test mode selection pin
  • 1: test mode
  • 0: normal operation mode.
VDDIO0
26 AON_GPIO_0 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
27 AON_GPIO_1 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
28 AON_GPIO_2 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
29 AON_GPIO_3 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
30 GPIO_24 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
31 GPIO_25 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
32 GPIO_16 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
33 GPIO_17 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
34 GPIO_31 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
35 GPIO_30 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
36 GPIO_26 Digital I/O General purpose I/O VDDIO0
37 VDD_AMS Analog/RF AMS supply 1.1 V; connect to VREG.
38 XO_OUT Analog/RF Output of inverting amplifier connected to 32 MHz crystal
39 XO_IN Analog/RF Input of inverting amplifier connected to 32 MHz crystal
40 TPP Analog/RF Test Mux + output
