文档中心 > GR551x Datasheet/ Pinout/ GR5515RGBD BGA68 Copy URL
GR5515RGBD BGA68
Figure 4 shows the pin assignments of GR5515RGBD BGA68 package (top view).
Figure 4 GR5515RGBD BGA68 package pinout
Table 4 shows pin descriptions of GR5515RGBD BGA68 package.
Table 4 GR5515RGBD BGA68 package pin descriptions
Pin # Pin Name Pin Type Description/Default Function Voltage Domain
A1 VDD_VCO Analog/RF supply Synthesizer VCO supply: 1.1 V; connect to VREG
A2 TPP Analog/RF Test Mux +output
A3 XO_IN Analog/RF Input of inverting amplifier connected to 32 MHz crystal
A4 XO_OUT Analog/RF Output of inverting amplifier connected to 32 MHz crystal
A5 VDD_AMS Analog/RF AMS supply 1.1 V; connect to VREG
A6 GPIO28 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A7 GPIO27 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A8 GPIO26 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A9 GPIO30 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A10 GPIO17 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
B1 VDD_RF Analog/RF RF supply: 1.1 V; connect to VREG
B2 TPN Analog/RF Test Mux - output
B9 GPIO13 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
B10 GPIO24 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
C1 RF_GND Analog/RF RF ground
C3 RF_GND Analog/RF RF ground
C4 GPIO0 Digital I/O General purpose I/O; default: SWD_CLK; pad drive level is 2 mA. VDDIO1
C5 GPIO29 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
C6 GPIO31 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
C7 GPIO25 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
C8 GPIO16 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
C10 GPIO14 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
D1 TRX Analog/RF RX input and TX output
D3 RF_GND Analog/RF RF ground
D8 NC - -
D9 AON_GPIO6 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
D10 GPIO15 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
E1 VBATT_RF Analog/RF Connect to VBATL
E3 GPIO1 Digital I/O General purpose I/O; default: SWD_IO; pad drive level is 2 mA. VDDIO1
E5 DGND Digital GND Digital Ground
E6 DGND Digital GND Digital Ground
E8 AON_GPIO1 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
E9 AON_GPIO7 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
E10 GPIO9 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F1 GPIO4 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F3 GPIO2 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F5 VDDIO_1 Digital Supply
I/O supply voltage. Support external 1.8 V–3.3 V input voltage.
VDDIO1
F6 TEST_MODE Digital I/O Factory test mode selection pin
  • 1: test mode
  • 0: normal operation mode
VDDIO0
F8 AON_GPIO0 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
F9 GPIO8 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F10 GPIO12 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G1 GPIO5 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G3 GPIO6 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G8 MSIO4 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
G10 AON_GPIO5 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
H1 VDD_CORE Digital Supply Digital core supply
H3 GPIO11 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
H4 CHIP_EN Mixed Signal IN
Master Enable for chip reset pin.
The high value of CHIP_EN equals VBATL.
H5 VBATH_LDO_WBE Analog/PMU Connect to GND.
H6 PMUGND Analog/PMU DC-DC converter supply & general battery GND
H7 MSIO3 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
H8 MSIO2 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
H10 AON_GPIO4 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
J1 GPIO7 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
J2 GPIO10 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
J4 VIO_LDO_OUT Analog/PMU Output of On-Chip I/O supply regulator. Connected internally to VDDIO0
J9 MSIO0 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
J10 AON_GPIO3 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
K1 GPIO3 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
K2 VDD_DIGCORE_1V Analog/PMU On-chip LDO output for digital core, connected to 1 µF capacitor
K3 VREG Analog/PMU Feedback pin of switch regulator
K4 VBATH Analog/PMU Connect to VBATL
K5 VSW Analog/PMU DC-DC Converter Switching Node
K6 VBATL Analog/PMU Power supply: 2.2 V to 3.8 V
K7 MSIO1 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
K8 RTC_IN Analog/PMU Input of inverting amplifier connected to 32.768 kHz crystal
K9 RTC_OUT Analog/PMU Output of inverting amplifier connected to 32.768 kHz crystal
K10 AON_GPIO2 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
