文档中心 > GR551x Datasheet/ Pinout/ GR5515GGBD BGA55 Copy URL
GR5515GGBD BGA55
Figure 5 shows the pin assignments of GR5515GGBD BGA55 package (top view).
Figure 5 GR5515GGBD BGA55 package pinout
Table 5 shows pin descriptions of GR5515GGBD BGA55 package.
Table 5 GR5515GGBD BGA55 package pin descriptions
Pin # Pin Name Pin Type Description/Default Function Voltage Domain
A1 VDD_RF Analog/RF supply RF supply: 1.1 V
A2 VDD_VCO Analog/RF supply Synthesizer VCO supply; connect to VREG
A3 XO_IN Analog/RF Input of inverting amplifier connected to 32 MHz crystal
A4 XO_OUT Analog/RF Output of inverting amplifier connected to 32 MHz crystal
A5 VDD_AMS Analog/RF supply AMS supply 1.1 V; connect to VREG
A6 GPIO30 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A7 GPIO25 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
A8 GPIO26 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
B1 RF_GND0 Analog/RF RF ground
B2 RF_GND1 Analog/RF RF ground
B3 TPP Analog/RF Test Mux + output
B4 GPIO0 Digital I/O General purpose I/O; default: SWD_CLK; pad drive level is 2 mA. VDDIO1
B5 GPIO1 Digital I/O General purpose I/O; default: SWD_IO; pad drive level is 2 mA. VDDIO1
B6 GPIO17 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
B7 GPIO24 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
B8 NC - -
C1 TRX Analog/RF RX input and TX output
C2 RF_GND2 Analog/RF RF ground
C3 DGND0 Digital GND Digital ground
C4 DGND1 Digital GND Digital ground
C6 AON_GPIO7 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
C7 AON_GPIO2 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
C8 AON_GPIO5 Digital I/O Always-on general purpose I/O VDDIO0
D1 VBATT_RF Analog/RF supply Connect to VBATL
D2 GPIO3 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
D7 MSIO1 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
D8 AON_GPIO0 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
E1 GPIO2 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
E2 GPIO4 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
E7 MSIO2 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
E8 MSIO0 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
F1 GPIO5 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F2 GPIO6 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
F3 DGND2 Digital GND Digital ground
F4 TEST_MODE Digital I/O Factory test mode selection pin
  • 1: test mode
  • 0: in normal operation mode.
VDDIO0
F5 AON_GPIO4 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
F6 CHIP_EN Mixed Signal IN
Master Enable for chip reset pin.
The high value of CHIP_EN equals VBATL.
F7 MSIO3 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
F8 RTC_OUT Analog/PMU Output of inverting amplifier connected to 32.768 kHz crystal
G1 GPIO8 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G2 GPIO7 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G3 GPIO11 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
G4 GPIO16 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO0
G5 VIO_LDO_OUT Analog/PMU Output of On-Chip I/O supply regulator Connected internally to VDDIO0
G6 VDD_DIGCORE_1V Analog/PMU On-chip LDO output for digital core, connected to 1 µF capacitor
G7 MSIO4 Mixed Signal I/O Configurable to be a GPIO mixed signal (SNSADC interface); pad drive level is 2 mA. VBATL
G8 RTC_IN Analog/PMU Input of inverting amplifier connected to 32.768 kHz crystal
H1 GPIO9 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
H2 GPIO10 Digital I/O General purpose I/O; pad drive level is 2 mA. VDDIO1
H3 VDDIO_1 Digital I/O supply I/O supply voltage. Support external 1.8 V–3.3 V input voltage. VDDIO1
H4 AON_GPIO1 Digital I/O Always-on GPIO; pad drive level is 2 mA. VDDIO0
H5 VBATL Analog/PMU Power supply: 2.2 V to 3.8 V
H6 VREG Analog/PMU Feedback pin of switch regulator
H7 VSW Analog/PMU DC-DC converter switching node
H8 PMUGND Analog/PMU DC-DC converter & general battery GND pin
