Add User Code
You can modify corresponding code in the ble_app_example on demand.
Modify the main() Function
Code of a typical main.c file is provided as follows:
/**@brief Stack global variables for Bluetooth protocol stack. */
STACK_HEAP_INIT(heaps_table);
int main (void)
    /** Initialize user peripherals. */
    app_periph_init();
    /** Initialize BLE Stack. */
    ble_stack_init(&&m_app_ble_callback, &heaps_table);
    // Main Loop
    while (1)
        * Add Application code here, e.g. GUI Update.
        app_log_flush();
        pwr_mgmt_schedule();
     - STACK_HEAP_INIT(heaps_table) defines four global arrays as Heaps for BLE Stack. Do not modify the definition; otherwise, BLE Stack cannot work. For more information about Heap size, see CFG_MAX_CONNECTIONS in “Configure custom_config.h”.
 - You can initialize peripherals in app_periph_init(). In development and debugging phases, the SYS_SET_BD_ADDR in this function can be used to set a temporary Public Address. The user_periph_setup.c in which this function is contained includes the following main code:
/**@brief Bluetooth device address. */
static const uint8_t s_bd_addr[SYS_BD_ADDR_LEN] = {0x11, 0x11, 0x11, 0x11,0x11, 0x11};
void app_periph_init(void)
   SYS_SET_BD_ADDR(s_bd_addr);
   bsp_uart_init();
   app_log_assert_init();
     - You should add main loop code of applications to “while(1) { }”, for example, code to handle external input and update GUI.
 - When using the APP LOG module, call the app_log_flush() in the main loop. This is to ensure logs are output completely before the SoC enters Sleep Mode. For more information about the APP LOG module, see “Output Debug Logs”.
 - Call the pwr_mgmt_shcedule() to implement automatic power management to reduce system power consumption.
Implement Bluetooth LE Business Logics
Related Bluetooth LE business logics of applications are driven by a number of Bluetooth LE SDK callbacks which are defined in the GR551x SDK. Applications need to register these callbacks in the GR551x SDK to obtain operation results or state change notifications of BLE Stack. Bluetooth LE SDK callbacks are called in the interrupt context of Bluetooth LE SDK IRQ. Therefore, do not perform long-running operations in callbacks, for example, blocking function call and infinite loop; otherwise, the system is blocked, causing BLE Stack and the SDK Bluetooth LE module unable to run in a normal timing.
Bluetooth LE SDK callbacks are categorized into different files by GAP, Security Manager, L2CAP, GATT Common, and GATT Client. All callback functions supported by the GR551x SDK are listed in Table 10.
| File Name | Callback Struct | Callback Function |
|   user_app.c  |
          app_callback_t  |
          app_ble_init_cmp_callback  |
|   user_gap_callback.c  |
          gap_cb_fun_t  |
          app_gap_param_set_cb  |
|   app_gap_psm_manager_cb  |
|   app_gap_phy_update_cb  |
|   app_gap_dev_info_get_cb  |
|   app_gap_adv_start_cb  |
|   app_gap_adv_stop_cb  |
|   app_gap_scan_req_ind_cb  |
|   app_gap_adv_data_update_cb  |
|   app_gap_scan_start_cb  |
|   app_gap_scan_stop_cb  |
|   app_gap_adv_report_ind_cb  |
|   app_gap_sync_establish_cb  |
|   app_gap_stop_sync_cb  |
|   app_gap_sync_lost_cb  |
|   app_gap_connect_cb  |
|   app_gap_disconnect_cb  |
|   app_gap_connect_cancel_cb  |
|   app_gap_auto_connection_timeout_cb  |
|   app_gap_peer_name_ind_cb  |
|   app_gap_connection_update_cb  |
|   app_gap_connection_update_req_cb  |
|   app_gap_connection_info_get_cb  |
|   app_gap_peer_info_get_cb  |
|   app_gap_le_pkt_size_info_cb  |
|   app_rslv_addr_read_cb  |
|   user_l2cap_callback.c  |
          l2cap_lecb_cb_fun_t  |
          app_l2cap_lecb_conn_req_cb  |
|   app_l2cap_lecb_conn_cb  |
|   app_l2cap_lecb_add_credits_ind_cb  |
|   app_l2cap_lecb_disconn_cb  |
|   app_l2cap_lecb_sdu_recv_cb  |
|   app_l2cap_lecb_sdu_send_cb  |
|   app_l2cap_lecb_credit_add_cmp_cb  |
|   user_sm_callback.c  |
          sec_cb_fun_t  |
          app_sec_enc_req_cb  |
|   app_sec_enc_ind_cb  |
|   app_sec_keypress_notify_cb  |
|   user_gatt_common_callback.c  |
          gatt_common_cb_func_t  |
          app_gatt_mtu_exchange_cb  |
|   app_gatt_prf_register_cb  |
|   user_gattc_callback.c  |
          gattc_cb_fun_t  |
          app_gattc_srvc_disc_cb  |
|   app_gattc_inc_srvc_disc_cb  |
|   app_gattc_char_disc_cb  |
|   app_gattc_char_desc_disc_cb  |
|   app_gattc_read_cb  |
|   app_gattc_write_cb  |
|   app_gattc_ntf_ind_cb  |
|   app_gattc_srvc_browse_cb  |
|   app_gattc_cache_update_cb  |
You need to implement necessary Bluetooth LE SDK callbacks according to functional requirements of your products. For example, if a product does not support Security Manager, you do not need to implement corresponding callbacks; if the product supports GATT Server only, you do not need to implement the callbacks corresponding to GATT Client. Only those callback functions required for products are to be implemented.
For more information about the usage of Bluetooth LE APIs and callback APIs, see the source code of Bluetooth LE examples in GR551x Bluetooth Low Energy Stack User Guide, SDK_Folder\documentation\GR551x_API_Reference, and SDK_Folder\projects\ble.
Schedule BLE_Stack_IRQ, BLE_SDK_IRQ, and Applications
BLE Stack is the implementation core of BLE protocol stacks. It directly operates the hardware mentioned in Bluetooth 5.1 Core (see “Software Architecture”). Therefore, BLE_Stack_IRQ has the second-highest priority after SVCall IRQ, which ensures that BLE Stack runs strictly in a time sequence specified in Bluetooth Core Spec.
The system_priority_init() in SDK_Folder\toolchain\gr551x\source\system_gr55xx.c is used to set default interrupt priority of modules in the system.
A state change of BLE Stack triggers BLE_SDK_IRQ interrupt with lower priority. In this interrupt handler, the Bluetooth LE SDK callbacks (to be executed in applications) are called to send state change notifications of BLE Stack and related business data to applications. You should avoid performing long-running operations in these callbacks, and shall move such operations to the main loop or user thread for processing. You can use the module in SDK_Folder\components\libraries\app_queue, or your own application framework, to transfer events from Bluetooth LE SDK callbacks to the main loop. For more information about processing in the user thread, see GR551x FreeRTOS Example Application.
