Prepare ble_app_example
Open SDK_Folder\projects\ble\ble_peripheral\, copy ble_app_template to the current directory, and rename it as ble_app_example. Rename the base name of .uvoptx and .uvprojx files in ble_app_example\Keil_5 as ble_app_example.
Double-click ble_app_example.uvprojx to open the project example in Keil. Click
, and select Output in Options for Target ‘GR551x_SK’; enter ble_app_example in Name of Executable.
All groups of the ble_app_example project are available in the Project pane of Keil.
Groups of the ble_app_example project are mainly in two categories: SDK groups and User groups.
- SDK groups
The SDK groups include gr_startup, gr_arch, gr_stack_lib, gr_drivers, gr_app_drivers, gr_libraries, gr_profiles, and external.
Figure 17 SDK groups Source files in the SDK groups are not required to be modified. Group descriptions are provided below:
Table 7 SDK groups SDK Group Name Description gr_startup
It contains the system boot file.
gr_arch
It contains initialization configuration files and system interrupt implementation files for System Core and PMU.
gr_stack_lib
It contains the GR551x SDK .lib file.
gr_drivers It contains drive source files of SoC peripherals. You can add hardware drives on demand. gr_app_drivers
It contains driver API source files, which are easy to use for application developers. You can add related application drivers on demand.
gr_libraries
It contains open source files of common assistant software modules and peripheral drivers provided by in the SDK.
gr_profiles
It contains source files of GATT Services/Service Clients. You can add necessary GATT source files for projects.
external
It contains source files for third-party programs, such as FreeRTOS and SEGGER RTT. You can add third-party programs on demand.
- User groups
User groups include user_callback, user_platform, and user_app.
Figure 18 User groups Functions for source files in User groups need to be implemented by developers. Group descriptions are provided below:
Table 8 User groups User Group Name Description user_callback
It contains BLE Stack callback functions, which are implemented in applications. For more information about callbacks, see Table 10.
user_platform
It implements software and hardware resource setting and application initialization; you need to execute corresponding APIs on demand.
user_app
It contains main() function entries, and other source files created by developers, which are used to configure runtime parameters of BLE Stack and execute event handlers of GATT Services/Service Clients.
