Documentation > GR551x Developer Guide/ Introduction Copy URL
The Goodix GR551x System-on-Chip (SoC) is a single-mode low-power SoC that supports Bluetooth 5.1. It can be configured as a Broadcaster, an Observer, a Central, or a Peripheral, and supports the combination of all the above roles, making it an ideal choice for Internet of Things (IoT) and smart wearable devices.
Based on ARM® Cortex®-M4F CPU core, the GR551x SoC integrates the Bluetooth 5.1 Protocol Stack, a 2.4 GHz RF transceiver, on-chip programmable Flash memory, RAM, and multiple peripherals.
Table 1 GR551x series
Part Number
GR5515IGND
GR5515IENDU
GR5515I0NDA
GR5515RGBD (NRND)
GR5515GGBD
GR5513BENDU
CPU Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F
RAM 256 KB 256 KB 256 KB 256 KB 256 KB 128 KB
SiP Flash 1 MB 512 KB N/A 1 MB 1 MB 512 KB
I/O Number 39 39 39 39 29 22
Package (mm)
QFN56
(7 x 7 x 0.75)
QFN56
(7 x 7 x 0.75)
QFN56
(7 x 7 x 0.75)
BGA68
(5.3 x 5.3 x 0.88)
BGA55
(3.5 x 3.5 x 0.60)
QFN40
(5 x 5 x 0.75)
  • GR5515RGBD is not recommended for new designs (NRND).
  • GR5515IENDU and GR5513BENDU are embedded with wide-voltage Flash, with Flash power supply from 1.65 V to 3.6 V.
GR551x SDK
GR551x SDK provides comprehensive software development support for GR551x SoCs. GR551x SDK contains Bluetooth Low Energy Protocol Stack (Bluetooth LE Stack) APIs, System APIs, peripheral drivers, a tool for generating and downloading .hex files, project example code, and related user documents.
The GR551x SDK version mentioned in this document is applicable to all GR551x SoCs.
Bluetooth LE Stack
The architecture of Bluetooth LE Stack is shown in Figure 1.
Figure 1 Bluetooth LE Stack architecture
The Bluetooth LE Stack consists of the Controller, the Host-Controller Interface (HCI), and the Host.
Controller
  • Physical Layer (PHY) supports 1-Mbps and 2-Mbps adaptive frequency hopping and Gaussian Frequency Shift Keying (GFSK).
  • Link Layer (LL) controls the RF state of devices. Devices are in one of the following five modes, and can switch between the modes on demand: Standby, Advertising, Scanning, Initiating, and Connection.
HCI
  • HCI enables communications between Host and Controller, supported by software interfaces or standard hardware interfaces, for example, UART, Secure Digital (SD), or USB. HCI commands and events are transferred between Host and Controller through HCI.
Host
  • Logical Link Control and Adaptation Protocol (L2CAP) provides channel multiplexing and data segmentation and reassembly services for upper layers. It also supports logic end-to-end data communications.
  • Security Manager (SM) defines pairing and key distribution methods, providing upper-layer protocol stacks and applications with end-to-end secure connection and data exchange functions.
  • Generic Access Profile (GAP) provides upper-layer applications and profiles with interfaces to communicate and interact with protocol stacks, which fulfills functions such as advertising, scanning, connection initiation, service discovery, connection parameter update, secure process initiation, and response.
  • Attribute Protocol (ATT) defines service data interaction protocols between a server and a client.
  • Generic Attribute Profile (GATT) is based on the top of ATT. It defines a series of communications procedures for upper-layer applications, profiles, and services to exchange service data between GATT Client and GATT Server.
For more information about Bluetooth LE technologies and protocols, visit the Bluetooth SIG official website: www.bluetooth.com.
