示例代码
GPIO_TE
示例工程主要调用GPIO_TE驱动接口,配置GPIO中断输入模式,实现按键输入功能。工程路径:SDK_Folder\projects\peripheral\gpio\app_gpio。
初始化参数
  1. IO引脚定义:
    定义key0和key1按键输入引脚。
    #define APP_GPIO_KEY0_PIN        APP_KEY_UP_PIN
    #define APP_GPIO_KEY0_TYPE       APP_KEY_UP_IO_TYPE
    #define APP_GPIO_KEY1_PIN        APP_KEY_OK_PIN
    #define APP_GPIO_KEY1_TYPE       APP_KEY_OK_IO_TYPE
    具体引脚见board_SK.h,如下key0按键输入引脚为AON_1;key1按键输入为AON_0。
    /*******KEY DRIVER IO CONFIG********************/
    #define APP_KEY_UP_IO_TYPE                  APP_IO_TYPE_AON
    #define APP_KEY_DOWN_IO_TYPE                APP_IO_TYPE_AON
    #define APP_KEY_UP_PIN                      APP_IO_PIN_1
    #define APP_KEY_DOWN_PIN                    APP_IO_PIN_0
  2. 定义初始化结构体,用于中断引脚、中断方式和中断回调函数
    const app_gpiote_param_t gpiote_param[] =
        {APP_GPIO_KEY0_TYPE, APP_GPIO_KEY0_PIN, APP_IO_MODE_IT_FALLING,
                                  APP_IO_PULLUP, app_io_event_handler},
        {APP_GPIO_KEY1_TYPE, APP_GPIO_KEY1_PIN, APP_IO_MODE_IT_FALLING,
重要函数
实现GPIO中断配置
app_gpiote_init(gpiote_param, sizeof(gpiote_param) / sizeof(app_gpiote_param_t))
连接开发板到PC端,打开串口调试助手,连接串口。分别按下key0和key1,串口打印如下。(key0和key1对应的物理按键需要根据原理图知晓。)
KEY0 pressed.
KEY1 pressed.
