GPIO
A GR5526 SoC has up to 34 individually configurable GPIOs that can serve as peripherals or digital input/output.
  • Up to 34 digital GPIOs: GPIO_0–GPIO_15 are supplied by VDDIO_1. GPIO_16–GPIO_33 are supplied by VDDIO_0.
  • All I/Os except GPIO_10–GPIO_25, GPIO_32, and GPIO_33 can retain their output levels when the system enters sleep mode.
  • GPIO default state is input mode with pull-down.
  • All GPIOs can be configured as being triggered by high level, low level, rising edge, falling edge, or both edges.
The 34 digital GPIOs can be used:
  • For general-purpose input/output.
  • To multiplex different peripherals on different output pins of the package.
  • To multiplex debug signals from different blocks of the GR5526 SoC.
A functional drawing of the GPIO pads is provided in 图 22. The digital GPIO pads can be configured to set direction, enable pull-up/pull-down resistors, and enable output retention. GPIOs can also be read or written by firmware for applications that need direct access through the GPIOx registers.
图 22 GPIO pad diagram
The general rule for enabling the on-chip pull-up/pull-down resistors is as follows:
  • If a GPIO is unused, enable a pull-down resistor.
  • If a GPIO is configured as an output, disable the pull-up/pull-down resistor. However, if disabling the output causes a high impedance state, enable the pull-up or pull-down resistor during this period.
  • If a GPIO is used as an input and is being actively driven high or low by an external device, disable the pull-up/pull-down resistor (the same thing goes when there is an external pull-up/pull-down resistor on the board. In this case, the on-chip resistor should always be disabled). However, if the external device driving the input ever goes to a high impedance state, a pull-up or pull-down resistor must be enabled during this period.
GPIO_10–GPIO_25 become high impedance in sleep and cannot retain their output levels. During sleep, the signal level of these IOs is determined by the pull-up/pull-down resistors.
DPAD_R_EN_BUS_0
  • Name: GPIO Pull-Up/Down Resistor Enable Register
  • Description: This register decides whether to use pull-up/down resistors.
  • Base Address: 0x4000EE00
  • Offset: 0x000
表 145 DPAD_R_EN_BUS_0 Register
31:0
DPAD_R_EN
Resistor enable control of GPIO_31–GPIO_0
  • 0x0: Enable pull-up/down resistor.
  • 0x1: Disable pull-up/down resistor.
DPAD_RTYP_BUS_0
  • Name: GPIO Resistor Type Control Register
  • Description: This register sets the resistor type to either pull-up or pull-down.
  • Offset: 0x004
表 146 DPAD_RTYP_BUS_0 Register
31:0
DPAD_RTYP
Resistor type of GPIO_31–GPIO_0
  • 0x0: Pull down.
  • 0x1: Pull up.
DPAD_IN_EN_BUS_0
  • Name: GPIO Input Enable Register
  • Description: This register enables a GPIO as input.
  • Base Address: 0xA000E000
  • Offset: 0x008
表 147 DPAD_IN_EN_BUS_0 Register
31:0
DPAD_IN_EN
Active l/O inputs to GPIO_31–GPIO_0
  • 0x0: Enable inputs to pad.
  • 0x1: Disable inputs to pad.
DPAD_R_EN_BUS_1
  • Offset: 0x000
表 148 DPAD_R_EN_BUS_1 Register
31:2
1:0
DPAD_R_EN
Resistor enable control of GPIO_33–GPIO_32.
DPAD_RTYP_BUS_1
  • Name: GPIO Pull-Up/Down Resistor Type Control Register
  • Offset: 0x004
表 149 DPAD_RTYP_BUS_1 Register
31:2
1:0
DPAD_RTYP
Resistor type of GPIO_33–GPIO_32
  • 0x0: Pull down.
  • 0x1: Pull up.
DPAD_IN_EN_BUS_1
  • Base Address: 0x4000E000
  • Offset: 0x008
表 150 DPAD_IN_EN_BUS_1 Register
31:2
1:0
DPAD_IN_EN
Active l/O inputs to the GPIO_33 – GPIO_32
DPAD_R_EN_MISC
  • Name: OSPI and XQSPI I/O Pull-Up/Down Resistor Enable Register
  • Offset: 0x000
表 151 DPAD_R_EN_MISC Register
31:22
21:18
xqspi_io
  • 0x0: Enable pull-up/down resistor for XQSPI I/O.
  • 0x1: Disable pull-up/down resistor for XQSPI I/O.
17
xqspi_cs
  • 0x0: Enable pull-up/down resistor for XQSPI CS.
  • 0x1: Disable pull-up/down resistor for XQSPI CS.
16
xqspi_clk
  • 0x0: Enable pull-up/down resistor for XQSPI clk.
  • 0x1: Disable pull-up/down resistor for XQSPI clk.
15:11
10:3
ospi_io
  • 0x0: Enable pull-up/down resistor for OSPI I/O.
  • 0x1: Disable pull-up/down resistor for OSPI I/O.
2
ospi_cs
  • 0x0: Enable pull-up/down resistor for OSPI CS.
  • 0x1: Disable pull-up/down resistor for OSPI CS.
ospi_dqs
  • 0x0: Enable pull-up/down resistor for OSPI DQS.
  • 0x1: Disable pull-up/down resistor for OSPI DQS.
ospi_clk
  • 0x0: Enable pull-up/down resistor for OSPI clk.
  • 0x1: Disable pull-up/down resistor for OSPI clk.
DPAD_RTYP_MISC
  • Name: OSPI and XQSPI Pull-Up/Down Resistor Type Control Register
  • Offset: 0x004
  • Reset Value: 0x003F0000
表 152 DPAD_RTYP_MISC Register
31:22
21:18
xqspi_io
  • 0x0: Pull down.
  • 0x1: Pull up.
17
xqspi_cs
  • 0x0: Pull down.
  • 0x1: Pull up.
16
xqspi_clk
  • 0x0: Pull down.
  • 0x1: Pull up.
15:11
10:3
ospi_io
  • 0x0: Pull down.
  • 0x1: Pull up.
2
Ospi_cs
  • 0x0: Pull down.
  • 0x1: Pull up.
ospi_dqs
  • 0x0: Pull down.
  • 0x1: Pull up.
ospi_clk
  • 0x0: Pull down.
  • 0x1: Pull up.
DPAD_IN_EN_MISC
  • Name: OSPI and XQSPI Pin Input Enable Register
  • Description: This register enables the input.
  • Offset: 0x008
表 153 DPAD_IN_EN_MISC Register
31:22
21:18
xqspi_io
  • 0x0: Enable inputs to pad for XQSPI I/O.
  • 0x1: Disable inputs to pad for XQSPI I/O.
17
xqspi_cs
  • 0x0: Enable inputs to pad for XQSPI CS.
  • 0x1: Disable inputs to pad for XQSPI CS.
16
xqspi_clk
  • 0x0: Enable inputs to pad for XQSPI clk.
  • 0x1: Disable inputs to pad for XQSPI clk.
15:11
10:3
ospi_io
  • 0x0: Enable inputs to pad for OSPI I/O.
  • 0x1: Disable inputs to pad for OSPI I/O.
2
ospi_cs
  • 0x0: Enable inputs to pad for OSPI CS.
  • 0x1: Disable inputs to pad for OSPI CS.
ospi_dqs
  • 0x0: Enable inputs to pad for OSPI DQS.
  • 0x1: Disable inputs to pad for OSPI DQS.
ospi_clk
  • 0x0: Enable inputs to pad for OSPI clk.
  • 0x1: Disable inputs to pad for OSPI clk.
GPIOx_DATA
  • Name: GPIO Data Value Register
  • Description: This register contains the input data and can write it to data output register.
  • Base Address: 0x40010000 + x*0x1000
  • Offset: 0x0000
表 154 GPIOx_DATA Register
31:16
15:0
DATA
Data value [15:0]:
  • Read: Read the value that is sampled at pin
  • Write: Write the field to the GPIOx_DATA_OUT register.
GPIOx includes GPIOA (GPIO_0–GPIO_15), GPIOB (GPIO_16–GPIO_31), and GPIOC (GPIO_32–GPIO_33).
GPIOx_DATA_OUT
  • Name: GPIO Data Output Register
  • Description: This register contains the output data.
  • Offset: 0x0004
表 155 GPIOx_DATA_OUT Register
31:16
15:0
DATA_OUT
Data output register value [15:0]:
  • Read: current value of data output register
  • Write: to data output register
GPIOx_OUT_EN
  • Name: GPIO Output Enable Register
  • Description: This register is used to enable the GPIO as output.
  • Offset: 0x0010
表 156 GPIOx_OUT_EN Register
31:16
15:0
EN
Output enable set [15:0]:
Read:
  • 0x0: As input
  • 0x1: As output
Write:
  • 0x0: No effect
  • 0x1: Set the output enable bit.
GPIOx_OUT_CLR
  • Name: GPIO Output Enable Clear Register
  • Description: This register is used to disable output bit.
  • Offset: 0x0014
表 157 GPIOx_OUT_CLR Register
31:16
15:0
CLR
Output enable clear [15:0]:
Read:
  • 0x0: as input
  • 0x1: as output
Write:
  • 0x0: No effect
  • 0x1: Clear the output enable bit.
GPIOx_INT_EN
  • Name: GPIO Interrupt Enable Register
  • Description: This register is used to enable GPIO interrupt.
  • Offset: 0x0020
表 158 GPIOx_INT_EN Register
31:16
15:0
EN
Interrupt enable set [15:0]:
Read:
  • 0x0: Interrupt disabled
  • 0x1: Interrupt enabled
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt enable bit.
GPIOx_INT_CLR
  • Name: GPIO Interrupt Enable Clear Register
  • Description: This register is used to disable GPIO interrupt.
  • Offset: 0x0024
表 159 GPIOx_INT_CLR Register
31:16
15:0
CLR
Interrupt enable clear [15:0]:
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt enable bit.
GPIOx_INT_TYPE_EN
  • Name: GPIO Interrupt Type Enable Register
  • Description: This register is used to set GPIO interrupt type.
    • Interrupt type is 0 and interrupt polarity is 0: low-level trigger interrupt
    • Interrupt type is 0 and interrupt polarity is 1: high-level trigger interrupt
    • Interrupt type is 1 and interrupt polarity is 0: falling edge trigger interrupt
    • Interrupt type is 1 and interrupt polarity is 1: rising edge trigger interrupt
  • Offset: 0x0028
表 160 GPIOx_INT_TYPE_EN Register
31:16
15:0
EN
Interrupt type set [15:0]:
Read:
  • 0x0: Low or high level
  • 0x1: Falling edge or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt type bit.
GPIOx_INT_TYPE_CLR
  • Name: GPIO Interrupt Type Clear Register
  • Description: This register is used to disable GPIO interrupt type.
  • Offset: 0x002C
表 161 GPIOx_INT_TYPE_CLR Register
31:16
15:0
CLR
0h 0
Interrupt type clear [15:0]:
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt type bit.
GPIOx_INT_POL_EN
  • Name: GPIO Interrupt Polarity Enable Register
  • Description: This register is used to enable GPIO interrupt polarity.
  • Offset: 0x0030
表 162 GPIOx_INT_POL_EN Register
31:16
15:0
EN
0h 0
Polarity configuration [15:0]:
Read:
  • 0x0: Low level or falling edge
  • 0x1: High level or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt polarity bit.
GPIOx_INT_POL_CLR
  • Name: GPIO Interrupt Polarity Disable Register
  • Description: This register is used to disable GPIO interrupt polarity.
  • Offset: 0x0034
表 163 GPIOx_INT_POL_CLR Register
31:16
15:0
CLR
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt polarity bit.
GPIOx_INT_STAT
  • Name: GPIO IRQ Status Register
  • Description: This register contains GPIO interrupt status and is used to clear the interrupt request.
  • Offset: 0x0038
表 164 GPIOx_INT_STAT Register
31:16
15:0
STAT_CLR
Write one to clear interrupt request:
Read:
  • [15:0] IRQ status register
Write:
  • 0x0: No effect
  • 0x1: To clear the interrupt request
The electrical parameters for the GPIO_0–GPIO_33 are as follows:
表 165 GPIO electrical specifications
VIH
Input high voltage
VDDIO x 0.7
VDDIO
V
VIL
Input low voltage
VSSIO
VDDIO x 0.3
V
VOH,L
Output high voltage, 4 mA, VDDIO ≥ 1.7 V
VDDIO – 0.4
VDDIO
V
VOH,M
Output high voltage, 4 mA, VDDIO ≥ 2.5 V
VDDIO – 0.4
VDDIO
V
VOH,H
Output high voltage, 4 mA, VDDIO ≥ 3 V
VDDIO – 0.4
VDDIO
V
VOL,L
Output low voltage, 4 mA, VDDIO ≥1.7 V
VSS
VSS + 0.4
V
VOL,M
Output low voltage, 4 mA, VDDIO ≥ 2.5 V
VSS
VSS + 0.4
V
VOL,H
Output low voltage, 4 mA, VDDIO ≥ 3 V
VSS
VSS + 0.4
V
IOL,L
Current at VSS+0.4 V, output set low, VDDIO ≥1.7 V
4
mA
IOL,M
Current at VSS+0.4 V, output set low, VDDIO ≥ 2.5 V
5
mA
IOH,L
Current at VDD-0.4 V, output set high, VDDIO ≥ 1.7 V
4
mA
IOH,M
Current at VDD-0.4 V, output set high, VDDIO ≥ 2.5 V
5
mA
tRF,15pF
Rise/Fall time, 10% – 90%, 15 pF load
5
8
ns
tRF,25pF
Rise/Fall time, 10% – 90%, 25 pF load
6
13
ns
RPU
Pull-up resistance
70
120
150
kΩ
RPD
Pull-down resistance
70
120
150
kΩ
CPAD
Pad capacitance
5
pF
