eFuse
GR5526 eFuse (512 bytes) stores the product ID, TRIM, and security parameters. It consists of Main Region (240 bytes), Backup Region (240 bytes), and User Region (32 bytes). User Region is reserved for users to write and read data by calling the eFuse driver. Every single byte of eFuse can only be written once. 图 7 shows the structure of eFuse.
The access to eFuse should be word-aligned, which means the offset address can only be 0x0, 0x4, …, 0x1C.
- The initial eFuse bit is zero, and it can only be changed once from zero to one.
- Little-endian mode; the minimum unit size of read or write is 4 bytes.
- The Main Region has three sections: Key section, Control section and TRIM section0.
- Key section stores all the keys needed for Secure Boot and SPI Flash encryption.
- Control section stores some parameters required by the boot loader for chip configuration.
- TRIM section0 stores chip UID, TRIM parameters, and product configurations. Users can read the chip UID from the address 0x40016110.
- The Backup Region has three sections: Key section, Control section and TRIM section1.
- The values in Control section and Key section of the Backup Region are the same as those in the Main Region.
- TRIM section1 is used to save Flash parameters as well as ADC and COMP calibration parameters.
- The User Region is reserved for users to write and read data by calling the eFuse driver.
- The base address of User Region is 0x40016000.
- Every single byte of eFuse can only be written once.
- Reading from or writing to User Region requires disabling main_or_backup.
Users can use GProgrammer to create and download eFuse files.
eFuse Information
| Name | Offset | Size (Byte) | Description |
| Product ID |
0x15E |
0x2 |
Product ID; the default value is 0x0000; customers can write this field. |
| Chip ID |
0x158 |
0x6 |
Chip ID; the default value is 0x000000000000; customers can write this filed. |
| EncMode |
0x152 |
0x2 |
Firmware security mode (encryption and signature verification)
| SWDDisable |
0x150 |
0x2 |
Bit0–Bit15: Disable SWD.
| Config |
0x14C |
0x4 |
| Package Type |
0x134 |
0x2 |
| XO |
0x12A |
0x2 |
Bit0-Bit15: XO offset |
| BT_MAC |
0x124 |
0x6 |
Bluetooth device address; the system will find the address in NVDS (Non-Volatile Data Storage) first; if no address is found in NVDS, then use this address as the device address. |
| IO_LDO_SEL |
0x123 |
0x1 |
| Chip UUID |
0x110 |
0x10 |
| User region |
0x000 |
0x20 |
eFuse user region; customers can write this field. |
EFUSE_TPGM
- Name: EFUSE TPGM Register
- Description: EFUSE TPGM Register
- Base Address: 0x4001_6400
- Offset: 0x00
- Reset Value: 0x100000F0
| 31:24 | EFUSE_WR_INR | RW | 0x10 | Interval between two bits in eFuse, number of APB CLK cycles |
| 11:0 | EFUSE_PGM_T | RW | 0xF0 | eFuse program time, tpro = EFUSE_PGM_T*T, where T is clock period; range: 9000 ns < tpro < 11000 ns (typical: 10000 ns) |
EFUSE_PGENB
- Name: EFUSE PGENB Register
- Description: EFUSE PGENB Register
- Offset: 0x04
- Reset Value: 0x00000001
| 0 | PGENB | RW | 0x1 | eFuse PGENB signal |
EFUSE_OPTION
- Name: EFUSE OPTION Register
- Description: EFUSE OPTION Register
- Offset: 0x08
| 0 | EFUSE_INIT_CHK_START | WO | 0x0 | Writing "1" to this bit enables eFuse ctrl to start to read the whole eFuse value; writing “0” to this bit enables checking this value. |
EFUSE_STAT
- Name: EFUSE STAT Register
- Description: EFUSE STAT Register
- Base Address: 0x4001_8400
- Offset: 0x10
- Reset value: 0x00000000
| 2 | EFUSE_WR_DONE | RC | 0x0 | 1: eFuse one word write done Note: Reading this register enables hardware to clear this bit. |
| 1 | EFUSE_INIT_CHK_OK | RC | 0x0 | 1: eFuse initial value check success which means the eFuse values are all "0" Note: Reading this register enables hardware to clear this bit. |
| 0 | EFUSE_INIT_CHK_DONE | RC | 0x0 | 1: eFuse initial value check done Note: Reading this register enables hardware to clear this bit. |
RF_REG_2
- Name: RF_REG_2 Register
- Description: RF_REG_2 Register
- Base Address: 0x4000A800
- Offset: 0x0C
- Reset Value: 0x0000A0C0
| 12 | EFUSE_VDDQ_EN_DLY | RW | 0x0 | Delayed enable signal for efuse_vddq (2.5 V) |
| 11 | EFUSE_VDDQ_EN | RW | 0x0 | Enable eFuse 2.5 V. |
| 10 | EFUSE_VDD_EN | RW | 0x0 | Enable eFuse 1.1 V. |
