USB 2.0
GR5526 SoC provides a universal serial bus (USB) device controller that is compliant with USB 2.0 Full-Speed specification. The USB device controller supports six endpoints and four data transfer modes: control transfer, bulk transfer, interrupt transfer, and isochronous transfer.
  • Complaint with USB 2.0 Full-Speed specification
  • Controllable pull-up/pull-down resistor at D+/D-
  • Integrated USB PHY on GR5526 SoCs
  • Support for six endpoints:
    • EP0 as a control endpoint that integrates IN and OUT
    • EP1 as an OUT endpoint supporting both interrupt and bulk transfers
    • EP2 and EP3 as IN endpoints supporting both interrupt and bulk transfers
    • EP4 as an IN endpoint supporting isochronous transfer
    • EP5 as an OUT endpoint supporting isochronous transfer
  • Diverse FIFO sizes:
    • EP0: 2 x 64 bytes FIFOs
    • EP1, EP2, and EP3: 64 bytes FIFO for each
    • EP4 and EP5: 1023 bytes FIFO for each
  • DMA (available for EP3, EP4, and EP5 only)
The USB system of GR5526 comprises four modules: a USB device controller (the light blue module in the 图 58), a clock module (clock data recovery submodule and OSC clock generation source), an AON power module (5 V VBUS to 3.3 V LDO), and a USB transceiver module. The figure below shows the block diagram of a USB system.
图 58 GR5526 USB system block diagram
The USB device controller module contains the following submodules:
  • Digital PHY: receives differential signals from the USB transceiver (XCVR). The submodule generates parallel data and converts the data into differential data in NRZI code that will be then transmitted to the USB XCVR.
  • UTMI I/F: converts parallel signals into standard USB 2.0 Transceiver Macrocell Interface (UTMI) signals.
  • Protocol processing submodule: parses 8-bit parallel data signals received from the UTMI I/F and disassembles the data into different packet fields. The data is then transmitted to the UTMI I/F.
  • Endpoint control submodule: controls write/read permissions of endpoints.
  • Register submodule: receives control commands from MCU and returns the status and interrupt information of the USB device controller module.
  • AON power submodule: detects connection/disconnection of a USB device to/from the host; converts 5 V VBUS supply from the host into 3.3 V supply for the USB XCVR.
Endpoint Configurations
表 299 Endpoint configurations of GR5526 USB device controller
EP# Direction Type FIFO Size Functionality Access DMA
IN/OUT
Control
2 x 64 bytes
Enumeration/Config
APB
Not supported
OUT
Bulk/Interrupt
64 bytes
Data from host
APB
Not supported
2
IN
Bulk/Interrupt
64 bytes
Data to host
APB
Not supported
3
IN
Bulk/Interrupt
64 bytes
Data to host
AHB/APB
Supported
4
IN
Isochronous
1023 bytes
Data to host
AHB/APB
Supported
5
OUT
Isochronous
1023 bytes
Data from host
AHB/APB
Supported
The data transfer modes of EP1, EP2, and EP3 can be configured to either interrupt or bulk by the MCU through registers before USB reset. Default mode: bulk transfer.
EP0 serves as a standard control endpoint for USB enumeration. EP0 receives device requests from the host and returns descriptors; alternatively, EP0 can obtain configurations of diverse-type data sent out by the host.
EP1 receives data sent out from the host in bulk or interrupt mode. The data can be transferred in a packet of up to 64 bytes, and the data content is parsed by the MCU. After enabling EP1 interrupt transfer, the USB device controller parses data sent out from the host and informs the MCU of the packet size of the received data. The MCU reads related FIFO address to obtain the data.
EP2 sends out information to software on the host side and responds to IN requests that data should be sent to the host in bulk or interrupt mode. The data packet size is up to 64 bytes. The MCU writes to-be-transferred data to a corresponding FIFO address and informs the USB device controller to send out the data after packaging it into a packet. The packet format is defined by software.
In general, EP3 supports bulk transfer of large amounts of data. The EP3 accesses the system RAM in DMA mode as an AHB master. It transmits a large amount of data to the USB host. Alternatively, EP3 supports data write by the MCU(4 bytes align) through Advanced Peripheral Bus (APB) and transmits data to the USB host.
EP4 sends isochronous data to the host and supports a FIFO of 1023 bytes. It can be used to transmit audio data and respond to isochronous IN data requests from the host. Similar to EP3, EP4 supports data write by the MCU at the FIFO entry address through APB and transmits data to the USB host. In addition, EP4 accesses the system RAM in DMA mode as an AHB master.
EP5 receives isochronous data from the host and supports a FIFO of 1023 bytes. It can be used to transmit audio data and respond to isochronous OUT data requests from the host. EP5 enables the MCU to read data at the FIFO entry address through APB. In addition, EP5 accesses the system RAM in DMA mode as an AHB master.
USB Enumeration Methods
GR5526 supports USB enumeration by either hardware or software:
  • By hardware: The built-in finite-state machine (FSM) automatically completes the USB enumeration, not requiring MCU or DMA.
  • By software: The MCU parses and responds to all device requests while EP0 serves as a passthrough channel.
Automatic Hardware-enabled Enumeration
In hardware-enabled enumeration, the built-in FSM controls the enumeration procedures, and EP0 automatically parses and responds to standard device requests sent by the host. The hardware-enabled enumeration features highest enumeration efficiency, fast response, and no timeout. In addition, it requires no support from the MCU and exerts the least impact on system. However, this enumeration approach is less flexible to use compared with software-enabled enumeration (supporting enumeration of some USB devices only).
图 59 Hardware-enabled enumeration diagram
Descriptors required in hardware-enumeration such as vendor IDs (VID) and product IDs (PID) of USB devices are stored in GR5526 Flash. The hardware enumeration module provides a built-in 256-byte RAM to store enumeration data. Power on the GR5526 SoC, and the MCU writes the descriptors to the RAM through APB in Flash. During enumeration, the FSM reads corresponding descriptors in the RAM and then responds to device requests sent from the host.
Software-enabled Enumeration
In software-enabled enumeration, EP0 serves as a bidirectional data transfer channel, and the USB device controller module does not parse payloads. This makes the software-enabled enumeration flexible to use (supporting enumeration of all USB devices) and allows users to modify MCU firmware files to ensure optimal interoperability.
图 60 Software-enabled enumeration diagram
Software-enabled enumeration steps:
  1. EP0 sends out an interrupt signal to the MCU after receiving a complete data packet (when an end of packet or EOP signal is detected and CRC validation).
  2. The MCU processes the interrupt signal and then reads and parses data bytes one after another from the EP0 OUT FIFO (the first byte of a packet indicates the packet size).
  3. The MCU successively writes the corresponding data including descriptors that are read from Flash into the IN FIFO of EP0 according to the request type.
  4. When data write completes, set the EP0_1_CTRL register to EP0_DATA_READY by software to inform the USB device controller that the complete data packet has been written to the IN FIFO of EP0.
  5. EP0 sends the data in the IN FIFO to the USB host in a packet.
Bulk and Interrupt Transfer
图 61 EP1, EP2, EP3 data transfer diagram
After EP1 is enabled, it receives the OUT packet sent by the host based on the configured data transfer type (bulk or interrupt), and parses the payload size in the packet as well as contents saved in its FIFO. EP1 then generates the EP1_OUT_READY interrupt to notify the MCU to read payload of the same size from the FIFO.
When the MCU needs to send messages (including data in response to command(s) to EP1, and the status agreed between the MCU software and the host, such as an interrupt status) to the host, the action should be first permitted by EP2. EP1, EP2, and EP3 are in bulk transfer mode by default. If a specific latency is required, users can configure EP2 to interrupt mode via the MCU prior to data transfer.
During EP2 data transfer:
  1. The MCU checks the status register EP2_DATA_READY via APB.
  2. If the space in EP2 FIFO is sufficient, the MCU writes the values read from the register in sequence to the EP2 FIFO in the agreed format. Otherwise, wait until the space becomes sufficient.
  3. When data write completes, the MCU writes to the EP2_DATA_READY register via APB, to inform USB device controller of data write completion and data ready for transmission, to avoid incomplete data transmission caused by data transfer before data write to FIFO completes.
  4. When the USB module receives EP2 IN token from the host, it packs and sends the data from the FIFO to the host.
In addition to the functions of EP2, EP3 supports DMA, which enables bulk data transfer from the MCU to the host: Set the allocation address on RAM for DMA transfer and the size of data to be transferred, and enable the DMA function. By default, the USB module allocates data to the EP3 FIFO before data transfer.
  1. The MCU configures USB registers via APB. Set the condition to trigger EP3 interrupt is when the available space in EP3 FIFO equal to or above 64 bytes.
  2. The MCU checks whether there are sufficient data for USB data transfer based on DMA interrupt. If no, wait until the data blocks become sufficient; if yes, ask USB host via EP2 to fetch data and then proceed to the next step.
  3. The MCU configures the AHB master interface module of EP3 [the configuration covers SRAM offset address, total size of data to be transferred, and data size (burst size) in one read operation by AHB].
  4. AHB master transfers data from the designated address in SRAM to FIFO in the size of one read operation as configured.
  5. After receiving IN Token from the host, EP3 packs and sends data to the host; if the data transfer (one frame) has not completed, AHB master will continue to transfer data from SRAM until the data transfer completes.
The host software parses messages; USB host only passes through data, and places no limit to the payload format and content.
Isochronous Transfer
EP4 and EP5 only support isochronous data transfer, and each uses its FIFO (1023 bytes) for buffer.
图 62 EP4 and EP5 data transfer diagram
During EP4 data transfer:
  • When EP4 sends isochronous data to the host via FIFO:
    1. Enable TX interrupt of EP4 FIFO and the empty packet function of EP4 (to return a packet with null data before data is ready), and disable the pending state of EP4.
    2. Query whether EP4 FIFO is sending data; clear data in FIFO if data TX completes.
    3. Write data to EP4 in every 4 bytes. If the last data segment written to EP4 does not reach 4 bytes, re-configure the size for the last data transfer of EP4 FIFO based on the actual data size (1 byte, 2 bytes, or 3 bytes).
    4. Set the data transfer status of EP4 FIFO to complete.
  • When EP4 sends isochronous data to the host via DMA:
    1. Enable DMA TX interrupt and the empty packet function of EP4 (to return a packet with null data before data is ready), and disable the pending state of EP4.
    2. Query whether EP4 is sending data via DMA; clear data in FIFO if DMA data TX completes.
    3. Set DMA data TX size of EP4 and the RAM entry address to receive data via DMA.
    4. Enable DMA data TX of EP4 as AHB master.
During EP5 data transfer:
  • When EP4 receives isochronous data from the host via FIFO:
    1. Enable RX interrupt of EP5, and disable the pending state of EP5.
    2. After receiving the OUT data from the host, EP5 parses the received payload and writes the parsed data to FIFO; it then generates an interrupt EP5_OUT_READY to inform the MCU of the received data size.
    3. The MCU reads data in accordance with the received data size from the entry address of the EP5 FIFO.
  • When EP5 receives isochronous data from the host via DMA:
    1. Configure the RAM entry address for data transferred via DMA, and the data size to generate interrupt to indicate EP5 DMA RX completes.
    2. Enable DMA RX interrupt and DMA RX timeout interrupt of EP5, and set the timeout period: If the size of received data does not equal the size to generate an interrupt, an interrupt will be generated after the system times out. Disable the pending state of EP5.
    3. After receiving the OUT data from the host, EP5 parses the received payload and writes the parsed data to FIFO. Data will be transferred to the RAM address as configured via DMA; data transfer ends when the transferred size reaches the pre-set size, and an interrupt will be generated to inform the MCU of DMA data RX completion.
    4. If the transferred data size does not reach or exceed the size to generate an interrupt, an interrupt will be generated after the system times out, to inform the MCU of data transfer completion.
CTRL
Name: USB Control Register
Description: This register controls USB base state.
Base Address: 0x0400A900
Offset: 0x0
Reset Value: 0x00000000
表 300 USB Control Register
31:18
17
EP5_OUT_DATA_READY
OUT data in EP5 is ready.
The MCU will clear this bit after reading the data.
16
EP0_FIFO_SWITCH_EN
This bit is used when MCU_ENUM = 0. When hardware enumeration is finished, disable enumeration by hardware.
15
EP1_OUT_DATA_READY
OUT data in EP1 is ready.
The USB will issue NAK before the data is read out.
14:8
FUNC_ADDR
USB function address.
If taking enumeration, the MCU fills in the address; otherwise this field is automatically set by the USB device controller.
7
CMD_ERR
W
Error occurs when the MCU interprets the USB device request.
1: Command or OUT data is wrong.
0: No error.
6
CMD_OK
W
The MCU interprets the request sent by the host to the USB device.
  • If there is no OUT data in the command, the MCU will set the bit after interpreting the command.
  • If there is OUT data in the command, the MCU will set the bit after reading the OUT data packet.
5
CFG_STATUS
USB is in configured status:
If taking enumeration, the MCU fills in the bit; otherwise this field is automatically set by the USB device controller.
4
ADDR_STATUS
USB is in configuring address status.
3
DEV_REMOTE_WAKEUP
REMOTE_WAKEUP feature.
If taking enumeration, the MCU sets this bit for USB device; otherwise this bit is automatically set by the USB device controller.
2
MCU_WAKEUP
W
The MCU wakes up USB host remotely.
When the MCU writes 1 to this bit, and "REMOTE_WAKEUP" feature is set by the host, the USB will wake up the host.
This bit will be cleared after USB wakeup.
EP0_OUT_DATA_READY
OUT data in EP0 is ready.
The MCU will clear this bit after reading the data. USB will issue NAK before the data is read out.
MCU_ENUM
The type of the MCU taking the enumeration process:
0: Hardware-enabled enumeration
1: Software-enabled enumeration (by MCU)
EP0_1_CTRL
Name: USB EP0 and EP1 Control Register
Description: This register controls USB EP0 and EP1.
Offset: 0x04
表 301 USB EP0 and EP1 Control Register
31:3
2
EP1_OFIFO_CLR
W
Write 1 to this bit to clear EP1 OUT FIFO.
EP0_IFIFO_CLR
W
Write 1 to this bit to clear EP0 IN FIFO.
EP0_DATA_READY
The bit is set by MCU when MCU has sent all data to EP0 IN FIFO.
The bit is set by USB device controller when IN FIFO has max-packet-size data to transfer.
After USB device controller sends all EP0 data, it will clear this bit. MCU shall poll this bit before send data to EP0 FIFO, and cannot write data until this bit is cleared.
EP2_CTRL
Name: USB EP2 Control Register
Description: This register controls USB EP2.
Offset: 0x08
表 302 USB EP2 Control Register
31:2
EP2_IFIFO_CLR
W
Write 1 to this bit to clear EP2 IN FIFO.
EP2_DATA_READY
The bit is set by MCU when MCU has sent all data to EP2 IN FIFO.
After USB device controller sends all EP2 data, it will clear this bit. MCU shall poll this bit before sending data to EP2 FIFO, and cannot write data until this bit is cleared.
EP3_CTRL
Name: USB EP3 Control Register
Description: This register controls USB EP3.
Offset: 0x0C
表 303 USB EP3 control Register
31:2
EP3_IFIFO_CLR
W
Write 1 to this bit to clear EP3 IN FIFO.
EP3_DATA_READY
The bit is set by MCU when MCU has sent all data to EP3 IN FIFO.
The bit is set by USB controller when IN FIFO has max-packet-size data to transfer.
After USB device controller sends all EP3 data, it will clear this bit. MCU shall poll this bit before send data to EP3 FIFO, and cannot write data until this bit is cleared.
EP_ATTR
Name: USB Set Endpoint Attribute Register
Description: This register sets USB EP1, EP2 and EP3 attribute.
Offset: 0x10
Reset Value: 0x00000202
表 304 USB Set Endpoint Attribute Register
31:11
10
EP3_HALT_MCU
Set this bit to halt EP3.
8:9
EP3_ATTR
0x2
EP3 attribute setting:
00: Interrupt
01: Isochronous
10: Bulk
11: Undefined
MCU must keep this data consistent with the content of descriptor.
7
6
EP2_HALT_MCU
Set this bit to halt EP2.
4:5
EP2_ATTR
EP2 attribute setting:
00: Interrupt
01: Isochronous
10: Bulk
11: Undefined
3
2
EP1_HALT_MCU
Set this bit to halt EP1
0:1
EP1_ATTR
0x2
EP1 attribute setting:
00: Interrupt
01: Isochronous
10: Bulk
11: Undefined
INT_STAT
Name: USB Interrupt Status Register
Description: This register returns the interrupt status of USB.
Offset: 0x14
表 305 USB Interrupt Status Register
31:26
25
EP5_TIMER_OUT_ERR
AHB master EP5 transmission timeout error.
24
EP5_AHB_XFER_DONE
AHB master EP5 transfer done.
23
EP4_DAT_SENT
The data in the EP4 IN FIFO has been sent to the host.
22
EP4_AHB_XFER_DONE
AHB master EP4 transfer done.
21
EP5_OUT_READY
The data in the EP5 from the USB host is ready.
20
INTO_CONFIG
The hardware enters the enumeration status, and is valid when MCU_ENUM = 0.
19
EP3_DAT_SENT
The data in the EP3 IN FIFO has been sent to the host.
18
EP2_DAT_SENT
The data in the EP2 IN FIFO has been sent to the host.
17
EP0_DAT_SENT
The data in the EP0 IN FIFO has been sent to the host.
16
SOF
SOF interrupt.
15
BYTE_ERR
USB byte error.
14
BIT_STUFF_ERR
USB bit stuff error.
13
SYNC_ERR
USB SYNC error.
12
AHB_EP3_XFER_DONE
AHB master EP3transfer done.
11
NSE_ERR
No such endpoint error.
10
AHB_EP3_XFER_ERR
AHB master EP3 receives error response.
9
HOST_RESET
USB host reset.
8
PID_CRC_ERR
PID CRC error.
7
PID_CKS_ERR
PID checksum error.
6
SEQ_ERR
DATA0/DATA1 PID sequence error.
5
TO_ERR
RX/TX timeout error.
4
UPID_ERR
Receive unsupported PID error.
3
CRC16_ERR
Receive CRC error data.
2
EP1_OUT_READY
The data in the EP1 from the USB host is ready.
EP0_OUT_READY
The setup data in the EP0 from the USB host is ready.
USB_SUSPEND
MCU takes the enumeration process.
USB device controller will turn to the suspended status.
INT_EN
Name: USB Interrupt Enable Register
Description: This register enables USB interrupts.
Offset: 0x18
Reset Value: 0x003EFDFF
表 306 USB Interrupt Enable Register
31:26
25
EP5_TIMER_OUT_ERR_EN
0x01
Enable EP5 transfer timeout interrupt.
24
EP5_AHB_XFER_DONE_EN
0x01
Enable AHB master EP5 transfer done interrupt.
23
EP4_DAT_SENT_EN
0x01
Enable the interrupt source: Data in the EP4 IN FIFO has been sent to the host.
22
EP4_AHB_XFER_DONE_EN
0x01
Enable AHB master EP4 transfer done interrupt.
21
EP5_OUT_READY_EN
0x01
Enable the interrupt source: Data in endpoint5 from USB host is ready.
20
INTO_CONFIG_EN
Enable the interrupt that the hardware completes enumeration process and enters the configured status, which is valid when EP0_FIFO_SWITCH_EN = 1.
19
EP3_DAT_SENT_EN
0x01
Enable the interrupt that EP3 IN FIFO data has been sent to the host.
18
EP2_DAT_SENT_EN
Enable the interrupt that EP2 IN FIFO data has been sent to the host.
17
EP0_DAT_SENT_EN
0x01
Enable the interrupt that EP0 IN FIFO data has been sent to host.
16
SOF_EN
0x01
Enable the SOF interrupt.
15
BYTE_ERR_EN
0x01
Enable the USB byte error interrupt.
14
BIT_STUFF_ERR_EN
0x01
Enable the USB bit stuff error interrupt.
13
SYNC_ERR_EN
Enable the USB SYNC error interrupt.
12
AHB_EP3_XFER_DONE_EN
0x01
Enable the AHB master EP3 transfer done interrupt.
11
NSE_ERR_EN
0x01
Enable the no such endpoint error interrupt.
10
AHB_EP3_XFER_ERR_EN
0x01
Enable the interrupt source: AHB master EP3 receives ERROR response.
9
HOST_RESET_EN
0x01
Enable USB host reset interrupt.
8
PID_CRC_ERR_EN
0x01
Enable PID CRC error interrupt.
7
PID_CKS_ERR_EN
0x01
Enable PID checksum error interrupt.
6
SEQ_ERR_EN
0x01
Enable DATA0/DATA1 PID sequence error interrupt.
5
TO_ERR_EN
0x01
Enable RX/TX timeout error interrupt.
4
UPID_ERR_EN
0x01
Enable receiving unsupported PID interrupt.
3
CRC16_ERR_EN
0x01
Enable receiving CRC error data interrupt.
2
EP1_OUT_READY_EN
0x01
Enable the interrupt that the data in EP1 from USB host is ready.
EP0_OUT_READY_EN
0x01
Enable the interrupt that setup data in EP0 from USB host is ready.
USB_SUSPEND_EN
0x01
Enable the interrupt that MCU takes the enumeration process of USB controller turning to suspended status.
INT_CLR
Name: USB Interrupt Clear Register
Description: This register clears USB interrupts.
Offset: 0x1C
表 307 USB interrupt clear Register
31:26
25
EP5_TIMER_OUT_ERR_CLR
W
Clear EP5 transfer timeout interrupt.
24
EP5_AHB_XFER_DONE_CLR
W
Clear AHB master EP5 transfer done interrupt.
23
EP4_DAT_SENT_CLR
W
Clear the interrupt source: Data in the EP4 IN FIFO has been sent to the host.
22
EP4_AHB_XFER_DONE_CLR
W
Clear AHB master EP4 transfer done interrupt.
21
EP5_OUT_READY_CLR
W
Clear the interrupt source: Data in endpoint5 from USB host is ready.
20
INTO_CONFIG_CLR
W
Clear the interrupt source: The hardware completes enumeration process and enters the configured status, which is valid when EP0_FIFO_SWITCH_EN = 1.
19
EP3_DAT_SENT_CLR
W
Clear the interrupt source: EP3 IN FIFO data has been sent to the host.
18
EP2_DAT_SENT_CLR
W
Clear the interrupt source: EP2 IN FIFO data has been sent to the host.
17
EP0_DAT_SENT_CLR
W
Clear the interrupt source: EP0 IN FIFO data has been sent to host.
16
SOF_CLR
W
Clear the SOF interrupt.
15
BYTE_ERR_CLR
W
Clear the USB byte error interrupt.
14
BIT_STUFF_ERR_CLR
W
Clear the USB bit stuff error interrupt.
13
SYNC_ERR_CLR
W
Clear the USB SYNC error interrupt.
12
AHB_EP3_XFER_DONE_CLR
W
Clear the AHB master EP3 transfer done interrupt.
11
NSE_ERR_CLR
W
Clear the no such endpoint error interrupt.
10
AHB_EP3_XFER_ERR_CLR
W
Clear the interrupt source: AHB master EP3 receives error response.
9
HOST_RESET_CLR
W
Clear USB host reset interrupt.
8
PID_CRC_ERR_CLR
W
Clear PID CRC error interrupt.
7
PID_CKS_ERR_CLR
W
Clear PID checksum error interrupt.
6
SEQ_ERR_CLR
W
Clear DATA0/DATA1 PID sequence error interrupt.
5
TO_ERR_CLR
W
Clear RX/TX timeout error interrupt.
4
UPID_ERR_CLR
W
Clear receiving unsupported PID interrupt.
3
CRC16_ERR_CLR
W
Clear receiving CRC error data interrupt.
2
EP1_OUT_READ_CLR Y
W
Clear the interrupt source: Data in EP1 from USB host is ready.
EP0_OUT_READY_CLR
W
Clear the interrupt source: Setup data in EP0 from USB host is ready.
USB_SUSPEND_CLR
W
Clear the interrupt source: MCU takes the enumeration process of USB device controller turning to suspended status.
EP3_AHBM_RADDR
Name: AHB Master EP3 Reads Start Address Register
Description: This register enables the AHB master EP3 to read the start address.
Offset: 0x20
表 308 AHB Master EP3 Reads Start Address Register
31:0
EP3_RD_SADDR
AHB master EP3 reads start address
EP3_AHMB_CTRL
Name: AHB Master EP3 Reads Control Register
Description: This register controls AHB master EP3.
Offset: 0x24
Reset Value: 0x00004000
表 309 AHB Master EP3 Reads Control Register
31:16
15:8
EP3_AHBM_BURST_SIZE
0x40
AHB master EP3 burst length; default 64 bytes.
7:1
EP3_AHBM_EN
Enable AHB master EP3.
CTRL0
Name: USB Control 0 Register
Description: This register controls USB PHY.
Offset: 0x28
Reset Value: 0x00000048
表 310 USB Control 0 Register
31:19
18:16
PROBE_SEL
Probe selection signal:
  • 0: Main protocol state machine
    • 1: IDLE
    • 2: TOKEN
    • 3: IN
    • 4: IN2
    • 5: OUT
    • 6: OUT2A
    • 7: OUT2B
    • 8: UPDATEW
    • 9: UPDATE
    • 10: UPDATE2
  • 1: RX state machine
    • 1: IDLE
    • 2: ACTIVE
    • 4: TOKEN
    • 8: DATA
  • 2: UTMI signals: RxValid, RxActive, TxValid, and TxReady
  • 3: SYNC state machine, and RxError
    • 0: IDLE
    • 1: K1
    • 2: J1
    • 3: K2
    • 4: J2
    • 5: K3
    • 6: J3
    • 7: K4
  • 4: TX state machine
    • 1: IDLE
    • 2: DATA
    • 4: CRC1
    • 8: CRC2
  • 5: DPLL state machine
15
RXD
RXD real time status.
14
INPUT_EDIAN_CTRL
1: Data is in big endian.
0: Data is in small endian.
13
OUTPUT_ENDIAN_CTRL
12:10
9
XCVR_DM_RPD_EN
Set this bit to drive DM to pull down in transceiver test mode.
8
XCVR_DP_RPD_EN
Set this bit to drive Data plus (D+) to pull down in transceiver test mode.
7
XCVR_DM_RPUSW_EN
Set this bit to drive DM software to pull up in transceiver test mode.
6
XCVR_DP_RPUSW_EN
0x01
Set this bit to drive DP SW to pull up in transceiver test mode.
In function mode, this bit is driven by USB controller and cannot be set.
5
XCVR_DM_RPU_EN
Set this bit to drive DM to pull up in transceiver test mode.
4
XCVR_DP_RPU_EN
Set this bit to drive DP to pull up in transceiver test mode.
3
XCVR_OEB
0x01
Drive output enable buffer (OEB) in transceiver test mode.
2
DRIVE_DM
Drive DM in transceiver test mode.
Read this bit to get the DM status.
DRIVE_DP
Drive DP in transceiver test mode.
Read this bit to get the DP status.
TEST_MODE
0: Function mode
1: USB transceiver test mode
EP3_XFER_LEN
Name: USB Total EP3 Transfer Length Register
Description: This register sets the total USB EP3 transfer length.
Offset: 0x2C
表 311 USB Total EP3 Transfer Length Register
31:16
15:0
EP3_XFER_LEN
Total USB EP3 transfer length.
MCU should set this field for AHB transfer.
RX_CNT
Name: USB Received Data Sum Register
Description: This register gets received data sum in the EP0 FIFO and EP1 FIFO.
Offset: 0x30
表 312 USB Received Data Sum Register
31:16
15:8
EP1_RX_DATA_SUM
USB receives data sum in the EP1 FIFO.
7:0
EP0_RX_DATA_SUM
USB receives data sum in the EP0 FIFO.
CFG_DESC_CTRL
Name: USB Config Descriptor Control Register
Description: This register controls USB config descriptor in hardware-enabled enumeration.
Offset: 0x34
Reset Value: 0x00004912
表 313 USB Config Descriptor Control Register
31:16
15:8
CFG_DESC_SIZE
0x49
Config descriptor size.
7:0
CFG_DESC_START
0x12
Config descriptor start address.
STR_DESC0_CTRL
Name: USB Language ID Descriptor Control Register
Description: This register controls USB language ID descriptor in hardware-enabled enumeration.
Offset: 0x38
Reset Value: 0x00000470
表 314 USB Language ID Descriptor Control Register
31:16
15:8
STR_DESC0_SIZE
0x4
Language ID descriptor size
7:0
STR_DESC0_START
0x70
Language ID descriptor start address
STR_DESC1_CTRL
Name: USB String Descriptor Control Register
Description: This register controls USB string descriptor in hardware-enabled enumeration.
Offset: 0x3C
Reset Value: 0x00001290
表 315 USB String Descriptor Control Register
31:16
15:8
STR_DESC1_SIZE
0x12
String descriptor size
7:0
STR_DESC1_START
0x90
String descriptor start address
EP0_FIFO_ADDR
Name: USB EP0 FIFO Address Register
Description: This register reads or sends USB EP0 FIFO data.
Offset: 0x40
表 316 USB EP0 FIFO Address Register
31:0
USB_EP0_FIFO
USB EP0 FIFO address.
EP1_FIFO_ADDR
Name: USB EP1 FIFO Address Register
Description: This register reads USB EP1 FIFO data.
Offset: 0x44
表 317 USB EP1 FIFO Address Register
31:0
USB_EP1_FIFO
USB EP1 FIFO address.
EP2_FIFO_ADDR
Name: USB EP2 FIFO Address Register
Description: This register sends data to USB EP2 FIFO.
Offset: 0x48
表 318 USB EP2 FIFO Address Register
31:0
USB_EP2_FIFO
W
USB EP2 FIFO address.
EP3_FIFO_ADDR
Name: USB EP3 FIFO Address Register
Description: This register sends data to USB EP3 FIFO.
Offset: 0x4C
表 319 USB EP3 FIFO Address Register
31:0
USB_EP3_FIFO
W
USB EP3 FIFO address.
SRAM_ADDR
Name: USB Descriptor SRAM Address Register
Description: This register indicates USB descriptor SRAM address in hardware-enabled enumeration.
Offset: 0x50
表 320 USB Descriptor SRAM Address Register
31:0
USB_DESC_SRAM
W
STR_DESC2_CTRL
Name: USB String2 Descriptor Control Register
Description: This register controls USB string2 descriptor in hardware-enabled enumeration.
Offset: 0x54
Reset Value: 0x00000A60
表 321 USB String2 Descriptor Control Register
31:16
15:8
STR_DESC2_SIZE
0x0A
When wValue[3:0] = 4'h2, string descriptor size (for string descriptor) should be reserved.
7:0
STR_DESC2_START
0x60
When wValue[3:0] = 4'h2, descriptor start address (for string descriptor) should be reserved.
STR_DESC3_CTRL
Name: USB String3 Descriptor Control Register
Description: This register controls USB string3 descriptor in hardware-enabled enumeration.
Offset: 0x58
Reset Value: 0x00000A70
表 322 USB String3 Descriptor Control Register
31:16
15:8
STR_DESC3_SIZE
0x0A
When wValue[3:0] = 4'h3, string descriptor size (for string descriptor) should be reserved.
7:0
STR_DESC3_START
0x70
When wValue[3:0] = 4'h3, descriptor start address(for string descriptor) should be reserved.
EP4_CTRL
Name: USB EP4 Control Register
Description: This register controls USB EP4.
Offset: 0x60
表 323 USB EP4 Control Register
31:3
2
EP4_EMPTY_PACKET_EN
Enable EP4 empty packet.
EP4_IFIFO_CLR
W
Write 1 to this bit to clear EP4 IN FIFO.
EP4_DATA_READY
The bit is set by MCU when MCU has sent all data to EP4 IN FIFO.
After USB sends all the EP4 data, it will clear this bit. MCU shall poll this bit before sending data to EP4 FIFO, and cannot write data until this bit is cleared.
EP4_AHBM_RADDR
Name: AHB Master EP4 Reads Start Address Register
Description: This register enables the AHB master EP4 to read the start address.
Offset: 0x64
表 324 AHB Master EP4 Reads Start Address Register
31:0
EP4_RD_SADDR
AHB master EP4 reads start address.
EP4_AHBM_CTRL
Name: AHB Master EP4 Reads Control Register
Description: This register controls AHB master EP4.
Offset: 0x68
Reset Value: 0x0003FF00
表 325 AHB Master EP4 Reads Control Register
31:18
17:8
EP4_AHBM_BURST_SIZE
0x3FF
AHB master EP4 burst length is 32 bytes to 1023 bytes; default: 1023 bytes.
7:1
EP3_AHBM_EN
Enable AHB master EP4.
EP4_XFER_LEN
Name: USB Total EP4 Transfer Length Register
Description: This register sets total transfer length of USB EP4.
Offset: 0x6C
表 326 USB Total EP4 Transfer Length Register
31:16
15:0
EP4_XFER_LEN
USB total EP4 transfer length.
EP4_FIFO_WEN
Name: USB EP4 FIFO Writing Byte Enable Register
Description: This register enables writing byte for USB EP4 FIFO.
Offset: 0x80
表 327 USB EP4 FIFO Writing Byte Enable Register
31:4
3:0
EP4_FIFO_WEN
0x1
EP4_FIFO_ADDR
Name: USB EP4 FIFO Address Register
Description: This register sends data to USB EP4 FIFO.
Offset: 0x84
表 328 USB EP4 FIFO Address Register
31:0
USB_EP4_FIFO
W
USB EP4 FIFO address
EP5_CTRL
Name: USB EP5 Control Register
Description: This register controls USB EP5.
Offset: 0x70
表 329 USB EP5 Control Register
31:3
2
EP5_RX_CNT_NO_OVERWIRTE
0: EP5_RX_DATA_SUM can be overwritten.
1: EP5_RX_DATA_SUM cannot be overwritten until it has been read.
EP5_IFIFO_CLR
W
Write 1 to this bit to clear EP5 OUT FIFO.
EP5_AHBM_EN
Enable AHB master EP5.
EP5_AHBM_RADDR
Name: AHB Master EP5 Writing Start Address Register
Description: The register enables the AHB master EP5 to write the start address.
Offset: 0x74
表 330 AHB Master EP5 Writing Start Address Register
31:0
EP5_WR_SADDR
AHB master EP5 writing start address.
EP5_XFER_LEN
Name: USB Total EP5 Transfer Length Register
Description: This register sets total transfer length OF USB EP5.
Offset: 0x78
表 331 USB Total EP5 Transfer Length Register
31:16
15:0
EP5_XFER_LEN
USB total EP5 transfer length.
EP5_TIMER
Name: EP5 Isochronous Data Out Timer Register
Description: This register indicates the OUT timer value of isochronous data transfer of EP5.
Offset: 0x7C
Reset Value: 0x00000001
表 332 EP5 Isochronous Data Out Timer Register
31:16
15:0
USB_EP5_TIMER
0x1
EP5 isochronous out timer value is 1 to 1000 ms.
If this field is set to 0, EP5 will never time out.
EP5_FIFO_ADDR
Name: USB EP5 FIFO Address Register
Description: This register reads USB EP5 FIFO data.
Offset: 0x88
表 333 USB EP5 FIFO Address Register
31:0
USB_EP5_FIFO
USB EP5 FIFO address
EP5_RX_CNT
Name: USB Endpoint5 Received Data Sum Register
Description: This register gets the received data sum in USB Endpoint5.
Offset: 0x8C
表 334 USB Endpoint5 Received Data Sum Register
31:0
EP5_RX_DATA_SUM
USB received data sum in the EP5 transfer.
USB_DEBUG
Name: USB Debug Register
Description: This register is used for USB debugging.
Offset: 0x90
Reset Value: 0x00000150
表 335 USB Debug Register
31:20
19
EP5_OUT_READY_FLAG
WC
Ep5 output ready flag; write 1 to clear it
18
EP4_DAT_SENT_FLAG
WC
Ep4 data sent flag; write 1 to clear it
17
EP5_WR_ERR
WC
Ep5 write err flag; write 1 to clear it
16
EP4_EMTY_PACKET
WC
Ep4 empty packet flag; write 1 to clear it
15:9
8
EP5_FIFO_EMPTY
0x1
Ep5 FIFO empty flag
7
EP4_FIFO_FULL
Ep4 FIFO full flag
6
EP4_FIFO_EMPTY
0x1
Ep4 FIFO empty flag
5
EP3_FIFO_FULL
Ep3 FIFO full flag
4
EP3_FIFO_EMPTY
0x1
Ep3 FIFO empty flag
3:0
USB_PROBE
State output based on probe_sel[2:0]
USB_TRX_LDO
Name: USB LDO Control Register
Description: This register controls USB LDO.
Base Address: 0x4000A884
Offset: 0x00
表 336 USB_TRX_LDO Register
31:11
10:8
USB_RG_LDO3V3_VSEL
USB LDO trimming is used to adjust LDO3V3 voltage.
7:5
6:4
USB_RG_LDO3V3_BIAS_SEL
USB LDO trimming is used to adjust D+/D- rise and fall time.
3:1
USB_RG_LDO3V3_LP_EN
1: Enable USB LDO low power mode.
0: Disable USB LDO low power mode.
USB_LP_CTRL
Name: USB Low Power Control Register
Description: This register controls USB low power mode.
Base Address: 0x4000E140
Offset: 0x00
表 337 USB_LP_CTRL Register
31:9
8
USB_CLK_FORCE_OFF
0: Follow usb_suspend_clk_off.
1: Force usb_clk off.
7:5
4
USB_PMU_LP_EN
0: Disable USB PMU low power mode.
1: Enable USB PMU low power mode.
3:1
USB_SUSPEND_CLK_OFF
Turn off USB clock during USB suspend.
USB_XCVR_CTRL
Name: USB Transceiver Control Register
Description: This register controls USB transceiver.
Offset: 0x04
Reset Value: 0x0000000F
表 338 USB_XCRV_CTRL Register
31:9
10:8
USB_RG_XCVR_RTRIMP
USB D+ trimming is used to adjust D+ impedance.
6:4
USB_RG_XCVR_RTRIMN
USB D- trimming is used to adjust D- impedance.
3
USB_RG_XCVR_BIAS_EN
2
USB_RG_XCVR_SUSPEND
USB suspend control
0: Disable
1: Enable
USB_RG_XCVR_SPEED
1: Full speed
0: Slow speed
USB_RG_XCVR_SECMP_PD
USB single end comparator power down control
0: Power up
1: Power down
USB_SW_RST
Name: USB Module All Reset Control Register
Description: This register controls USB reset.
Offset: 0x0C
表 339 USB_SW_RST Register
31:1
USB_SOFTWARE_RESET
W
Write 1 to reset USB. No need to manually write it back to 0.
表 340 Electrical specifications
IUSB,ACTIVE,VBUS
Current from VBUS supply, USB active
2.7
mA
IUSB,SUSPEND,VBUS
Current from VBUS supply, USB suspended
360
µA
IUSB,DISABLED,VBUS
Current from VBUS supply, USB disabled (low power mode)
0.8
1.1
1.3
µA
RUSB,PU,ACTIVE
Value of pull-up resistance on D+, bus active
1425
2600
3090
Ω
RUSB,PU,IDLE
Value of pull-up resistance on D+, bus idle
900
1500
1575
Ω
fUSB,CLK
Frequency of local clock, USB active
48
MHz
