DC
The display control (DC) module is a powerful display controller which contains several smart tools and functionalities to compose multiple graphics layers by improving image quality and contributing significantly to the reduction of the SoC power consumption. The DC module supports composition features, a wide range of display interfaces, and advanced proprietary framebuffer compression technology. The core is designed to lift the workload off the Graphics Processing Unit (GPU) or the host processor (CPU), in GPU-less systems, and minimize the memory bandwidth.
  • 1 instance
  • Supporting up to two layers with blending capabilities
  • Programmable display resolutions up to 454 x 454
  • Compressed framebuffer support
  • Powerful composition
  • Alpha blending
  • Programmable size, offset, and format per layer
  • Programmable stride/pitch enabling panning and clipping
  • SPI3/SPI4/DualSPI/QuadSPI display interface
  • DMA support (internal dedicated DMA)
  • Input color formats: GBA-8888, ARGB-8888, ABGR-8888, BGRA-8888, RGB-888, RGBA-5551, RGB-565, RGB-332, RGB-565, TSC4,TSC6, TSC6a
    • 3/4w SPI: RGB-111, RGB-332, RGB-444, RGB-565, RGB-666, RGB-888
    • Dual/Quad SPI: RGB-444, RGB-565, RGB-666, RGB-888
Block Diagram
The functional block diagram of display control is shown in 图 82. The display control module contains timing generator, master arbiter, two layers, formatting block, and more.
图 82 Display control block diagram
Pin Mux
Before configuring the display control module functions, you must ensure that the pin mux of the display control interface GPIOs should be configured as DC_DCX, DC_CS_N, DC_CLK, DC_IO_0, DC_IO_1, DC_IO_2, and DC_IO_3.
Clock Divider
The input PLL clock (pll_clk) which is serial clock is fed to the clock divider module. If the optional divider is enabled, then its input is driven by the PLL clock and its ratio is determined by the CLK_CTRL[31:27] register bits. Primary clock’s divider input is driven by the optional divider output, if it is enabled; otherwise by the PLL clock. Primary clock’s divider ratio is determined by the CLK_CTRL[5:0] register bits. In case that SPI interface is selected, the SPI_SCLK is generated by the format_clk, and then a hard division between the SPI_SCLK and the format_clk is applied depending on the INTERFACE_CFG[10:9]. The format_clk and pixel_clk are also fed to Pixel Pipeline and Display Format, representing the different processing stages of the Display controller.
图 83 Clock division diagram
Layer Overlays
The DC module supports two layers (n = 0, 1) sourced from different memory regions. Each layer can have separate color modes, alpha blending, and filtering attributes. The main control registers for each layer are the LAYERn_MODE (n = 0–1) registers. Layer 0 is on top of the background color, and Layer 1 is on top of Layer 0.
Layering starts with a 32-bit background color (RGBA), as shown in 图 84, which is applied on the entire screen. If it is not needed, the background register BG_COLOR field is set to 0. If no layer is enabled, only the background color will be displayed.
图 84 RGBA background color
The base frame address is set in the LAYERn_BASEADDR (n = 0–1) registers. When the video image is stored in the memory, the frame buffer may contain extra bytes after each row of pixels. The number of bytes from one row of pixels to the next row in memory is called stride. These bytes affect how the image is stored in memory and the LAYERn_STRIDE[15:0] (n = 0–1) bits are used to add space between frame lines.
图 85 Layer overlay
For each layer, the start location (registers LAYERn_STARTXY n = 0–1), the visible size (registers LAYERn_SIZEXY n= 0–1), and the resolution (registers LAYERn_RESXY n = 0–1) are needed. For example, if the resolution of an image is 800 x 600 and the size of the required image for layer 0 is 400 x 300 at location (68, 32), then the value of the registers are shown in 表 419:
表 419 Layer0 example
Parameter Register Register Bits Value
Resolution X
RESXY
31–16
800
Resolution Y
RESXY
15–0
600
Start coordinate X
LAYER0_STARTXY
31–16
68
Start coordinate Y
LAYER0_STARTXY
15–0
32
Pixel size in X coordinate
LAYER0_SIZEXY
31–16
400
Pixel size in Y coordinate
LAYER0_SIZEXY
15–0
300
Blending Modes
Each layer supports alpha blending. During blending process, a translucent foreground color (current layer) with a background color (previous layer) are combined, and a new blended color is produced. Foreground color’s translucency may range from completely transparent to completely opaque. If the foreground color is completely transparent, the blended color will be the background color; if the foreground color is completely opaque, the blended color will be the foreground color. When the translucency ranges in between, the blended color is computed as a weighted average of the foreground and background colors. Each layer is blended on top of the previous generated blended layer based on the following equation:
c = c s × F s + c d × F d
表 420 shows the blending modes that the DC module supports:
表 420 Blending modes
Binary Blending Mode Fs Fd
0000
Blend black
0001
Blend white
0010
Blend alpha source
as
as
0011
Blend alpha global
ag
ag
0100
Blend alpha source and alpha global
as* ag
as* ag
0101
Blend inverted source
1 – as
1 – as
0110
Blend inverted global
1 – ag
1 – ag
0111
Blend inverted source and inverted global
1 – ( as* ag)
1 – ( as* ag)
1010
Blend alpha destination
ad
ad
1101
Blend inverted destination
1 – ad
1 – ad
as: The A channel of the source image, representing the transparency of the source image
as: The A channel of the destination image, representing the transparency of the destination image
ag: The global A channel
TSC Format
The DC’s framebuffer compression operates in screen blocks (4 x 4 pixel blocks), and depending on the configuration achieves TSC™4, TSC™6, and TSC™6a lossy, fixed-ratio compression.
• TSC™4 is a 6:1 compression (4bpp).
• TSC™6 is a 4:1 compression (6bpp).
• TSC™6a is a 4:1 compression (6bpp) with alpha channel.
Compression is performed at run time using minimal hardware. Pixel data can be stored in the framebuffer in compressed form and decompressed in the DC module. 图 86 shows the TS compression operation. The output of the TSC™4 compression is 64 bits per 4 x 4 block of pixels, and the output of the TSC™6 compression is 96 bits per 4 x 4 block of pixels. It should be noted that the three compression formats of TSC are all lossy compression, and users need to measure whether the format meets their requirements for reduction.
图 86 TSC™4 /TSC™6 framebuffer compression module
Display Interface
The DC module supports one-/multiple-line SPI. All supported formats are listed as follows:
  • 3-wire SPI
  • 4-wire SPI
  • Dual SPI
  • Quad SPI
The SPI serial interface is mainly composed of five parts:
  • SPI_DC: data/command indicator
  • SPI_CS: chip enable
  • SPI_SCLK: serial clock
  • SPI_SD/SPI_SD1/SPI_SD2/SPI_SD3: serial data output
  • SPI_SI: serial data input
图 87 SPI interface
SPI 3-Wire/4-Wire Serial Interface
The SPI 3-wire serial interface uses the SPI_CS (chip enable), SPI_SCLK (serial clock), and SPI_SD (serial data output). The command word consists of 9 bits: 1-bit data/command indicator and 8-bit command. The data word consists of 1-bit data/command indicator and as many bits as required from the chosen format. The MSB is transmitted first.
图 88 SPI 3-wire serial write transmission
The SPI 4-wire serial interface uses SPI_CS (chip enable), SPI_SCLK (serial clock), SPI_SD (serial data output), and one additional signal SPI_DC (data/command indicator). The command consists of 8 bits. The data consists of n bits, according to the chosen format. The MSB is transmitted first.
图 89 SPI 4-wire serial write transmission
The waveform of the read data is as follows:
图 90 SPI read
DualSPI Serial Interface
The DualSPI serial interface uses SPI_CS (chip enable), SPI_SCLK (serial clock), and SPI_SD & SPI_SD1 (serial data outputs). The command word is always transmitted through the SPI_SD line, and the data is routed through the SPI_SD and SPI_SD1 lines. The command word consists of 9 bits: 1-bit data/command indicator and 8-bit command. The data word consists of 1-bit data/command indicator and n bits, according to the chosen format.
QuadSPI Serial Interface
The QuadSPI serial interface uses SPI_CS (chip enable), SPI_SCLK (serial clock), as well as SPI_SD, SPI_SD1, SPI_SD2, and SPI_SD3 (serial data outputs). The header and the command type are always transmitted through the SPI_SD line, and the data is routed through the SPI_SD, SPI_SD1, SPI_SD2, and SPI_SD3 lines. The header consists of 8 bits. The command word consists of 24 bits, and the data consists of n bits according to the chosen format.
The available signals of the SPI3/4, DualSPI, and QuadSPI interfaces are shown in the table below.
表 421 Available signals of SPI3/4, DualSPI, and QuadSPI interfaces
Pin Name Type Description Source
SCLK Output Serial clock signal Display Controller
CS Output Chip enable when low Display Controller
DC Output Data/Command select Display Controller
SD0 Output Serial data Display Controller
SD1 Output Serial data Display Controller
SD2 Output Serial data Display Controller
SD3 Output Serial data Display Controller
SI Input Serial data (Read) Display Controller
RESET Output Reset display GPIO
TE Input Display Tearing effect signal GPIO
Backlight Output LED driver signals GPIO
Color Input Format
The DC module supports multiple color formats. The supported color formats are the following:
  • L1 big-endian 1-bit
    表 422 L1 big-endian 1-bit
    Pixel 0 Pixel 1 Pixel 2 Pixel 3 Pixel 4 Pixel 5 Pixel 6 Pixel 7
    7
    6
    5
    4
    3
    2
    L0
    L0
    L0
    L0
    L0
    L0
    L0
    L0
    Byte 0
  • L4 big-endian 4-bit
    表 423 L4 big-endian 4-bit
    Pixel 0 Pixel 1
    7
    6
    5
    4
    3
    2
    L3
    L2
    L1
    L0
    L3
    L2
    L1
    L0
    Byte 0
  • L8 8-bit
    表 424 L8 8-bit
    Pixel 0
    7
    6
    5
    4
    3
    2
    L7
    L6
    L5
    L4
    L3
    L2
    L1
    L0
    Byte 0
  • RGBA 8888 32-bit
    表 425 RGBA 8888 32-bit
    Pixel 0
    31
    30
    29
    28
    27
    26
    25
    24
    23
    22
    21
    20
    19
    18
    17
    16
    15
    14
    13
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    A7
    A6
    A5
    A4
    A3
    A2
    A1
    A0
    B7
    B6
    B5
    B4
    B3
    B2
    B1
    B0
    G7
    G6
    G5
    G4
    G3
    G2
    G1
    G1
    R7
    R6
    R5
    R4
    R3
    R2
    R1
    R0
    Byte 3
    Byte 2
    Byte 1
    Byte 0
  • ARGB 8888 32-bit
    表 426 ARGB 8888 32-bit
    Pixel 0
    31
    30
    29
    28
    27
    26
    25
    24
    23
    22
    21
    20
    19
    18
    17
    16
    15
    14
    13
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    B7
    B6
    B5
    B4
    B3
    B2
    B1
    B0
    G7
    G6
    G5
    G4
    G3
    G2
    G1
    G1
    R7
    R6
    R5
    R4
    R3
    R2
    R1
    R0
    A7
    A6
    A5
    A4
    A3
    A2
    A1
    A0
    Byte 3
    Byte 2
    Byte 1
    Byte 0
  • ABGR 8888 32-bit
    表 427 ABGR 8888 32-bit
    Pix 0
    31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0
    R7 R6 R5 R4 R3 R2 R1 R0 G7 G6 G5 G4 G3 G2 G1 G1 B7 B6 B5 B4 B3 B2 B1 B0 A7 A6 A5 A4 A3 A2 A1 A0
    Byte 3 Byte 2 Byte 1 Byte 0
  • BGRA 8888 32-bit
    表 428 BGRA 8888 32-bit
    Pixel 0
    31
    30
    29
    28
    27
    26
    25
    24
    23
    22
    21
    20
    19
    18
    17
    16
    15
    14
    13
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    A7
    A6
    A5
    A4
    A3
    A2
    A1
    A0
    R7
    R6
    R5
    R4
    R3
    R2
    R1
    R0
    G7
    G6
    G5
    G4
    G3
    G2
    G1
    G1
    B7
    B6
    B5
    B4
    B3
    B2
    B1
    B0
    Byte 3
    Byte 2
    Byte 1
    Byte 0
  • RGBA 5551 16-bit
    表 429 RGBA 5551 16-bit
    Pixel 0
    15
    14
    13
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    R4
    R3
    R2
    R1
    R0
    G4
    G3
    G2
    G1
    G1
    B4
    B3
    B2
    B1
    B0
    A0
    Byte 1
    Byte 0
  • RGBA 565 16-bit
    表 430 RGBA 565 16-bit
    Pixel 0
    15
    14
    13
    12
    11
    10
    9
    8
    7
    6
    5
    4
    3
    2
    R4
    R3
    R2
    R1
    R0
    G5
    G4
    G3
    G2
    G1
    G1
    B4
    B3
    B2
    B1
    B0
    Byte 1
    Byte 0
  • RGB 332 8-bit
    表 431 RGB 332 8-bit
    Pixel 0
    7
    6
    5
    4
    3
    2
    R2
    R1
    R0
    G2
    G1
    G0
    B1
    B0
    Byte 0
  • TSC4 16-pixel/64-bit
    表 432 TSC4 16-pixel/64-bit
    Pixel 15 – Pixel 0
    63
    62
    Byte 8 – Byte 0
  • TSC6 16-pixel/96-bit
    表 433 TSC6 16-pixel/96-bit
    Pixel 15 – Pixel 0
    95
    94
    Byte 12 – Byte 0
  • TSC6A 16-pixel with Alpha/96-bit
    表 434 TSC6A 16-pixel with Alpha/96-bit
    Pixel 15 – Pixel 0
    95
    94
    Byte 12 – Byte 0
Color Output Format
Through SPI, the DC module supports the following output color formats:
  • Binary (black & white) 1 bit/pixel
  • RGB111 3 bits/pixel
  • RGB332 8 bits/pixel
  • RGB565 16 bits/pixel
  • RGB666 18 bits/pixel
  • RGB888 24 bits/pixel
Register INTERFACE_CFG[8:0] bits are used to configure the SPI output color formats, and 表 435 shows their values. The [8:6] bits refer to the interface which is set to SPI. The [5:3] bits refer to the data order which can be set from option 0 to option 4. The [2:0] bits refer to the supported color formats which can be set to RGB111, RGB332, RGB444, RGB565, RGB666, and RGB888.
In case of black & white format, users should set the register bits INTERFACE_CFG[2:0] to RGB111 (3 bits/pixel) format and the register bits INTERFACE_CFG[5:3] to option 3. This means that the register bits INTERFACE_CFG[8:0] should be set to 0x0D9 as it can be seen in 表 435. The RGB111 format includes four more options that refer to the output data word ordering. The figures in “SPI 3-Wire/4-Wire Output Format” show the SPI output format depending on the configurations of the INTERFACE_CFG[8:0] register bits.
表 435 INTERFACE_CFG[8:0] register bits setup for the SPI interface
INTERFACE_CFG[8:0] Interface INTERFACE_CFG[8:6] Option INTERFACE_CFG[5:3] Color Format INTERFACE_CFG[2:0]
0x0C1
SPI
option 0
RGB111
0x0C9
SPI
option 1
RGB111
0x0D1
SPI
option 2
RGB111
0x0D9
SPI
option 3
RGB111
0x0E1
SPI
option 4
RGB111
0x0C2
SPI
option 0
RGB332
0x0C3
SPI
option 0
RGB444
0x0C5
SPI
option 0
RGB565
0x0C6
SPI
option 0
RGB666
0x0C7
SPI
option 0
RGB888
0x103
Dual SPI
option 0
RGB444
0x10b
Dual SPI
option 1
RGB444
0x105
Dual SPI
option 0
RGB565
0x106
Dual SPI
option 0
RGB666
0x10e
Dual SPI
option 1
RGB666
0x107
Dual SPI
option 0
RGB888
0x10f
Dual SPI
option 1
RGB888
0x143
Quad SPI
option 0
RGB444
0x145
Quad SPI
option 0
RGB565
0x146
Quad SPI
option 0
RGB666
0x147
Quad SPI
option 0
RGB888
For better screen compatibility, you can do the following:
  • Set the delay that begins at the CS activation and ends at the first positive edge of SPI_CLK.
  • Set the delay that begins at the last negative edge of SPI_CLK and ends at the CS deactivation.
The settings of the above two parts are based on SPI CLK as the unit, and the range we can choose is as follows:
  • 0 = 0 SPI_CLK cycle delay
  • 1 = 1 SPI_CLK cycle delay
  • 2 = 2 SPI_CLK cycles delay
  • 3 = 3 SPI_CLK cycles delay
  • 4 = 4 SPI_CLK cycles delay
  • 5 = 5 SPI_CLK cycles delay
  • 6 = 6 SPI_CLK cycles delay
  • 7 = 7 SPI_CLK cycles delay
Configuration 0x0C1 (RGB111: Option 0)
图 91 SPI-3 RGB111 option 0
图 92 SPI-4 RGB111 option 0
Configuration 0x0C9 (RGB111: Option 1)
图 93 SPI-3 RGB111 option 1
图 94 SPI-4 RGB111 option 1
Configuration 0x0D1 (RGB111: Option 2)
图 95 SPI-3 RGB111 option 2
图 96 SPI-4 RGB111 option 2
Configuration 0x0D9 (RGB111: Option 3)
图 97 SPI-3 RGB111 option 3
图 98 SPI-4 RGB111 option 3
Configuration 0x0E1 (RGB111: Option 4)
图 99 SPI-3 RGB111 option 4
图 100 SPI-4 RGB111 option 4
Configuration 0x0C2 (RGB332-Option 0)
图 101 SPI-3 RGB332 option 0
图 102 SPI-4 RGB332 option 0
Configuration 0x0C3 (RGB444-Option 0)
图 103 SPI-3 RGB444 option 0
图 104 SPI-4 RGB444 option 0
Configuration 0x0C5 (RGB565-Option 0)
图 105 SPI-3 RGB565 option 0
图 106 SPI-4 RGB565 option 0
Configuration 0x0C6 (RGB666-Option 0)
图 107 SPI-3 RGB666 option 0
图 108 SPI-4 RGB666 option 0
Configuration 0x0C7 (RGB888-Option 0)
图 109 SPI-3 RGB888 option 0
图 110 SPI-4 RGB888 option 0
DualSPI Output Format
Configuration 0x103 (RGB444-Option 0)
图 111 DualSPI RGB444 option 0
Configuration 0x10B (RGB444-Option 1)
图 112 DualSPI RGB444 option 1
Configuration 0x105 (RGB565-Option 0)
图 113 DualSPI RGB565 option 0
Configuration 0x106 (RGB666-Option 0)
图 114 DualSPI RGB666 option 0
Configuration 0x10E (RGB666-Option 1)
图 115 DualSPI RGB666 option 1
Configuration 0x107 (RGB888-Option 0)
图 116 DualSPI RGB888 option 0
Configuration 0x10F (RGB888-Option 1)
图 117 DualSPI RGB888 option 1
The QuadSPI serial interface uses SPI_CS (chip enable), SPI_SCLK (serial clock), as well as SPI_SD, SPI_SD1, SPI_SD2, and SPI_SD3 (serial data outputs). The header and the command type are always transmitted through the SPI_SD line, and the data is routed through the SPI_SD, SPI_SD1, SPI_SD2, and SPI_SD3 lines. The header consists of 8 bits. The command word consists of 24 bits, and the data word consists of n bits according to the chosen format.
Configuration 0x143 (RGB444-Option 0)
图 118 QuadSPI RGB444 option 0
Configuration 0x145 (RGB565-Option 0)
图 119 QuadSPI RGB565 option 0
Configuration 0x146 (RGB666-Option 0)
图 120 QuadSPI RGB666 option 0
Configuration 0x147 (RGB888-Option 0)
图 121 QuadSPI RGB888 option 0
MODE
  • Name: Mode Register
  • Description: General control register that activates the DC controller and various parameters, sets the timing signals’ polarity, and chooses the output display formats to meet LCD color specifications.
  • Base Address: 0x4002C000
  • Offset: 0x000
表 436 Mode Register
31
EN
When set to 1, the DC controller is activated.
30:18
17
SINGLE_FRAME
When set to 1, single frame update is enabled.
16:10
9
FORMAT
Selects a format.
  • 0x0: RGB
  • 0x1: YUV/YCbCr
8:1
TEST_MODE
Test mode
  • 0x0: Disable
  • 0x1: Enable
CLK_DIV
  • Name: Clock Divider Register
  • Description: Set proper timing with divisor control bits and specify the number of lines to be prefetched before the start of frame.
  • Offset: 0x004
  • Reset Value: 0x00000401
表 437 Clock Divider Register
31:27
OPTIONAL_DIV
0x00
Value of optional clock divider
  • 0x00: No division
  • 0x01: No division
  • 0x02: Divided by 2
  • 0x0D: Divided by 29
  • 0x0E: Divided by 30
  • 0x0F: Divided by 31
26:6
0:5
PRIMARY_DIV
0x00
Value of primary clock divider
  • 0x00: No division
  • 0x01: No division
  • 0x3D: Divided by 61
  • 0x3E: Divided by 62
  • 0x3F: Divided by 63
BG_COLOR
  • Name: Background Color Register
  • Description: This register specifies the main background color.
  • Offset: 0x008
表 438 Background Color Register
31:24
COLOR_BLUE
Color red is used as background color.
23:16
COLOR_GREEN
Color green is used as background color.
15:8
COLOR_BLUE
Color blue is used as background color.
0:7
COLOR_ALPHA
Color alpha is used as background color.
RES
  • Name: X and Y Resolutions Register
  • Description: This register specifies the main X and Y resolutions.
  • Offset: 0x00C
表 439 X and Y Resolutions Register
31:16
X_RES
Value of X resolution in pixels
15:0
Y_RES
Value of Y resolution in pixels
PLAY
  • Name: Play Register
  • Description: Write any value to this register at the end of the programming sequence to trigger the display controller.
  • Offset: 0x010
表 440 Play Register
31:0
VALUE
Trigger the frame generation process.
INTERFACE_CFG
  • Name: Interface Configuration Register
  • Description: The activation of SPI 3-/4-wire interfaces
  • Offset: 0x028
表 441 Interface Configuration Register
31
INTERFACE_EN
When set to 1, the SPI interfaces are activated.
30
SW_CS_EN
When set to 1, the value of the CSX signal of the SPI interfaces can be configured from the INTERFACE_CFG[29] register bit.
29
CS_VAL
Sets the value of SPI_CS signal:
  • CS is set to one if INTERFACE_CFG[29] has the value of one.
  • CS is set to zero if INTERFACE_CFG[29] has the value of zero.
28:27
26
CLEAR_FIFO
When set to 1, it clears the data FIFO and the command FIFO of the SPI interfaces.
25
Reserved bit
24
INVERT_PIXEL_ORDER
Invert pixel order.
23-22
SPI3/4_EN
Set the SPI 3-wire or 4-wire mode:
  • 2’b01: SPI 4-wire interface is enabled.
  • 2’b10: SPI 3-wire interface is enabled.
21
BACK_PRESSURE
When set to 1, back-pressure for SPI interfaces is enabled.
20
CLK_PHASE
Sets SPI clock phase.
19
CLK_POLARITY
Sets SPI clock polarity.
18:12
11
DUALSPI_SUB_PIXEL
When set to 1, DualSPI sub-pixel transaction is enabled.
10:9
MODE
Set mode of operation- SPI/DualSPI/QuadSPI/QuadSPI DDR:
  • 0x0: Enables SPI.
  • 0x1: Enables DualSPI.
  • 0x2: Enables QuadSPI.
8:6
INTERFAC
The serial interface(SPI) mode:
  • 0x3: SPI
  • 0x4: DualSPI
  • 0x5: QuadSPI
3:5
DATA_ORDER
Set the data order of the 8-bit data word:
  • 0x0: Option 0
  • 0x1: Option 1
  • 0x2: Option 2
  • 0x3: Option 3
  • 0x4: Option 4
  • 0x5: Reserved
  • 0x6: Reserved
  • 0x7: Reserved
2:0
COLOR_FORMAT
Set the color format for DBI Type-B/SPI interfaces:
  • 0x1: RGB111 (3 bits/pixel)
  • 0x2: RGB332 (8 bits/pixel)
  • 0x3: RGB444 (12 bits/pixel)
  • 0x5: RGB565 (16 bits/pixel)
  • 0x6: RGB666 (18 bits/pixel)
  • 0x7: RGB888 (24 bits/pixel)
LAYER0_MODE
  • Name: Layer 0 Mode Register
  • Description: Activate and set-up layer 0.
  • Offset: 0x030
表 442 Layer 0 Mode Register
31
LAYER0_EN
When set to 1, layer n is enabled.
30
FORCE_GLOBAL_ALPHA
When set to 1, force alpha with global alpha.
29:24
23:16
GLOBAL_ALPHA
Alpha layer global value (range: 0x00-0xFF)
15:12
DST_BLEND
Destination blending function for layer 0
  • 0x00: Blend black
  • 0x01: Blend white
  • 0x02: Blend alpha source
  • 0x03: Blend alpha global
  • 0x04: Alpha source and alpha global
  • 0x05:Iinverted source
  • 0x06: Blend inverted global
  • 0x07: Inverted source and inverted global
  • 0x0A: Blend alpha destination
  • 0x0D: Blend inverted destination
11:8
SRC_BLEND
Source blending function for layer 0.
  • 0x00: Blend black
  • 0x01: Blend white
7:6
5
REG_PROTECTION
Enable register protection for DC layer registers. When register protection is enabled, the layer registers take effect in the design only when frame end occurs. Register reading functionality from register file remains the same.
4:0
LAYER0_COLOR_MODE
Color mode for layer 0.
  • 0x00: 8-bit color palette look-up table (LUT8)
  • 0x01: 16-bit RGBA5551 color format
  • 0x02: 32-bit ABGR8888 color format
  • 0x04: 8-bit RGB332 color format
  • 0x05: 16-bit RGB565 color format
  • 0x06: 32-bit BGRA8888 color format
  • 0x07: L8 Grayscale/Palette format
  • 0x08: L1 Black-White/Palette format
  • 0x09: L4 Grayscale/Palette format
  • 0x0A: YUYV color format
  • 0x0B: 24-bit RGB color format
  • 0x0C: YUY2 color format
  • 0x0D: 32-bit RGBA8888 color format
  • 0x0E: 32-bit ARGB8888 color format
  • 0x10: Video YUV 420 mode
  • 0x12: TSc4
  • 0x13: TSc6
  • 0x14: TSc6A
LAYER0_START
  • Name: Layer 0 Start Register
  • Description: X and Y start dimensions of layer 0
  • Offset: 0x034
表 443 Layer 0 Start Register
31:16
LAYER0_X_POSITION
Specify the pixel offset of the starting X dimension of layer 0.
15:0
LAYER0_Y_POSITION
Specify the pixel offset of the starting Y dimension of layer 0.
LAYER0_SIZE
  • Name: Layer 0 Size Register
  • Description: X and Y size of layer 0
  • Offset: 0x038
表 444 Layer 0 Size Register
31:16
LAYER0_X_SIZE
Specify the pixel size of the layer 0 in the X dimension.
15:0
LAYER0_Y_SIZE
Specify the pixel size of the layer 0 in the Y dimension.
LAYER0_ADDR
  • Name: Layer 0 Address Register
  • Description: This register specifies the start address of the framebuffer to be accessed by layer 0.
  • Offset: 0x03C
表 445 Layer 0 Address Register
31:0
ADDR
Specify the start address of framebuffer for layer 0.
LAYER0_STRIDE
  • Name: Layer 0 Stride Register
  • Description: This register specifies the stride and the AXI bus burst of layer 0.
  • Offset: 0x040
表 446 Layer 0 Stride Register
31:26
25
DMA_PREFETCH_EN
DMA prefetch in layer 0
  • 0: Disable
  • 1: Enable
24:17
16
INCR16_EN
When set to 1, INCR16 bursts in layer 0 are allowed.
15:0
Y_POSITION
Specify the stride, which is the distance from line to line in bytes for layer 0 memory.
LAYER0_RES
  • Name: Layer 0 Resolution Register
  • Description: This register specifies X and Y start dimensions for the resolution of layer 0.
  • Offset: 0x044
表 447 Layer 0 Resolution Register
31:16
X_RESOLUTION
Specify the layer 0 pixel resolution in the X dimension.
15:0
Y_RESOLUTION
Specify the layer 0 pixel resolution in the Y dimension.
LAYER1_MODE
  • Name: Layer 1 Mode Register
  • Description: Activate and set-up layer 1.
  • Offset: 0x050
表 448 Layer 1 Mode Register
31
LAYER1_EN
30
FORCE_GLOBAL_ALPHA
29:24
23:16
GLOBAL_ALPHA
15:12
DST_BLEND
Destination blending function for layer 1.
  • 0x00: Blend black
  • 0x01: Blend white
11:8
SRC_BLEND
Source blending function for layer 1.
  • 0x00: Blend black
  • 0x01: Blend white
7:6
5
REG_PROTECTION
4:0
LAYER1_COLOR_MODE
Color mode for layer 1.
  • 0x12: TSc4
  • 0x13: TSc6
  • 0x14: TSc6A
LAYER1_START
  • Name: Layer 1 Start Register
  • Description: X and Y start dimensions of layer 1
  • Offset: 0x054
表 449 Layer 1 Start Register
31:16
LAYER1_X_POSITION
Specify the pixel offset of the starting X dimension of layer 1.
15:0
LAYER1_Y_POSITION
Specify the pixel offset of the starting Y dimension of layer 1.
LAYER1_SIZE
  • Name: Layer 1 Size Register
  • Description: X and Y size of layer 1
  • Offset: 0x058
表 450 Layer 1 Size Register
31:16
LAYER1_X_SIZE
Specify the pixel size of the layer 1 in the X dimension.
15:0
LAYER1_Y_SIZE
Specify the pixel size of the layer 1 in the Y dimension.
LAYER1_ADDR
  • Name: Layer 1 Address Register
  • Description: This register specifies the start address of the framebuffer to be accessed by layer 1.
  • Offset: 0x05C
表 451 Layer 1 Address Register
31:0
ADDR
Specify the start address of framebuffer for layer 1.
LAYER1_STRIDE
  • Name: Layer 1 Stride Register
  • Description: This register specifies the stride and the AXI bus burst of layer 1.
  • Offset: 0x060
表 452 Layer 1 Stride Register
31:26
25
DMA_PREFETCH_EN
DMA prefetch in layer 1
  • 0: Disable
  • 1: Enable
24:17
16
INCR16_EN
When set to 1, INCR16 bursts in layer 1 are allowed.
15:0
Y_POSITION
Specify the stride, which is the distance from line to line in bytes for layer 1 memory.
LAYER1_RES
  • Name: Layer 1 Resolution Register
  • Description: This register specifies X and Y start dimensions for the resolution of layer 1.
  • Offset: 0x064
表 453 Layer 1 Resolution Register
31:16
X_RESOLUTION
Specify the layer 1 pixel resolution in the X dimension.
15:0
Y_RESOLUTION
Specify the layer 1 pixel resolution in the Y dimension.
INTERFACE_CMD
  • Name: Interface Command Register
  • Description: Command register to read/write commands from/to SPI interfaces
  • Offset: 0x0E8
表 454 Interface Command Register
31
BASE_ADDR_FLAG
Being set to 0 indicates that the command data is the base address for partial update. Applied on SPI type.
30
SEND_DATA
Send direct data of type command to the SPI interfaces.
29:28
CMD_WIDTH
Determine the command width.
Applicable only to QuadSPI.
  • 0x00: 1 byte
  • 0x01: 2 bytes
  • 0x02: 3 bytes
  • 0x03: Reserved
27
QSPI_SERIAL_EN
Being set to 1 means switching to serial transmission of the command. Applicable only to QuadSPI.
26
READ_EN
When set to 1, read mode is enabled.
25
Reserved bit
24
CMD_LINE_EN
When set to 1, store internally a command type which is transmitted at the beginning of each scanline.
23:16
15:0
DATA
Data to be sent to the SPI interfaces
INTERFACE_RDAT
  • Name: Interface Read Data Register
  • Description: Data read by DBI Type-B/SPI interfaces is stored in the register.
  • Offset: 0x0EC
表 455 Interface Read Data Register
31:30
READ_CYCLES
On write: Specify the number of read cycles.
  • 0x0: 8 cycles
  • 0x1: 16 cycles
  • 0x2: 24 cycles
  • 0x3: Used along with FMTCTRL[21:16] register bits
On read: Read data from DBI Type-B/SPI interfaces (high bits).
29:0
READ_DATA
Read data from DBI Type-B/SPI interfaces (low bits).
CFG
  • Name: Configuration Register
  • Description: Information register of the layers activation and setup. The reset value of this register changes according to the selected configuration.
  • Offset: 0x0F0
  • Reset Value: 0x01003130
表 456 Configuration Register
31
LAYER3_YUV_MEM_EN
Indicates that layer 3 has YUV Memory.
30
LAYER2_YUV_MEM_EN
Indicates that layer 2 has YUV Memory.
29
LAYER1_YUV_MEM_EN
Indicates that layer 1 has YUV Memory.
28
LAYER0_YUV_MEM_EN
Indicates that layer 0 has YUV Memory.
27:25
24
SPI_EN
0x1
Indicates that SPI interface is enabled.
23
LAYER3_GAMMA_EN
Indicates that layer 3 has Gamma LUT.
22
Reserved bit
21
LAYER3_BLENDER_EN
Indicates that layer 3 has blender.
20
LAYER3_EN
Indicates that layer 3 is enabled.
19
LAYER2_GAMMA_EN
Indicates that layer 2 has Gamma LUT.
18
Reserved bit
17
LAYER2_BLENDER_EN
Indicates that layer 2 has blender.
16
LAYER2_EN
Indicates that layer 2 is enabled.
15
LAYER1_GAMMA_EN
Indicates that layer 1 has Gamma LUT.
14
Reserved bit
13
LAYER1_BLENDER_EN
0x1
Indicates that layer 1 has blender.
12
LAYER1_EN
0x1
Indicates that layer 1 is enabled.
11
LAYER0_GAMMA_EN
Indicates that layer 0 has Gamma LUT.
10
Reserved bit
9
LAYER0_BLENDER_EN
Indicates that layer 0 has blender.
8
LAYER0_EN
0x1
Indicates that layer 0 is enabled.
7
RGB_TO_YUV_EN
Indicates that RGB to YUV/YCbCr converter is enabled.
6
DBI_TYPEB_EN
Indicates that DBI Type-B interface is enabled.
5
YUV_CONVERTER_EN
0x1
Indicates that high quality YUV/YCbCr converter is enabled.
4
FORMAT_EN
0x1
Indicates that formatting is enabled.
3
DITHER_EN
Indicates that dithering is enabled.
2
Reserved bit
CURSOR_EN
Indicates that cursor is enabled.
GAMMA_PALETTE_EN
Indicates that Global Gamma/Palette is enabled.
ID
  • Name: Identification Register
  • Description: This register specifies the identification of the DC.
  • Offset: 0x0F4
  • Reset Value: 0x87452365
表 457 Identification Register
31:0
ID
0x87452365
Constant ID value
INT
  • Name: Interrupt Register
  • Description: This register specifies the interrupt of DC.
  • Offset: 0x0F8
  • Reset Value: 0x00000001
表 458 Interrupt Register
31
IRQ_TRIGGER
Interrupt request trigger control
  • 0: Level triggering is enabled
  • 1: Edge triggering is enabled
30
IRQ_UNDERWAY
Indicates IRQ is underway.
29:7
6
CMD_INT_EN
When set to 1, signal an interrupt when SPI/DBI interfaces have finished the transmission of the commands.
5
FRAME_CPLT_INT_EN
When set to 1, signal an interrupt when SPI/DBI interfaces have finished the transmission of the frame.
4
FRMAE_END_INT_EN
When set to 1, signal an interrupt on frame end.
3
TE_INT_EN
When set to 1, TE interrupt is enabled.
2
Reserved bit
HSYNC_INT_EN
When set to 1, HSYNC interrupt is enabled.
VSYNC_INT_EN
0x1
When set to 1, VSYNC interrupt is enabled.
STAT
  • Name: Status Register
  • Description: This register specifies the status of DC.
  • Offset: 0x0FC
表 459 Status Register
31:19
18
GPI_STACK
Indicates GPI gets stack during packet transaction.
17
CRC_READY
Indicates CRC register read is ready.
16
SPI_RW
Indicates read/write operation on SPI.
15
FIFO_ACK
Indicates the DBI/SPI command FIFO ACK.
14
CS_STATUS
Indicates DBI/SPI CS status.
13
FRAME_END
Indicates frame ends.
12
SPI_PENDING
Indicates pending output transaction in DBI Type-B/SPI interfaces.
11
CMD_PENDING
Indicates pending commands in DBI Type-B/SPI interfaces.
10
DATA_PENDING
Indicates pending RGB data in DBI Type-B/SPI interfaces.
9
Reserved bit
8
TEARING_EFFECT
Indicates DBI Type-B/SPI tearing effect.
7
STICKY_UNDERFLOW
Indicates sticky underflow. This bit is cleared when interrupt register is written.
6
CUR_UNDERFLOW
Indicates current underflow.
5
LAST_LOW
Indicates that the last row is currently displayed.
4
CSYNC_STAT
Indicates the CSYNC signal status (0 or 1) at the current time of reading.
3
VSYNC_STAT
Indicates the VSYNC signal status and the tearing effect signal status (0 or 1) at the current time of reading.
2
HSYNC_STAT
Indicates the HSYNC signal status (0 or 1) at the current time of reading.
DE_STAT
Indicates the DE signal status (0 or 1) at the current time of reading.
DC_STAT
Indicates that the controller is not in active vertical blanking.
COLOR_MODE
  • Name: Color Mode Register
  • Description: This register specifies the color mode of DC.
  • Offset: 0x100
  • Reset Value: 0x0067FF59
表 460 Color Mode Register
31:29
28:23
22
ARGB4444
0x1
Setting to zero indicates that the ARGB4444 16-bit color format is disabled.
21
RGBA4444
0x1
Setting to zero indicates that the RGBA4444 16-bit color format is disabled.
20:19
18
TSC6
0x1
High value indicates that TSC6 is disabled.
17
TSC4
0x1
High value indicates that TSC4 is disabled.
16
LUT8
0x1
Setting to zero indicates that the LUT8 color format is disabled.
15
RGBA5551
0x1
Setting to zero indicates that the RGBA5551 16-bit color format is disabled.
14
ABGR8888
0x1
Setting to zero indicates that the ABGR8888 32-bit color format is disabled.
13
RGB332
0x1
Setting to zero indicates that the RGB332 8-bit color format is disabled.
12
RGB565
0x1
Setting to zero indicates that the RGB565 16-bit color format is disabled.
11
ARGB8888
0x1
Setting to zero indicates that the ARGB8888 32-bit color format is disabled.
10
L8
0x1
Setting to zero indicates that the L8 color format is disabled.
9
L1
0x1
Setting to zero indicates that the L1 color format is disabled.
8
L4
0x1
Setting to zero indicates that the L4 color format is disabled.
7
YUYV
Setting to zero indicates that the YUYV color format is disabled.
6
RGB888
0x1
Setting to zero indicates that the RGB888 24-bit color format is disabled.
5
YUY2
Setting to zero indicates that the YUY2 color format is disabled.
4
RGBA8888
0x1
Setting to zero indicates that the RGBA8888 32-bit color format is disabled.
3
BGRA8888
0x1
Setting to zero indicates that the BGRA8888 32-bit color format is disabled.
2
V_YUV420
Setting to zero indicates that the V_YUV420 color format is disabled.
TLYUV420
Setting to zero indicates that the TLYUV420 color format is disabled.
TSC4_TSC6
0x1
Setting to zero indicates that the TSC4/TSC6 proprietary color format is disabled.
CRC
  • Name: CRC Check Register
  • Description: This register specifies the CRC value.
  • Offset: 0x184
表 461 CRC Check Register
31:0
CRC
CRC value if CRC error exists
CLK_CTRL
  • Name: Clock Control Register
  • Description: Controls the clock gaters and the routing of format and pixel clock.
  • Offset: 0x1A8
表 462 Clock Control Register
31:28
27
LAYER1_BUS_CLK_BYPASS
Layer 1 bus clock clock-gater bypass
26
LAYER1_PIXEL_CLK_BYPASS
Layer 1 pixel clock clock-gater bypass
25
LAYER0_BUS_CLK_BYPASS
Layer 0 bus clock clock-gater bypass
24
LAYER0_PIXEL_CLK_BYPASS
Layer 0 pixel clock clock-gater bypass
23
REGFILE_BYPASS
RegFile clock-gaters bypass
22
BYPASS
Clock-gaters bypass
21:3
2
CLK_SWAP
Pixel generation and format clock swap
CLK_POLARITY
Invert (output) clock polarity.
CLK_DIV_EN
Enable clock divider.
FORMAT_CTRL
  • Name: CS Format Control Register
  • Description: Control CS format.
  • Offset: 0x1AC
表 463 CS Format Control Register
31:16
15:13
CS_END_DELAY
Values of bits [15:13] while reading from a panel in SDR mode and chip phase is 1:
  • 0: Zero SPI_CLK cycle delay
  • 1: One SPI_CLK cycle delay
  • 2: Two SPI_CLK cycles delay
  • 3: Three SPI_CLK cycles delay
  • 4: Four SPI_CLK cycles delay
  • 5: Five SPI_CLK cycles delay
  • 6: Six SPI_CLK cycles delay
  • 7: Seven SPI_CLK cycles delay
12:10
CS_BEGIN_DELAY
Values of bits [12:10] in SDR (Single Data Rate) and DDR (Dual Data Rate) modes:
The above equations apply to both write and read modes regardless the values of chip phase and polarity.
9:0
The timing of this the DC module meets the timing standard of MIPI type C, as follows:
表 464 DC electrical specifications
fsck Clock frequency 48 M
tcss CSX Chip Select setup time(Write) 4T ns
tcsh CSX Chip Select setup time(Read) 4T ns
tas D/CX Address setup time T ns
tah D/CX Address hold time T ns
twc SCL Write cycle 10T ns
twrh SCL H duration(Write) 4T ns
twrl SCL L duration(Write) 4T ns
trc SCL Read cycle 15T ns
trdh SCL H duration(Read) 6T ns
trdl SCL L duration(Read) 6T ns
tds Write data setup time 15 ns
tdh Write data hold time 25 ns
tacc Access time 10 ns
tod Output disable time T ns
Temperature = -30°C to 70°C; VDDI range: dependent on Logic High level input voltage classification; GND = 0 V; T = 10 (±0.5) ns
图 122 DC timing diagram
