PSRAM
The GR5526VGBIP and GR5526RGNIP SoCs have an 8 MB PSRAM. PSRAM uses OSPI for data access. The OSPI address mapping is used to map PSRAM space to 0x30080000 area, which is helpful for users to access this memory space. Pin definitions are shown in 表 21.
| Symbol | Type | Description |
VDD |
Power |
Core supply 1.8 V |
VDDQ |
Power |
IO supply 1.8 V |
VSS |
Ground |
Core supply ground |
VSSQ |
Ground |
IO supply ground |
A/DQ[7:0] |
IO |
Address/DQ bus[7:0] |
DQS/DM |
IO |
DQ Strobe (DQS) clock during reads, data mask during writes. DM (Data Mask) is active high. DM = 1 means “do not write”. |
CE# |
Input |
Chip select, active low. When CE# = 1, chip is in standby state. |
CLK |
Input |
Clock signal |
Specifications
- Single supply voltage:
- VDD: 1.62 to 1.98 V
- VDDQ: 1.62 to 1.98 V
- Interface: OSPI, two bytes transferred per one clock cycle
- Performance: Only 48 MHz clock rate is supported, up to 70 MB/s read/write throughput
- Organization: 8 MB with 1024 Bytes page size
- Refresh: Self-managed
- Operating temperature range:
- Tc: -40°C to +85°C (standard range)
- Maximum standby current:
- 300 μA @ 105°C
- 200 μA @ 85°C
- 100 μA @ 25°C
- 30 μA @ 25°C (half sleep mode with data retained)
Features
- Low
power
features
- Partial array self-refresh
- Auto Temperature Compensated Self-Refresh (ATCSR) by built-in temperature sensor
- User-configurable refresh rate
- Ultra Low Power (ULP) in half sleep mode with data retained
- Software reset
- Output driver LVCMOS with programmable drive strength
- Data Mask for writing data
- Data Strobe enables high-speed read operation
- Register-configurable write and read initial latencies
- Write burst length with a maximum of 1024 bytes and a minimum of 2 bytes
- Wrap and hybrid burst in 16 B/32 B/64 B/1 KB lengths
- Linear burst command
- Row boundary crossing (RBX)
- Read operations can be enabled via Mode Register
- RBX write is not supported
PSRAM is byte-addressable. Memory accesses are required to start on both even and odd addresses, but starting memory access at even addresses is more efficient than starting memory access at odd addresses (example, A[0] = 0). Mode Register accesses allow both even and odd addresses.
The modes of read and write operations are in default Hybrid Wrap 32 mode. Other burst lengths of 16 B, 32 B, 64 B or 1 KB in standard or hybrid wrap modes are configurable by using registers, as shown in the table below. The PSRAM also includes command for linear bursting. Bursts can start on any even address. Write burst length has a minimum of 2 bytes. Read has no minimum length.
| Register MR8[2] | Register MR8[1:0] | Burst Length | Example of Sequence of Bytes During Wrap | |
| Starting Address | Byte Sequence | |||
| 0b’0 | 0b’00 | 16 Byte Wrap | 4 | [4,5,6,…,15,0,1,2,3,…] |
| 0b’0 | 0b’01 | 32 Byte Wrap | 4 | [4,5,6,…,31,0,1,2,3,…] |
| 0b’0 | 0b’10 | 64 Byte Wrap | 4 | [4,5,6,…,63,0,1,2,3,…] |
| 0b’0 | 0b’11 | 1K Byte Wrap | 4 | [4,5,6,…,1023,0,1,2,3,…] |
| 0b’1 | 0b’00 | 16 Byte Hybrid Wrap | 2 |
[2,3,4,…,15,0,1],16,17,…,1023, 0,1,…] |
| 0b’1 | 0b’01 | 32 Byte Hybrid Wrap | 2 |
[2,3,4,…,31,0,1],32,33,…,1023, 0,1,…] |
| 0b’1 | 0b’10 | 64 Byte Hybrid Wrap | 2 |
[2,3,4,…,63,0,1],64,65,…,1023, 0,1,…] |
| 0b’1 | 0b’11 | 1k Byte Hybrid Wrap | 2 | [2,3,4,…,1023,0,1,2,…] |
PSRAM supports the following instructions and follows a certain timing.
| 1st CLK | 2nd CLK | 3rd CLK | |||
Rising/Falling edge |
Rising edge |
Falling edge |
Rising edge |
Falling edge |
Command |
Instruction |
Address[31:24] |
Address[23:16] |
Address[15:8] |
Address[7:0] |
Sync Read |
00h |
A3 |
A2 |
A1 |
A0 |
Sync Write |
80h |
A3 |
A2 |
A1 |
A0 |
Sync Read (Linear Burst) |
20h |
A3 |
A2 |
A1 |
A0 |
Sync Write (Linear Burst) |
A0h |
A3 |
A2 |
A1 |
A0 |
Mode Register Read |
40h |
Mode Register Address |
Mode Register Write |
C0h |
Global Reset |
FFh |
The PASR bits restrict refresh operations to a portion of the total memory array. This feature allows the device to reduce standby current by refreshing only that part of the memory array required by the host system. The refresh options are full array, one-half array, one-quarter array, one-eighth array, or none of the array. The mapping of these partitions can start at either the beginning or the end of the address map.
| Register MR4[2:0] | Refresh Coverage | Address Space | Size |
0b’000 |
Full array (default) |
000000h-7FFFFFh |
8 MB |
0b’001 |
Bottom 1/2 array |
000000h-3FFFFFh |
4 MB |
0b’010 |
Bottom 1/4 array |
000000h-1FFFFFh |
2 MB |
0b’011 |
Bottom 1/8 array |
000000h-0FFFFFh |
1 MB |
0b’100 |
None |
0 |
0 MB |
0b’101 |
Top 1/2 array |
400000h-7FFFFFh |
4 MB |
0b’110 |
Top 1/4 array |
600000h-7FFFFFh |
2 MB |
0b’111 |
Top 1/8 array |
700000h-7FFFFFh |
1 MB |
Half Sleep mode supports putting the device in an ultra-low power state, while the stored data is retained. Half Sleep Mode Entry is entered by writing 0xF0 into Register MR6. CE# going high initiates the Half Sleep mode and must be maintained for the minimum duration of tHS (minimum Half Sleep duration). Half Sleep Exit is initiated by a low-pulsed CE#.
Deep Power Down (DPD) mode supports putting the device into power down state. DPD Entry is entered by writing 0xC0 into Register MR6. CE# going high initiates the DPD mode and must be maintained for the minimum duration of tDPD (minimum Deep Power Down duration). DPD Exit is initiated by a low-pulsed CE#. Register values and memory content are not retained in DPD mode. Afterwards, the DPD mode register values will be reset to defaults. tDPDp is minimum period between two DPD modes (measured from DPD Exit to the next DPD Entry) as well as from the initial power-up to the first DPD Entry.
MR0
- Name: Mode Register 0
- Description: Mode Register
- Base Address: OSPI_XIP_BASE_ADDRESS
- Offset: 0x00
- Reset value: 0x09
7:6 |
FX |
Fixed |
5 |
RD_LT |
Read latency type Value:
4:2 |
RD_LC |
0x2 |
Read latency code When MR0[5] = 0, the latency value and max push out value for each bit of MR0[4:2] are listed below.
When MR0[5] = 1, the latency value for each bit of MR0[4:2] is listed below.
The standard/extended Max. Input CLK Freq (MHz) value for each bit of MR0[4:2] is listed below.
1:0 |
DS |
0x1 |
Drive Strength Value:
MR1
- Name: Mode Register 1
- Offset: 0x01
- Reset Value: 0x8D
7 |
ULP |
Ultra Low Power Device Value:
6:5 |
Reserved bits |
4:0 |
VID |
0x2 |
Vendor ID
MR2
- Name: Mode Register 2
- Offset: 0x02
- Reset Value: 0x93
7 |
GB |
0x1 |
Good-Die Value:
6:5 |
Reserved bits |
4:3 |
DID |
0x2 |
Device ID
2:0 |
DEV_D |
0x3 |
Device Density
MR3
- Name: Mode Register 3
- Offset: 0x03
- Reset Value: 0x80
7 |
RBX |
0x1 |
Row boundary crossing enable Value:
6 |
VCC |
Operating voltage range Value:
5 |
SRF |
Self refresh flag Value:
4:0 |
Reserved bits |
MR4
- Name: Mode Register 4
- Offset: 0x04
- Reset Value: 0x40
7:5 |
WR_L |
0x2 |
Write latency The values of write latency and Fmax (MHz) for MR4[7:5] are listed below.
4 |
FX |
Fixed |
3 |
FLUSH_FREQ |
Refresh Frequency Value:
2:0 |
PASR |
Partial array self-refresh Value: Refer to 表 24 |
MR6
- Name: Mode Register 6
- Offset: 0x06
- Reset Value: 0x00
7:4 |
ULP_MODE_SEL |
W |
ULP modes selection
3:0 |
W |
Reserved bits |
MR8
- Name: Mode Register 8
- Offset: 0x08
- Reset Value: 0x00
7 |
FX |
Fixed |
6:4 |
Reserved bits |
3 |
RBX |
Row Boundary Crossing Read Enable Value:
2 |
BT |
0x1 |
Burst Type. Value: Refer to 表 22 |
1:0 |
BL |
0x1 |
Burst Length Value: Refer to 表 22 |
