PWM
GR5526 SoC has two instances of Pulse Width Modulation (PWM) module. The PWM generates successive pulses with variable duty cycles that can be converted to analog levels by external discrete components, such as controlling LED brightness via a PWM signal.
  • Configurable output frequency and dynamic frequency configuration
  • The three PWM channel outputs (pwma, pwmb, and pwmc) can only be configured independently in the flicker mode.
  • Two operation modes: flicker mode and breath mode
  • Two alignment modes: edge alignment mode and center alignment mode
  • Configurable duty cycles in flicker mode
  • Three configuration modes: synchronize-all, synchronize-separate, and asynchronous
  • Polarity switching to support positive-drive and negative-drive mode
  • Optional stop I/O voltage level in active/idle mode: low level or high level
Block Diagram
The PWM block diagram is illustrated in 图 23.
图 23 PWM block diagram
The PWM is capable of configuring output frequency dynamically.
The PWM block can provide three independent channel outputs: pwma, pwmb and pwmc in flicker mode.
The PWM block has two operation modes: flicker mode and breath mode.
In flicker mode, the PWM module outputs successive pulses with a certain frequency and duty as configured. In breath mode, the duty of PWM output periodically changes from 0% to 100%, and then 100% to 0% uniformly. The change period is configurable.
In flicker mode, the duty of PWM can be configured in the range of 0% to 100%. The three outputs can be configured independently, and they share one output frequency.
In flicker mode, both edge alignment and center alignment are supported.
Choose edge alignment mode, as shown in the 图 24. All open channels are aligned at the beginning of each duty cycle.
图 24 PWM edge alignment
Choose center alignment mode, as shown in the 图 25. All open channels are aligned in the middle of each duty cycle.
图 25 PWM center alignment
The configured data can be updated into active registers in three modes: synchronize-all mode (enabled by UPDATE_SYNC_AE), synchronize-separate mode (enabled by UPDATE_SYNC_Sxx) and asynchronous update mode (enabled by UPDATE_SYNC_AE and UPDATE_SYNC_Sxx).
In breath mode, the breathing cycle can be set by BR_PRD, which represents the number of PWM cycles required for the duty cycle 0%→100% and then 100%→0%
In breath mode, a configurable duration of breath hold state (HOLD) is supported. The breath hold state is set between two adjacent breath processes, which are duty change (0%→100%→0%), breath hold, and duty change (0%→100%→0%). In the hold state, the PWM output is driven by inactive state.
Both positive-drive mode and negative-drive mode are supported and can be configured in PD_x_EN. In positive-drive mode, a valid output is configured by setting the PWM output logic level to 1, and an invalid output is set when the PWM output logic level is 0. In negative-drive mode, a valid output is configured by setting the PWM output logic level to 0, and an invalid output is set when PWM output logic level is 1.
In flicker mode, if the stop level is configured (the default value of FLICKER_PAUSE_LEVEL_x is 0 when not set), when PWM stops, the I/O level of the corresponding channel will be pulled to the set value. In breath mode, the I/O levels of all channels are the same and set by BREATH_PAUSE_LEVEL when PWM stops. When the MCU enters sleep state, the stop level remains high in both flicker mode and breath mode.
Operation
There are several shadow registers in the PWM module. The write operation will first change the shadow registers, and then will update the value of active registers from the shadow registers under certain conditions.
Active registers update conditions:
  1. In synchronize-all update mode (UPDATE_SYNC_AE = 0x1), all effective registers of flicker mode or breath mode will be updated simultaneously. In flicker mode (BREATH_EN = 0), after writing to PRD, CMPxx and AQ_CTRL will update from shadow registers simultaneously when the Time Base counter counts to a value of PRD minus 1.
    图 26 Flicker mode waveform
    In breath mode (BREATH_EN = 1), after writing to PRD, BR_PRD, and HOLD will update from shadow registers simultaneously when the current breath process ends (the moment PWM duty reduces to 0%). When using the app_pwm_update_freq interface, the PWM frequency will be updated immediately.
    图 27 Breath mode waveform
  2. In synchronize-separate update mode (UPDATE_SYNC_AE = 0x0), PRD, CMPxx, and AQ_CTRL will update when the Time Base counter counts to value of the PRD register minus 1 if the corresponding UPDATE_SYNC_Sxx bit is set. BR_PRD and HOLD will update when the current breath process ends and the corresponding UPDATE_SYNC_Sxx bit is set.
  3. In asynchronous update mode (UPDATE_SYNC_AE = 0x0 && UPDATE_SYNC_Sxx = 0x0), all registers will update instantly.
In initial state, set the update mode first, then PRD, CMPxx, AQ_CTRL, BR_PRD, and HOLD registers are configured, and then, drive mode is configured to choose the positive-drive mode or negative-drive mode, finally, choose breath mode or flicker mode and enable PWM.
Duty Cycle Calculation
The PWM duty cycle can be configured as an integer from 0 to 100, depending on the following calculation formulas of the duty cycle accuracy "n".
  • In PWM_ALIGNED_EDGE mode:
    n = f PWM ÷ f SYSCLK × 100
  • In PWM_CENTER_EDGE mode:
    n = f PWM ÷ f SYSCLK × 200
For example, when the clock frequency is 64 MHz, and the duty cycle is in the range of 0 to 100, the maximum PWM frequency can only be set to 640 kHz in the PWM_ALIGNED_EDGE mode and 320 kHz in the PWM_ALIGNED_CENTER mode.
Recommended Setting in Breath Mode
In breath mode, in order to satisfy that the duty cycle of the waveform changes from 0 to 100 and then from 100 to 0, it is allowed to set the values of PRD and BR_PRD to an integer that is multiple(s) of 128. The freq, bperiod and hperiod in the structure pwm_init_t need to meet the following formula during initialization:
f r e q × b p e r i o d = 1000 × k k ≥ 2 & & k ∈ i n t e r g e r
SYS CLK 1000 × hperiod ≤ 16777215
where, k represents the number of PWM cycles required for the duty cycle from 0% to 100%; SYSCLK represents the system clock frequency.
MODE
  • Name: Mode Register
  • Description: This register sets the PWM operation mode.
  • Base Address: 0x4000CB00 + x*0x100
  • Offset: 0x0
*x is used to identify the PWM Module instance. The “x” can be 0 or 1.
表 186 Mode Register
31:10
9
BREATH_PAUSE_LEVEL
PWMA/B/C output IO level when suspending in Breath Mode
8
FLICKER_PAUSE_LEVEL_C
PWMC output IO level when suspending in Flicker Mode
7
FLICKER_PAUSE_LEVEL_B
PWMB output IO level when suspending in Flicker Mode
6
FLICKER_PAUSE_LEVEL_A
PWMA output IO level when suspending in Flicker Mode
5
PD_C_EN
PWMC positive-drive mode enable.
  • 0x0: negative-drive mode
  • 0x1: positive-drive mode
4
PD_B_EN
PWMB positive-drive mode enable.
3
PD_A_EN
PWMA positive-drive mode enable.
2
BREATH_EN
Breath mode enable.
  • 0x0: flicker mode
  • 0x1: breath mode
PAUSE
PWM pause signal.
  • 0x0: Ongoing
  • 0x1: Pause
ENABLE
Enable PWM.
  • 0x0: Disable
  • 0x1: Enable
UPDATE
  • Name: Update Register
  • Description: This register is used to set the synchronous update mode.
  • Offset: 0x4
表 187 Update Register
31:18
17
UPDATE_SYNC_SAQCTRL
Separate update enable of AQ_CTRL
  • 0x0: Disable
  • 0x1: Enable
16
UPDATE_SYNC_SHOLD
Separate update enable of HOLD
  • 0x0: Disable
  • 0x1: Enable
15
UPDATE_SYNC_SBRPRD
Separate update enable of BR_PRD
  • 0x0: Disable
  • 0x1: Enable
14
UPDATE_SYNC_SCMPC1
Separate update enable of CMPC1
  • 0x0: Disable
  • 0x1: Enable
13
UPDATE_SYNC_SCMPC0
Separate update enable of CMPC0
  • 0x0: Disable
  • 0x1: Enable
12
UPDATE_SYNC_SCMPB1
Separate update enable of CMPB1
  • 0x0: Disable
  • 0x1: Enable
11
UPDATE_SYNC_SCMPB0
Separate update enable of CMPB0
  • 0x0: Disable
  • 0x1: Enable
10
UPDATE_SYNC_SCMPA1
Separate update enable of CMPA1
  • 0x0: Disable
  • 0x1: Enable
9
UPDATE_SYNC_SCMPA0
Separate update enable of CMPA0
  • 0x0: Disable
  • 0x1: Enable
8
UPDATE_SYNC_SPRD
Separate update enable of PRD
  • 0x0: Disable
  • 0x1: Enable
7:2
UPDATE_SYNC_AE
Synchronous update enable
  • 0x0: Disable
  • 0x1: Enable
UPDATE_SYNC_AG
Synchronous update ongoing
  • 0x0: Not ongoing
  • 0x1: Ongoing
PRD
  • Name: Period Register
  • Description: This register is used to set the PWM cycle.
  • Offset: 0x8
  • Reset Value: 0x64
表 188 Period Register
31:0
PRD
0x64
The period of PWM output, PRD=fCLK/fPWM
CMPA0
  • Name: Compare A0 Register
  • Description: This register controls the PWM duty of Compare register 0 of channel A.
  • Offset: 0xC
表 189 Compare A0 Register
31:0
CMPA0
PWMA duty control register0
CMPA1
  • Name: Compare A1 Register
  • Description: This register controls the PWM duty of Compare register 1 of channel A.
  • Offset: 0x10
表 190 Compare A1 Register
31:0
CMPA1
PWMA duty control register1
CMPB0
  • Name: Compare B0 Register
  • Description: This register controls the PWM duty of Compare register 0 of channel B.
  • Offset: 0x14
表 191 Compare B0 Register
31:0
CMPB0
PWMB duty control register0
CMPB1
  • Name: Compare B1 Register
  • Description: This register controls the PWM duty of Compare register 1 of channel B.
  • Offset: 0x18
表 192 Compare B1 Register
31:0
CMPB1
PWMB duty control register1
CMPC0
  • Name: Compare C0 Register
  • Description: This register controls the PWM duty of Compare register 0 of channel C.
  • Offset: 0x1C
表 193 Compare C0 Register
31:0
CMPC0
PWMC duty control register0
CMPC1
  • Name: Compare C1 Register
  • Description: This register controls the PWM duty of Compare register 1 of channel C.
  • Offset: 0x20
表 194 Compare C1 Register
31:0
CMPC1
PWMC duty control register1
AQ_CTRL
  • Name: Action Qualifier Control Register
  • Description: This register is used to set actions when counter reaches the compare value.
  • Offset: 0x24
表 195 Action Qualifier Control Register
31:12
11:10
AQ_CTRL_C1
Action of event CNT_CMPC1 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
9:8
AQ_CTRL_C0
Action of event CNT_CMPC0 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
7:6
AQ_CTRL_B1
Action of event CNT_CMPB1 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
5:4
AQ_CTRL_B0
Action of event CNT_CMPB0 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
3:2
AQ_CTRL_A1
Action of event CNT_CMPA1 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
1:0
AQ_CTRL_A0
Action of event CNT_CMPA0 control register
  • 0x0: Do nothing
  • 0x1: Clear
  • 0x2: Set
  • 0x3: Toggle
BR_PRD
  • Name: Breath Period Register
  • Description: This register configures the period of breath mode.
  • Offset: 0x28
表 196 Breath Period Register
31:0
BREATH_PRD
Register for breath period that is the required time (number of clock) that the duty changes from 0% to 100% in breath mode.
HOLD
  • Name: Hold Register
  • Description: This register configures the hold period in breath mode.
  • Offset: 0x2C
表 197 Hold Register
31:24
23:0
HOLD
Breath hold control register. The value should be the required number of clock in breath hold state.
