I2C
The Inter-Integrated Circuit (I2C) bus is a two-wire serial interface that is widely used for low-speed communication between chipsets in a system. Using I2C, a microcontroller can communicate with peripherals such as sensors, data converters, and I/O interfaces.
The device has two I2C module instances: I2C0 and I2C1 that can be configured as either Master or Slave.
The two-wire I2C serial interface consists of a serial data line (SDA) and a serial clock line (SCL) that support:
- Standard Mode (up to 100 kbit/s)
- Fast Mode (up to 400 kbit/s)
- Fast Plus Mode (up to 1000 kbit/s)
- Clock synchronization
- Master or Slave I2C operation
- 7-bit or 10-bit addressing
- Mixed 7-bit and mixed 10-bit format transfer
- Transmit and receive FIFO depth at 8 bytes
- Interrupt or polled-mode operation
- Handling of Bit and Byte waiting at all bus speeds
- Simple software interface
- DMA support
he I2C Controller is made up of an APB slave interface, an I2C interface, and FIFO logic to maintain consistency between the two interfaces, as well as DMA and interrupt logics. A simplified block diagram is illustrated below.
I2C Operation
The I2C is a synchronous serial interface. The SDA line is a bidirectional signal and changes only when the SCL line is low, except for STOP, START, and RESTART conditions. The output drivers are open-drain or open-collector to perform wired-AND functions on the bus. The maximum number of devices on the bus is limited by only the maximum capacitance specification of 400 pF. Data is transmitted in byte packages.
The master is responsible for generating the clock and controlling the transfer of data. The slave is responsible for either transmitting or receiving data to/from the master. The acknowledgement of data is sent by the device that is receiving data, which can be either a master or a slave. The I2C protocol also allows multiple masters to reside on the I2C bus and uses an arbitration procedure to determine the bus ownership.
When a master wants to communicate with a slave, the master transmits a START/RESTART condition that is then followed by the slave address and a control bit (R/W) to determine if the master wants to transmit data to or receive data from the slave. The slave then sends an acknowledge (ACK) pulse after the address.
If the master (master-transmitter) is writing to the slave (slave-receiver), the receiver gets one byte of data. This transaction continues until the master terminates the transmission with a STOP condition. If the master is reading from a slave (master-receiver), the slave transmits (slave-transmitter) a byte of data to the master, and the master then acknowledges the transaction with the ACK pulse. This transaction continues until the master terminates the transmission by not acknowledging (NACK) the transaction after the last byte is received, and then the master issues a STOP condition or addresses another slave after issuing a RESTART condition. This behavior is illustrated in the figure below.
START and STOP Conditions
When I2C operates as a Master, putting data into the transmit FIFO causes the I2C block to generate a START condition on the I2C bus. Writing 1 to DATA_CMD[9] causes the I2C block to generate a STOP condition on the I2C bus; a STOP condition is not issued if this bit is not set, even if the transmit FIFO is empty.
When the bus is idle, both the SCL and SDA signals are pulled high through external pull-up resistors on the bus. When a master wants to start a transmission on the bus, the master issues a START condition. This is defined as a high-to-low transition of the SDA signal while SCL is high. When a master wants to terminate the transmission, the master issues a STOP condition. This is defined as a low-to-high transition of the SDA line while SCL is high. The following figure shows the timing of the START and STOP conditions. When data is being transmitted on the bus, the SDA line must be stable when the SCL is high.
Addressing Slave
There are two address formats: the 7-bit address format and the 10-bit address format. The I2C block supports mixed formats of read and write transactions in 7-bit or 10-bit addressing modes. The I2C block does not support mixed address or mixed address format, that is, a 7-bit address transaction followed by a 10-bit address transaction or vice versa (combined format transactions).
7-bit Address Format
sing the 7-bit address format, the first seven bits (bits 7:1) of the first byte set the slave address and the least significant bit (bit 0) (LSB) is the R/W bit as shown in the figure below. When bit 0 (R/W) is set to 0, the master writes to the slave. When bit 0 (R/W) is set to 1, the master reads from the slave.
10-bit Address Format
Using the 10-bit address format, two bytes are transferred to set the 10-bit address. The transfer of the first byte contains the following bit definition. The first five bits (bits 7:3) notify the slave that this is a 10-bit transfer followed by the next two bits (bits 2:1), which set the slave address (bits 9:8), and the LSB bit (bit 0) is the R/W bit. The second byte transferred sets bits 7:0 of the slave address. The figure below shows the 10-bit address format.
The table below defines the special purpose and reserved first byte addresses.
| Slave Address | R/W Bit | Description |
0000 000 |
0 |
General Call Address. DW_apb_i2c places the data in the receive buffer and issues a General Call interrupt. |
0000 000 |
1 |
START byte |
1111 0XX |
X |
10-bit slave addressing |
Transmitting and Receiving
A master can initiate data transmission and reception to/from the bus, acting as either a master-transmitter or master-receiver. A slave responds to requests from the master to either transmit data or receive data to/from the bus, acting as either a slave-transmitter or slave-receiver, respectively.
Master-Transmitter and Slave-Receiver
All data is transmitted in byte format, with no limit on the number of bytes transferred per data transfer. After the master sends the address and R/W bit or the master transmits a byte of data to the slave, the slave-receiver must respond with the ACK signal. When a slave-receiver does not respond with an ACK pulse, the master aborts the transfer by issuing a STOP condition. The slave must leave the SDA line high so that the master can abort the transfer.
If the master-transmitter is transmitting data as shown in the following figure, the slave-receiver responds to the master-transmitter with an ACK pulse after every data byte is received.
Master-Receiver and Slave-Transmitter
If the master is receiving data as shown in the following figure, the master responds to the slave-transmitter with an ACK pulse after a byte of data has been received, except for the last byte. This is the way in which the master-receiver notifies the slave-transmitter that this is the last byte. The slave-transmitter relinquishes the SDA line after detecting the No Acknowledge (NACK) so that the master can issue a STOP condition.
START BYTE Transfer
The START BYTE transfer protocol is set up for systems that do not have an on-board dedicated I2C hardware module. When the I2C block is addressed as a slave, it always samples the I2C bus at the highest speed supported so that it never requires a START BYTE transfer. However, when the I2C block is a master, it supports the generation of START BYTE transfers that a slave device might require at the beginning of every transfer.
This protocol consists of seven zeros being transmitted followed by a one, as illustrated in the figure below. This allows the processor that is polling the bus to under-sample the address phase until 0 is detected. Once the microcontroller detects a 0, it switches from the under sampling rate to the correct rate of the master.
The START BYTE procedure is as follows:
- Master generates a START condition.
- Master transmits the START byte (0000 0001).
- Master transmits the ACK clock pulse. (Present only to conform with the byte handling format used on the bus)
- No slave sets the ACK signal to 0.
- Master generates a RESTART condition.
A hardware receiver does not respond to the START BYTE because it is a reserved address and resets after the RESTART condition is generated.
CTRL
Name: I2C Control Register
Description: This register can be written only when the I2C is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect.
Base Address: 0x4000C300 + x*0x100
Offset: 0x00
Reset Value: 0x0000007F
31:12 |
Reserved bits |
11 |
BUS_CLR_FEATURE |
In Master mode Value:
10 |
STOP_DET_M_ACTIVE |
9 |
RXFIFO_FULL_HLD |
This bit controls whether I2C should hold the bus when the RX FIFO is physically full. Value:
8 |
TX_EMPTY_CTRL |
This bit controls the generation of the TX_EMPTY interrupt, as described in the RAW_INT_STAT register. Value:
7 |
STOP_DET_INT |
In slave mode Value:
Note: During a general call address, the slave does not issue the STOP_DET interrupt if STOP_DET_INT = 1, even if the slave responds to the general call address by generating ACK. The STOP_DET interrupt is generated only when the transmitted address matches the slave address (S_ADDR). |
6 |
S_DIS |
0x1 |
This bit controls whether I2C has its slave disabled. By default, the slave is always disabled (in reset state as well). If you need to enable it after reset, set this bit to 0. If this bit is set (slave is disabled), I2C functions only as a master and does not perform any action that requires a slave. Note: Software should ensure that if this bit is written with 0, then bit 0 should also be written with 0. Value:
5 |
RESTART_EN |
0x1 |
Determine whether RESTART conditions may be sent when I2C acting as a master. Some older slaves do not support handling RESTART conditions; however, RESTART conditions are used in several I2C operations. When RESTART is disabled, the master is prohibited from performing the following functions:
By replacing RESTART condition followed by a STOP and a subsequent START condition, split operations are broken down into multiple I2C transfers. If the above operations are performed, it will result in setting bit 6 (TX_ABORT) of the RAW_INT_STAT register. Value:
4 |
ADDR_BIT_M |
0x1 |
This bit controls whether the I2C starts its transfers in 7-bit or 10-bit addressing mode when I2C acts as a master. Value:
3 |
ADDR_BIT_S |
0x1 |
When I2C acts as a slave, this bit controls whether the I2C responds to 7- or 10-bit addresses. Value:
2:1 |
SPEED |
0x3 |
These bits control at which speed the I2C operates; its setting is relevant only if one is operating the I2C in master mode. Hardware protects against illegal values being programmed by software. These bits must be programmed appropriately for slave mode, as it is used to capture correct value of spike filter as per the speed mode. This register should be programmed only with a value in the range of 1 to 2.
0 |
M_MODE |
0x1 |
This bit controls whether the I2C master is enabled. Note: Software should ensure that if this bit is written with '1', then bit 6 should also be written with '1'. Value:
TARGET_ADDR
Name: I2C Target Address Register
Description: This register can be written to only when EN[0] is set to 0. You cannot change the TARGET_ADDR address dynamically.
Note:If the software or application is aware that the I2C is not using the TARGET_ADDR address for the pending commands in the TX FIFO, it is possible to update the TARGET_ADDR address even when the TX FIFO has entries (STAT[2]= 0).
It is not necessary to perform any write to this register if the I2C is enabled as an I2C slave only.
Offset: 0x04
Reset Value: 0x00000055
31:12 |
Reserved bits |
11 |
SPECIAL |
This bit indicates whether software performs a Device-ID or General Call or START BYTE command. Value:
10 |
TX_CTRL |
If bit 11 (SPECIAL) is set to 1, this bit indicates whether a General Call or START BYTE command is to be performed by the I2C. Value:
9:0 |
TARGET |
0x55 |
This is the target address for any master transaction. When transmitting a General Call, these bits are ignored. To generate a START BYTE, the CPU needs to write only once into these bits. If the TARGET_ADDR and S_ADDR are the same, loopback exists but the FIFOs are shared between master and slave, so full loopback is not feasible. Only one direction loopback mode is supported (simplex), not duplex. A master cannot transmit to itself; it can transmit to a slave only. |
S_ADDR
Name: I2C Slave Address Register
Description: This register sets the address for I2C when it acts as a slave.
Offset: 0x08
31:10 |
Reserved bits |
9:0 |
S_ADDR |
0x55 |
The S_ADDR holds the slave address when the I2C is operating as a slave. For 7-bit addressing, only S_ADDR[6:0] is used. This register can be written only when the I2C interface is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. Note: The default values cannot be any of the reserved address locations: 0x00 to 0x07, or 0x78 to 0x7F. The correct operation of the device is not guaranteed if you program the S_ADDR or TARGET_ADDR to a reserved value. Refer to Table 411 for a complete list of these reserved values. |
DATA_CMD
Name: I2C RX/TX Data Buffer and Command Register
Description: This is the register the CPU writes to when filling the TX FIFO and the CPU reads from when retrieving bytes from RX FIFO.
Note:In order to continue acknowledging reads, a read command should be written for every byte that is to be received; otherwise the I2C will stop acknowledging.
Offset: 0x10
Reset Value: 0x00000000
31:9 |
Reserved bits |
8 |
CMD |
W |
This bit controls whether a read or a write is performed. This bit does not control the direction when the I2C acts as a slave. It controls only the direction when it acts as a master. Value:
7:0 |
DATA |
This register contains the data to be transmitted or received on the I2C bus. If you are writing to this register and want to perform a read, bits 7:0 (DATA) are ignored by the I2C. However, when you read this register, these bits return the value of data received on the I2C interface. |
SS_CLK_HCOUNT
Name: Standard Speed I2C Clock SCL High Count Register
Description: Standard Speed I2C Clock SCL High Count Register
Offset: 0x14
Reset Value: 0x00000190
31:16 |
Reserved bits |
15:0 |
COUNT |
0x0190 |
This register must be set before any I2C bus transaction can take place to ensure proper I/O timing. This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 6; hardware prevents values less than this being written, and if attempted, the value will be set to 6. Note: This register must not be programmed to a value higher than 65525, because I2C uses a 16-bit counter to flag an I2C bus idle condition when this counter reaches a value of COUNT + 10. |
SS_CLK_LCOUNT
Name: Standard Speed I2C Clock SCL Low Count Register
Description: Standard Speed I2C Clock SCL Low Count Register
Offset: 0x18
Reset Value: 0x000001D6
31:16 |
Reserved bits |
15:0 |
COUNT |
0x01D6 |
This register must be set before any I2C bus transaction can take place to ensure proper I/O timing. This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 8; hardware prevents values less than this being written, and if attempted, the value will be set to 8. |
FS_CLK_HCOUNT
Name: Fast Mode or Fast Mode Plus I2C Clock SCL High Count Register
Description: Fast Mode or Fast Mode Plus I2C Clock SCL High Count Register
Offset: 0x1C
Reset Value: 0x0000003C
31:16 |
Reserved bits |
15:0 |
COUNT |
0x003C |
This register must be set before any I2C bus transaction can take place to ensure proper I/O timing. This register can be written only when the I2C interface is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 6; hardware prevents values less than this being written, and if attempted, the value will be set to 6. |
FS_CLK_LCOUNT
Name: Fast Mode or Fast Mode Plus I2C Clock SCL Low Count Register
Description: Fast Mode or Fast Mode Plus I2C Clock SCL Low Count Register
Offset: 0x20
Reset Value: 0x00000082
31:16 |
Reserved bits |
15:0 |
COUNT |
0x0082 |
This register must be set before any I2C bus transaction can take place to ensure proper I/O timing. This register can be written only when the I2C interface is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 8; hardware prevents values less than this being written, and if attempted, the value will be set to 8. |
INT_STAT
Name: I2C Interrupt Status Register
Description: Each bit in this register has a corresponding mask bit in the INT_MASK register. These bits are cleared by reading the matching interrupt clear register. The unmasked raw versions of these bits are available in the RAW_INT_STAT register.
Offset: 0x2C
31:15 |
Reserved bits |
14 |
RAW_SCL_STUCKLOW |
See RAW_INTR_STAT for a detailed description of RAW_SCL_STUCK_AT_LOW bit. Values:
13 |
RAW_M_HOLD |
See RAW_INT_STAT for a detailed description of RAW_M_HOLD bit. Value:
12 |
RAW_RESTART_DET |
See RAW_INT_STAT for a detailed description of RAW_RESTART_DET bit. Value:
11 |
RAW_GEN_CALL |
See RAW_INT_STAT for a detailed description of RAW_GEN_CALL bit. Value:
10 |
RAW_START_DET |
See RAW_INT_STAT for a detailed description of RAW_START_DET bit. Value:
9 |
RAW_STOP_DET |
See RAW_INT_STAT for a detailed description of RAW_STOP_DET bit. Value:
8 |
RAW_ACTIVITY |
See RAW_INT_STAT for a detailed description of RAW_ACTIVITY bit. Value:
7 |
RAW_RX_DONE |
See RAW_INT_STAT for a detailed description of RAW_RX_DONE bit. Value:
6 |
RAW_TX_ABORT |
See RAW_INT_STAT for a detailed description of RAW_TX_ABORT bit. Value:
5 |
RAW_RD_REQ |
See RAW_INT_STAT for a detailed description of RAW_RD_REQ bit. Value:
4 |
RAW_TX_EMPTY |
See RAW_INT_STAT for a detailed description of RAW_TX_EMPTY bit. Value:
3 |
RAW_TX_OVER |
See RAW_INT_STAT for a detailed description of RAW_TX_OVER bit. Value:
2 |
RAW_RX_FULL |
See RAW_INT_STAT for a detailed description of RAW_RX_FULL bit. Value:
1 |
RAW_RX_OVER |
See RAW_INT_STAT for a detailed description of RAW_RX_OVER bit. Value:
0 |
RAW_RX_UNDER |
See RAW_INT_STAT for a detailed description of RAW_RX_UNDER bit. Value:
INT_MASK
Name: I2C Interrupt Mask Register
Description: These bits mask their corresponding interrupt status bits. This register is active low; a value of 0 masks the interrupt, whereas a value of 1 unmasks the interrupt.
Offset: 0x30
Reset Value: 0x000008FF
31:12 |
Reserved bits |
11 |
MASK_GEN_CALL |
0x1 |
This bit masks the RAW_GEN_CALL interrupt in INT_STAT register. Value:
10 |
MASK_START_DET |
This bit masks the RAW_START_DET interrupt in INT_STAT register. Value:
9 |
MASK_STOP_DET |
This bit masks the RAW_STOP_DET interrupt in INT_STAT register. Value:
8 |
MASK_ACTIVITY |
This bit masks the RAW_ACTIVITY interrupt in INT_STAT register. Value:
7 |
MASK_RX_DONE |
0x1 |
This bit masks the RAW_RX_DONE interrupt in INT_STAT register. Value:
6 |
MASK_TX_ABORT |
0x1 |
This bit masks the RAW_TX_ABORT interrupt in INT_STAT register. Value:
5 |
MASK_RD_REQ |
0x1 |
This bit masks the RAW_RD_REQ interrupt in INT_STAT register. Value:
4 |
MASK_TX_EMPTY |
0x1 |
This bit masks the RAW_TX_EMPTY interrupt in INT_STAT register. Value:
3 |
MASK_TX_OVER |
0x1 |
This bit masks the RAW_TX_OVER interrupt in INT_STAT register. Value:
2 |
MASK_RX_FULL |
0x1 |
This bit masks the RAW_RX_FULL interrupt in INT_STAT register. Value:
1 |
MASK_RX_OVER |
0x1 |
This bit masks the RAW_RX_OVER interrupt in INT_STAT register. Value:
0 |
MASK_RX_UNDER |
0x1 |
This bit masks the RAW_RX_UNDER interrupt in INT_STAT register. Value:
RAW_INT_STAT
Name: I2C Raw Interrupt Status Register
Description: Unlike the INT_STAT register, these bits are not masked so they always show the true status of the I2C.
Offset: 0x34
31:15 |
Reserved bits |
14 |
RSCL_STUCKLOW |
Indicates whether the SCL Line is stuck at low for the IC_SCL_STUCK_LOW_TIMEOUT number of ic_clk periods Value:
13 |
RM_HOLD |
Indicate whether the master is holding the bus and TX FIFO is empty. Value:
12 |
RRESTART_DET |
Indicate whether a RESTART condition has occurred on the I2C interface when I2C is operating in Slave mode and the slave is being addressed. Note: However, in High-speed Mode or during a START BYTE transfer, the RESTART comes before the address field as per the I2C protocol. In this case, the slave is not the addressed slave when the RESTART is issued, therefore I2C does not generate the RESTART_DET interrupt. Value:
11 |
RGEN_CALL |
Set only when a General Call address is received and it is acknowledged. It stays set until it is cleared either by disabling I2C or when the CPU reads bit 0 of the CLR_GEN_CALL register. I2C stores the received data in the RX buffer. Value:
10 |
RSTART_DET |
Indicate whether a START or RESTART condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode. Value:
9 |
RSTOP_DET |
Indicate whether a STOP condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode. In Slave Mode: If CTRL[7] = 0x1 (STOP_DET_INT), the STOP_DET interrupt will be issued only if slave is addressed. Note: During a general call address, this slave does not issue a STOP_DET interrupt if STOP_DET_INT = 0x1, even if the slave responds to the general call address by generating ACK. The STOP_DET interrupt is generated only when the transmitted address matches the slave address (S_ADDR). If CTRL[7] = 0x0 (STOP_DET_INT), the STOP_DET interrupt is issued irrespective of whether it is being addressed.
In Master Mode:
8 |
RACTIVITY |
This bit captures I2C activity and stays set until it is cleared. There are four ways to clear it:
Once this bit is set, it stays set unless one of the four methods is used to clear it. Even if the I2C module is idle, this bit remains set until cleared, indicating that there was activity on the bus. Value:
7 |
RRX_DONE |
When the I2C is acting as a slave-transmitter, this bit is set to 1 if the master does not acknowledge a transmitted byte. This occurs on the last byte of the transmission, indicating that the transmission is done. Value:
6 |
RTX_ABORT |
This bit indicates if I2C, as an I2C transmitter, is unable to complete the intended actions on the contents of the transmit FIFO. This situation can occur both as an I2C master or an I2C slave, and is referred to as a 'transmit abort'. When this bit is set to 1, the TX_ABORT_SRC register indicates the reason why the transmit abort takes place. Note: The I2C flushes/resets/empties only the TX_FIFO whenever there is a transmit abort caused by any of the events tracked by the TX_ABORT_SRC register. The TX FIFO remains in this flushed state until the register CLR_TX_ABORT is read. Once this read is performed, the TX FIFO is then ready to accept more data bytes from the APB interface. Value:
5 |
RRD_REQ |
This bit is set to 1 when I2C is acting as a slave and another I2C master is attempting to read data from I2C. The I2C holds the I2C bus in a wait state (SCL=0) until this interrupt is serviced, which means that the slave has been addressed by a remote master that is asking for data to be transferred. The processor must respond to this interrupt and then write the requested data to the DATA_CMD register. This bit is set to 0 just after the processor reads the CLR_RD_REQ register. Value:
4 |
RTX_EMPTY |
The behavior of the TX_EMPTY interrupt status differs based on the TX_EMPTY_CTRL selection in the CTRL register.
It is automatically cleared by hardware when the buffer level goes above the threshold. When EN[0] is set to 0, the TX FIFO is flushed and held in reset. Therefore, the TX FIFO looks like it has no data within it, so this bit is set to 1, provided there is any activity in the master or slave state machines. When there is no longer any activity, then with EN[0] = 0, this bit is set to 0. Value:
3 |
RTX_OVER |
Set during transmit if the transmit buffer is filled to 8 and the processor attempts to issue another I2C command by writing to the DATA_CMD register. When I2C module is disabled, this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared. Value:
2 |
RRX_FULL |
Set when the receive buffer reaches or goes above the RX_FIFO_THD threshold in the RX_FIFO_THD register. It is automatically cleared by hardware when buffer level goes below the threshold. If I2C module is disabled (EN[0] = 0), the RX FIFO is flushed and held in reset; therefore the RX FIFO is not full. So this bit is cleared once the EN bit 0 is programmed with a 0, regardless of the activity that continues. Value:
1 |
RRX_OVER |
Set if the receive buffer is completely filled to 8 and an additional byte is received from an external I2C device. The I2C acknowledges this, but any data bytes received after the FIFO is full are lost. If I2C module is disabled (EN[0]=0), this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared. Value:
0 |
RRX_UNDER |
Set if the processor attempts to read the receive buffer when it is empty by reading from the DATA_CMD register. If the module is disabled (EN[0]=0), this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared. Value:
RX_FIFO_THD
Name: I2C Receive FIFO Threshold Register
Description: I2C Receive FIFO Threshold Register
Offset: 0x38
31:8 |
Reserved bits |
7:0 |
THD |
0x00 |
Receive FIFO Threshold Level Control the level of entries (or above) that triggers the RX_FULL interrupt (bit 2 in RAW_INT_STAT register). The valid range is 0–255, with the additional restriction that hardware does not allow this value to be set to a value larger than the depth of the buffer. If an attempt is made to do that, the actual value set will be the maximum depth of the buffer. A value of 0 sets the threshold for 1 entry, and a value of 255 sets the threshold for 256 entries. |
TX_FIFO_THD
Name: I2C Transmit FIFO Threshold Register
Description: I2C Transmit FIFO Threshold Register
Offset: 0x3C
31:8 |
Reserved bits |
7:0 |
THD |
0x00 |
Transmit FIFO Threshold Level Control the level of entries (or below) that trigger the TX_EMPTY interrupt (bit 4 in RAW_INT_STAT register). The valid range is 0–255, with the additional restriction that it may not be set to value larger than the depth of the buffer. If an attempt is made to do that, the actual value set will be the maximum depth of the buffer. A value of 0 sets the threshold for 0 entries, and a value of 255 sets the threshold for 255 entries. |
CLR_INT
Name: Clear Combined and Individual Interrupt Register
Description: Clear Combined and Individual Interrupt Register
Offset: 0x40
31:1 |
Reserved bits |
0 |
CLR_INT |
Read this register to clear the combined interrupt, all individual interrupts, and the TX_ABORT_SRC register. This bit does not clear hardware clearable interrupts but software clearable interrupts. |
CLR_RX_UNDER
Name: Clear RX_UNDER Interrupt Register
Description: Clear RX_UNDER Interrupt Register
Offset: 0x44
31:1 |
Reserved bits |
0 |
CLR_RX_UNDER |
Read this register to clear the RX_UNDER interrupt (bit 0) of the RAW_INT_STAT register. |
CLR_RX_OVER
Name: Clear RX_OVER Interrupt Register
Description: Clear RX_OVER Interrupt Register
Offset: 0x48
31:1 |
Reserved bits |
0 |
CLR_RX_OVER |
Read this register to clear the RX_OVER interrupt (bit 1) of the RAW_INT_STAT register. |
CLR_TX_OVER
Name: Clear TX_OVER Interrupt Register
Description: Clear TX_OVER Interrupt Register
Offset: 0x4C
31:1 |
Reserved bits |
0 |
CLR_TX_OVER |
Read this register to clear the TX_OVER interrupt (bit 3) of the RAW_INT_STAT register. |
CLR_RD_REQ
Name: Clear RD_REQ Interrupt Register
Description: Clear RD_REQ Interrupt Register
Offset: 0x50
31:1 |
Reserved bits |
0 |
CLR_RD_REQ |
Read this register to clear the RD_REQ interrupt (bit 5) of the RAW_INT_STAT register. |
CLR_TX_ABORT
Name: Clear TX_ABORT Interrupt Register
Description: Clear TX_ABORT Interrupt Register
Offset: 0x54
31:1 |
Reserved bits |
0 |
CLR_TX_ABORT |
Read this register to clear the TX_ABORT interrupt (bit 6) of the RAW_INT_STAT register, and the TX_ABORT_SRC register. |
CLR_RX_DONE
Name: Clear RX_DONE Interrupt Register
Description: Clear RX_DONE Interrupt Register
Offset: 0x58
31:1 |
Reserved bits |
0 |
CLR_RX_DONE |
Read this register to clear the RX_DONE interrupt (bit 7) of the RAW_INT_STAT register. |
CLR_ACTIVITY
Name: Clear ACTIVITY Interrupt Register
Description: Clear ACTIVITY Interrupt Register
Offset: 0x5C
31:1 |
Reserved bits |
0 |
CLR_ACTIVITY |
Reading this register clears the ACTIVITY interrupt if the I2C is not active anymore. If the I2C module is still active on the bus, the ACTIVITY interrupt bit continues to be set. It is automatically cleared by hardware if the module is disabled and if there is no further activity on the bus. The value read from this register to get status of the ACTIVITY interrupt (bit 8) of the RAW_INT_STAT register. |
CLR_STOP_DET
Name: Clear STOP_DET Interrupt Register
Description: Clear STOP_DET Interrupt Register
Offset: 0x60
31:1 |
Reserved bits |
0 |
CLR_STOP_DET |
Read this register to clear the STOP_DET interrupt (bit 9) of the RAW_INT_STAT register. |
CLR_START_DET
Name: Clear START_DET Interrupt Register
Description: Clear START_DET Interrupt Register
Offset: 0x64
31:1 |
Reserved bits |
0 |
CLR_START_DET |
Read this register to clear the START_DET interrupt (bit 10) of the RAW_INT_STAT register. |
CLR_GEN_CALL
Name: Clear GEN_CALL Interrupt Register
Description: Clear GEN_CALL Interrupt Register
Offset: 0x68
31:1 |
Reserved bits |
0 |
CLR_GEN_CALL |
Read this register to clear the GEN_CALL interrupt (bit 11) of RAW_INT_STAT register. |
EN
Name: I2C ENABLE Register
Description: I2C enable register
Offset: 0x6C
31:4 |
Reserved bits |
3 |
SDA_STUCK_RECOVERY |
If SDA is stuck at low, which is indicated by the TX_ABORT interrupt (TX_ABORT_SRC[17]), this bit is used as a control knob to initiate the SDA Recovery Mechanism (that is, send at most 9 SCL clocks and STOP to release the SDA line) and then this bit gets auto clear. Value:
2 |
TX_CMD_BLOCK |
In Master mode: Value:
1 |
ABORT |
When set, the controller initiates the transfer abort. The software can abort the I2C transfer in master mode by setting this bit. The software can set this bit only when EN is already set; otherwise, the controller ignores any write to ABORT bit. The software cannot clear the ABORT bit once set. In response to an ABORT, the controller issues a STOP and flushes the TX FIFO after completing the current transfer, then sets the TX_ABORT interrupt after the abort operation. The ABORT bit is cleared automatically after the abort operation. Value:
0 |
ACTIVITY |
Control whether the I2C is enabled. Software can disable I2C while it is active. However, it is important that care should be taken to ensure that I2C is disabled properly. When I2C is disabled, the following occurs:
If the I2C module is transmitting, it stops as well as deletes the contents of the transmit buffer after the current transfer is completed. If the module is receiving, the I2C stops the current transfer at the end of the current byte and does not acknowledge the transfer. Value:
STAT
Name: I2C STATUS Register
Description: This is a read-only register used to indicate the current transfer status and FIFO status. The status register may be read at any time. None of the bits in this register requests an interrupt.
When the I2C is disabled by writing 0 in Bit 0 of the EN register:
Bits 1 and 2 are set to 1
Bits 3 and 6 are set to 0
When the master or slave state machine goes idle and EN[0]=0: Bits 5 and 6 are set to 0
Offset: 0x70
Reset Value: 0x00000006
31:12 |
Reserved bits |
11 |
SDA_STUCK_RCVR |
This bit indicates that SDA stuck at low is not recovered after the recovery mechanism. In Slave mode, this register bit is not applicable. Value:
10:7 |
Reserved bits |
6 |
S_ACTIVITY |
Slave Activity Status. When the Slave is not in the IDLE state, this bit is set. Value:
5 |
M_ACTIVITY |
Master Activity Status. When the Master is not in the IDLE state, this bit is set. Note: STAT[0], ACTIVITY bit, is the OR of S_ACTIVITY and M_ACTIVITY Y bits. Value:
4 |
RX_FIFO_CF |
Receive FIFO Completely Full. When the receive FIFO is completely full, this bit is set. When the receive FIFO contains one or more empty location, this bit is cleared. Value:
3 |
RX_FIFO_NE |
Receive FIFO Not Empty. This bit is set when the receive FIFO contains one or more entries; it is cleared when the receive FIFO is empty. Value:
2 |
TX_FIFO_CE |
0x1 |
Transmit FIFO Completely Empty. When the transmit FIFO is completely empty, this bit is set. When it contains one or more valid entries, this bit is cleared. This bit field does not request an interrupt. Value:
1 |
TX_FIFO_NF |
0x1 |
Transmit FIFO Not Full. Set when the transmit FIFO contains one or more empty locations, and is cleared when the FIFO is full. Value:
0 |
ACTIVITY |
I2C Activity Status Value:
TX_FIFO_LEVEL
Name: I2C Transmit FIFO Level Register
Description: This register contains the number of valid data entries in the transmit FIFO buffer. It is cleared whenever:
The I2C is disabled.
If TX_ABORT bit is set in the RAW_INT_STAT register, the slave bulk transmit mode is aborted.
The register increments whenever data is placed into the transmit FIFO and decrements when data is taken from the transmit FIFO.
Offset: 0x74
31:4 |
Reserved bits |
3:0 |
TLEVEL |
Transmit FIFO Level. It contains the number of valid data entries in the transmit FIFO. |
RX_FIFO_LEVEL
Name: I2C Receive FIFO Level Register
Description: This register contains the number of valid data entries in the receive FIFO buffer. It is cleared whenever:
There is a transmit abort caused by any of the events tracked in TX_ABORT_SRC.
The register increments whenever data is placed into the receive FIFO and decrements when data is taken from the receive FIFO.
Offset: 0x78
31:4 |
Reserved bits |
3:0 |
LEVEL |
Receive FIFO Level. It contains the number of valid data entries in the receive FIFO. |
SDA_HOLD
Name: I2C SDA Hold Time Length Register
Description: I2C SDA Hold Time Length Register
The bits [15:0] of this register are used to control the hold time of SDA during transmit in both slave and master mode (after SCL goes from HIGH to LOW).
The bits [23:16] of this register are used to extend the SDA transition (if any) whenever SCL is HIGH in the receiver in either master or slave mode.
Writes to this register succeed only when EN[0]=0.
The values in this register are in units of clock period. The value programmed in TX_HOLD must be greater than the minimum hold time in each mode one cycle in master mode, seven cycles in slave mode for the value to be implemented.
The programmed SDA hold time during transmit (TX_HOLD) cannot exceed at any time the duration of the low part of SCL. Therefore, the programmed value cannot be larger than N_SCL_LOW minus 2, where N_SCL_LOW is the duration of the low part of the SCL period measured in clock cycles.
Offset: 0x7C
Reset Value: 0x00000001
31:24 |
Reserved bits |
23:16 |
RX_HOLD |
Set the required SDA hold time in units of clock period, when I2C acts as a receiver. |
15:0 |
TX_HOLD |
0x1 |
Set the required SDA hold time in units of clock period, when I2C acts as a transmitter. |
TX_ABORT_SRC
Name: I2C Transmit Abort Source Register
Description: I2C Transmit Abort Source Register
This register has 32 bits that indicate the source of the TX_ABORT bit. Except for Bit 9, this register is cleared whenever the CLR_TX_ABORT register bit or the CLR_INT register is read. To clear Bit 9, the source of ABORT_SBYTE_NORSTRT must be fixed first; RESTART must be enabled (CTRL[5] = 1), the SPECIAL bit must be cleared (TARGET_ADDR[11]), or the TX_CTRL bit must be cleared (TARGET_ADDR[10]).
Once the source of the ABORT_SBYTE_NORSTRT is fixed, this bit can be cleared in the same manner as other bits in this register. If the source of the ABORT_SBYTE_NORSTRT is not fixed before attempting to clear this bit, Bit 9 clears for one cycle and is then re-asserted.
Offset: 0x80
| 31:23 | TX_FLUSH_CNT | R | 0x0 | This field indicates the number of TX FIFO Data Commands which are flushed due to TX_ABORT interrupt. It is cleared whenever I2C is disabled. Role of I2C: Master-Transmitter or Slave-Transmitter |
| 22:18 | RSVD | R | Reserved bits | |
| 17 | ABORT_SDA_STUCK | R | 0x0 | This is a master-mode-only bit. Master detects the SDA Stuck at low for the IC_SDA_STUCK_AT_LOW_TIMEOUT value of ic_clk cycles. Values:
| 16 | ABORT_USER_ABORT | R | 0x0 | This is a master-mode-only bit. Master has detected the transfer abort (EN[1]) event. Role of I2C: Master-Transmitter Value:
| 15 | ABORT_SLVRD_INTX | R | 0x0 | When the processor side responds to a slave mode request for data to be transmitted to a remote master and user writes a 1 in CMD (bit 8) of DATA_CMD register. Role of I2C: Slave-Transmitter Value:
| 14 | ABORT_S_ARBLOST | R | 0x0 | This field indicates that a Slave has lost the bus while transmitting data to a remote master. TX_ABORT_SRC[12] is set at the same time. Note: Even though the slave never 'owns' the bus, something could go wrong on the bus. This is a fail safe check. For instance, during a data transmission at the low-to-high transition of SCL, if what is on the data bus is not what is supposed to be transmitted, then I2C no longer owns the bus. Role of I2C: Slave-Transmitter Value:
| 13 | ABORT_SLVFLUSH_TXFIFO | R | 0x0 | This field specifies that the Slave has received a read command and some data exists in the TX FIFO, so the slave issues a TX_ABORT interrupt to flush old data in TX FIFO. Role of I2C: Slave-Transmitter Value:
| 12 | ABORT_LOST | R | 0x0 | This field specifies that the Master has lost arbitration, or if TX_ABORT_SRC[14] is also set, then the slave transmitter has lost arbitration. Role of I2C: Master-Transmitter or Slave-Transmitter Value:
| 11 | ABORT_MASTER_DIS | R | 0x0 | This field indicates that the User tries to initiate a Master operation with the Master mode disabled. Role of I2C: Master-Transmitter or Master-Receiver Value:
| 10 | ABORT_10B_RD_NORSTR | R | 0x0 | This field indicates that the restart is disabled (RESTART_EN bit (CTRL[5]) =0) and the master sends a read command in 10-bit addressing mode. Role of I2C: Master-Receiver Value:
| 9 | ABORT_SBYTE_NORSTRT | R | 0x0 | To clear Bit 9, the source of the ABORT_SBYTE_NORSTRT must be fixed first; RESTART must be enabled (RESTART_EN bit CTRL[5]=1), the SPECIAL bit must be cleared (TARGET_ADDR[11]), or the TX_CTRL bit must be cleared (TARGET_ADDR[10]). Once the source of the ABORT_SBYTE_NORSTRT is fixed, then this bit can be cleared in the same manner as other bits in this register. If the source of the ABORT_SBYTE_NORSTRT is not fixed before attempting to clear this bit, bit 9 clears for one cycle and then gets reasserted. When this field is set to 1, RESTART is disabled (RESTART_EN bit (CTRL[5]) =0) and the user is trying to send a START BYTE. Role of I2C: Master Value:
| 7 | ABORT_SBYTE_ACKDET | R | 0x0 | This field indicates that the Master has sent a START Byte and the START Byte was acknowledged (wrong behavior). Role of I2C: Master Value:
| 6 | RSVD | R | Reserved bits | |
| 5 | ABORT_GCALL_RD | R | 0x0 | This field indicates that I2C in the master mode has sent a General Call but the user programs the byte that follows the General Call to be a read from the bus (DATA_CMD[9] is set to 1). Role of I2C: Master-Transmitter Value:
| 4 | ABORT_GCALL_NOACK | R | 0x0 | This field indicates that I2C in master mode has sent a General Call and no slave on the bus acknowledged the General Call. Role of I2C: Master-Transmitter Value:
| 3 | ABORT_TX_NOACK | R | 0x0 | This field indicates the master-mode only bit. When the master receives an acknowledgement for the address, but when it sends data byte(s) following the address, it did not receive an acknowledge from the remote slave(s). Role of I2C: Master-Transmitter Value:
| 2 | ABORT_10B2_NOACK | R | 0x0 | This field indicates that the Master is in 10-bit address mode and that the second address byte of the 10-bit address was not acknowledged by any slave. Role of I2C: Master-Transmitter or Master-Receiver Value:
| 1 | ABORT_10B1_NOACK | R | 0x0 | This field indicates that the Master is in 10-bit address mode and the first 10-bit address byte was not acknowledged by any slave. Role of I2C: Master-Transmitter or Master-Receiver Value:
| 0 | ABORT_7B_NOACK | R | 0x0 | This field indicates that the Master is in 7-bit address mode and the address sent was not acknowledged by any slave. Role of I2C: Master-Transmitter or Master-Receiver Value:
DMA_CTRL
Name: DMA Control Register
Description: This register is only valid when I2C is configured with a set of DMA Controller interface signals. When I2C is not configured for DMA operation, this register does not exist and writing to the register address has no effect and reading from this register address will return zero. The register is used to enable the DMA Controller interface operation. There is a separate bit for transmitting and receiving. This can be programmed regardless of the state of EN.
Offset: 0x88
31:2 |
Reserved bits |
1 |
TX_EN |
Transmit DMA Enable. This bit enables/disables the transmit FIFO DMA channel. Value:
0 |
RX_EN |
Receive DMA Enable. This bit enables/disables the receive FIFO DMA channel. Value:
DMA_TX_LEVEL
Name: DMA Transmit Data Level Register
Description: This register is only valid when the I2C is configured with a set of DMA interface signals. When I2C is not configured for DMA operation, this register does not exist; writing to its address has no effect; reading from its address returns zero.
Offset: 0x8C
31:3 |
Reserved bits |
2:0 |
LEVEL |
Transmit Data Level. This bit field controls the level at which a DMA request is made by the transmit logic. |
DMA_RX_LEVEL
Name: DMA Receive Data Level Register
Description: This register is only valid when I2C is configured with a set of DMA interface signals. When I2C is not configured for DMA operation, this register does not exist; writing to its address has no effect; reading from its address returns zero.
Offset: 0x90
31:3 |
Reserved bits |
2:0 |
LEVEL |
Receive Data Level. This bit field controls the level at which a DMA request is made by the receive logic. |
SDA_SETUP
Name: I2C SDA Setup Register
Description: This register controls the amount of time delay (in terms of number of clock periods) introduced in the rising edge of SCL – relative to SDA changing – when I2C services a read request in a slave-transmitter operation. The relevant I2C requirement is tSU_STO as detailed in Figure 71. This register must be programmed with a value that is equal to or greater than 2.
Writes to this register succeed only when EN[0] = 0.
Note:The length of setup time is calculated using [(SDA_SETUP – 1)*(clk_period)], so if users require 10 clock periods of setup time, they should program a value of 11. The SDA_SETUP register is only used by the I2C when operating as a slave transmitter.
Offset: 0x94
Reset Value: 0x00000064
31:8 |
Reserved bits |
7:0 |
SETUP |
0x64 |
SDA Setup. It is recommended that if the required delay is 1000 ns, then for a clock frequency of 10 MHz, SETUP should be programmed to a value of 11. SETUP must be programmed with a minimum value of 2. |
ACK_GEN_CALL
Name: I2C ACK General Call Register
Description: The register controls whether I2C responds with an ACK or NACK when it receives an I2C General Call address. This register is applicable only when the I2C is in slave mode.
Offset: 0x98
31:1 |
Reserved bits |
0 |
ACK_GEN_CALL |
0x1 |
ACK General Call. When this bit is set to 1, I2C responds with an ACK (by asserting data_oe) when it receives a General Call. Otherwise, I2C responds with a NACK (by negating data_oe). Value:
EN_STAT
Name: I2C Enable Status Register
Description: The register is used to report the I2C hardware status when the EN[0] register bit is set from 1 to 0 (when I2C is disabled).
If EN[0] has been set to 1, Bits [2:1] of the EN_STAT register are forced to 0, and Bit 0 is forced to 1.
If EN[0] has been set to 0, Bits [2:1] of the EN_STAT register are only valid as soon as Bit 0 is read as '0'.
Note:When EN[0] has been set to 0, a delay occurs for Bit 0 to be read as 0 because disabling the I2C depends on I2C bus activities.
Offset: 0x9C
31:3 |
Reserved bits |
2 |
S_RX_DATA_LOST |
Slave Received Data Lost. This bit indicates if a Slave-Receiver operation has been aborted with at least one data byte received from an I2C transfer due to the setting bit 0 of EN from 1 to 0. When this bit is read as 1, I2C is deemed to have been actively engaged in an aborted I2C transfer (with matching address) and the data phase of the I2C transfer has been entered, even though a data byte has been responded with a NACK. Note: If the remote I2C master terminates the transfer with a STOP condition before the I2C has a chance to NACK transfer, and EN[0] has been set to 0, then this bit is also set to 1. When this bit is read as 0, I2C is deemed to have been disabled without being actively involved in the data phase of a Slave-Receiver transfer. The CPU can safely read this bit when EN (bit 0) is read as 0. Value:
1 |
S_DIS_BUSY |
Slave Disabled While Busy (Transmit, Receive). This bit indicates if a potential or active Slave operation has been aborted due to the setting bit 0 of the ENABLE register from 1 to 0. This bit is set when the CPU writes a 0 to the ENABLE register while: I2C is receiving the address byte of the Slave-Transmitter operation from a remote master. Address and data bytes of the Slave-Receiver operation from a remote master. When this bit is read as 1, I2C is deemed to have forced a NACK during any part of an I2C transfer, irrespective of whether the I2C address matches the slave address set in I2C (S_ADDR register) or if the transfer is completed before EN is set to 0 but has not taken effect. Note: If the remote I2C master terminates the transfer with a STOP condition before the I2C has a chance to NACK a transfer, and EN[0] has been set to 0, then this bit will also be set to 1. When this bit is read as 0, I2C is deemed to have been disabled when there is master activity, or when the I2C bus is idle. The CPU can safely read this bit when EN (bit 0) is read as 0. Value:
0 |
EN |
EN Status. This bit always reflects the value driven on the output port EN. When read as 1, I2C is deemed to be in an enabled state. When read as 0, I2C is deemed completely inactive. Note: The CPU can safely read this bit anytime. When this bit is read as 0, the CPU can safely read S_RX_DATA_LOST (bit 2) and S_DIS_BUSY (bit 1). Value:
FS_SPKLEN
Name: I2C SS, FS or FM+ Spike Suppression Limit
Description: This register is used to store the duration, measured in clock cycles, of the longest spike that is filtered out by the spike suppression logic when the component is operating in Standard Mode (SS), Fast Mode (FS), or Fast Plus (FM+) Mode. The relevant I2C requirement is tSP as detailed in the I2C Bus Specification. This register must be programmed with a minimum value of 1.
Offset: 0xA0
Reset Value: 0x00000005
31:8 |
Reserved bits |
7:0 |
FS_SPKLEN |
0x5 |
This register must be set before any I2C bus transaction can take place to ensure stable operation. This register sets the duration, measured in clock cycles, of the longest spike in the SCL or SDA lines that will be filtered out by the spike suppression logic. This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 1; hardware prevents values less than 1 being written, and any attempt to write a value less than 1 results in 1 being set. |
SCL_STUCK_AT_LOW_TIMEOUT
Name: I2C SCL Stuck at Low Timeout Register
Description: This register is used to store the duration, measured in ic_clk cycles, used to generate an interrupt (SCL_STUCK_AT_LOW) if SCL is held low for the IC_SCL_STUCK_LOW_TIMEOUT duration
Offset: 0xAC
Reset Value: 0xFFFFFFFF
31:0 |
IC_SCL_STUCK_LOW_TIMEOUT |
0xFFFFFFFF |
I2C generates the interrupt to indicate SCL stuck at low (SCL_STUCK_AT_LOW) if it detects that the SCL is stuck at low for the IC_SCL_STUCK_LOW_TIMEOUT in units of ic_clk period. This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. |
Name: I2C SDA Stuck at Low Timeout Register
Description: This register is used to store the duration, measured in ic_clk cycles, used to recover the data (SDA) line through sending SCL pulses if SDA is held low for the IC_SDA_STUCK_LOW_TIMEOUT duration
Offset: 0xB0
31:0 |
IC_SDA_STUCK_LOW_TIMEOUT |
0xFFFFFFFF |
I2C initiates the recovery of SDA line through enabling the SDA_STUCK_RECOVERY_ENABLE (EN[3]) register bit, if it detects that the SDA is stuck at low for the IC_SDA_STUCK_LOW_TIMEOUT in units of ic_clk period. |
CLR_SCL_STUCK_DET
Name: Clear SCL Stuck at Low Detect Interrupt Register
Description: Clear SCL Stuck at Low Detect Interrupt Register
Offset: 0xB4
31:1 |
Reserved bits |
0 |
CLR_SCL_STUCK_DET |
Read this register to clear the SCL_STUCK_AT_LOW interrupt (Bit 14) of the IC_RAW_INTR_STAT register. |
| Symbol | Parameter | Standard Mode (SS) | Fast Mode (FS) | Fast-plus Mode (FM+) | Unit | |||
| Min. | Max. | Min. | Max. | Min. | Max. | |||
| fSCL | SCL clock frequency | 0 | 100 | 0 | 400 | 0 | 1000 | kHz |
| tLOW | SCL clock LOW time | 4.7 | 1.3 | 0.5 | μs | |||
| tHIGH | SCL clock HIGH time | 4.0 | 0.6 | 0.26 | μs | |||
| tRSDA | SDA rise time | 1000 | 20 | 300 | 120 | ns | ||
| tFSDA | SDA fall time | 300 | 300 | 120 | ns | |||
| tRSCL | SCL rise time | 1000 | 20 | 300 | 120 | ns | ||
| tFSCL | SCL fall time | 300 | 300 | 120 | ns | |||
| tHD_STA | START hold time | 4.0 | 0.6 | 0.26 | μs | |||
| tSU_DAT | SDA setup time | 250 | 100 | 50 | ns | |||
| tHD_DAT | SDA hold time | 0 | μs | |||||
| tSU_STO | STOP setup time | 4.0 | 0.6 | 0.26 | μs | |||
| tBUF | BUS FREE time from STOP to START | 4.7 | 1.3 | 0.5 | μs | |||
The bus load capacitance Cb = 100 pF.
