文档中心 > GR5405 Datasheet/ System/ PMU/ Power Consumption Copy URL
Power Consumption
The software constantly adjusts the power supplies of the power management modules (such as DC-DC/LDO) according to different temperatures and system clock sources, so estimating the current consumption of an application can be challenging when the measurements cannot be performed directly on different test conditions. To facilitate the estimation, a set of current consumption scenarios are provided to show the typical current drawn from the VBATL supply.
Each scenario specifies a set of operations and conditions to apply to the given scenario. All scenarios are listed in "Electrical Specifications". The table below shows a set of common conditions used in all scenarios, unless otherwise stated in the description of a given scenario.
Table 32 Common conditions
Condition State Remark
Supply VBAT = 3.3 V
Temperature 25°C
CPU WFI/WFE
Peripheral All idle
Clock System clock = 64 MHz@HFRC, low clock = 32.768 kHz@LFXO_32K
Flash clock 64 MHz
Core RAM Full 96 KB retention In active mode, full 96 KB RAM is powered; in sleep mode, full 96 KB RAM is retained.
Cache enabled Yes, 4-way associative Only applied when the CPU is running from Flash memory.
Bluetooth LE Stack Disabled
32 MHz crystal 32 MHz Only applied when the high-frequency crystal oscillator (HFXO_32M) is running, and HFXO_32M is used when the radio is running.
32 KHz crystal 32.768 KHz Only applied when the low-frequency crystal oscillator (LFXO_32K) is running.
BOD/IO_LDO BOD Enabled/IO_LDO On
VDDIO 3.3 V
DC-DC/CORE_LDO DC-DC = 1.15 V / CORE_LDO = 1.05 V
Regulator DC-DC
Flash Standby mode In active mode, Flash is powered on; in sleep mode, Flash is powered off.
Inductors
Compiler version MDK-ARM Plus Version: 5.38.0.0
Compiler flag -xc -std=c99 --target=arm-arm-none-eabi -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard –c -fno-rtti -flto -funsigned-char -fshort-enums -fshort-wchar -D__MICROLIB -mlittle-endian -gdwarf-4 -O3 -ffunction-sections - D__UVISION_VERSION="538"
The current consumption values listed in the following tables are measured on the GR5405 Starter Kit board and under the conditions specified in Table 32, unless otherwise stated.
Sleep Current Consumption
Table 33 Current consumption in sleep modes
Symbol Condition1 Condition2 Condition3 Min. Typ. Max. Unit
IUDS,RAM_OFF, RESET Ultra deep sleep mode No RAM retention Woken up on reset 2.7 μA
IUDS,RAM_OFF, AON_GPIO Woken up on AON GPIO 2.7 μA
IUDS,RAM_OFF,SLP_TIMER Woken up on Sleep Timer 2.7 μA
IUDS,RAM_OFF,SLP_TIMER_LFRC Woken up on Sleep Timer (running from LFRC_32K clock) 2.6 μA
IS,RAM48K_RET,BLE Sleep mode Full 48 KB RAM retention Woken up on Bluetooth LE controller 3.3 μA
IS,RAM96K_RET,BLE Full 96 KB RAM retention Woken up on Bluetooth LE controller 3.6 μA
IS,RAM96K_RET,BLE_LFRC Woken up on Bluetooth LE controller (running from LFRC_32K clock) 3.5 μA
IS,RAM96K_RET,SLP_TIMER Woken up on sleep timer 3.6 μA
IS,RAM96K_RET,COMP Woken up on LPCOMP 3.9 μA
IS,RAM96K_RET,SLP_TIMER_LFRC Woken up on sleep timer (running from LFRC_32K clock) 3.5 μA
IS,RAM96K_RET,RTC Woken up on RTC 3.5 μA
MCU Current Consumption
Table 34 MCU current consumption at 3.3 V
ICOREMARK CPU running CoreMark from Flash 2.5 mA
ICOREMARK,SYS_LDO Regulator = SYS_LDO 5.1 mA
ICOREMARK,64M_HFXO System clock = 64 MHz from HFXO clock 3.1 mA
ICOREMARK,16M_HFRC System clock = 16 MHz from HFRC clock 1.1 mA
ILOOP CPU running while loop from Flash 1.8 mA
ILOOP,SYS_LDO Regulator = SYS_LDO 3.5 mA
ILOOP,64M_HFXO System clock = 64 MHz from HFXO clock 2.3 mA
IIDLE CPU idle 1.1 mA
IIDLE,SYS_LDO Regulator = SYS_LDO 2.0 mA
IIDLE,64M_HFXO System clock = 64 MHz from HFXO clock 1.5 mA
Radio Current Consumption
GR5405 provides two options of power amplifiers for optimal power performance:
  • Small power amplifier (SPA, -20 dBm to 5 dBm)
  • High power amplifier (HPA, -10 dBm to 15 dBm)
Please refer to the Bill of Materials for tailored recommendations, including tolerance, component package, recommended manufacturer, and recommended part number.
Radio Transmitting Current Consumption
Table 35 Radio transmitting current consumption at 3.3 V
Symbol Condition 1 Condition 2 Condition 3 Min. Typ. Max. Unit
ITRANSMIT,0dBm,SPA,1Mbps,HFXO16M
1 Mbps Bluetooth LE, SPA,
System clock = 16 MHz from HFXO clock
Radio transmitting @0 dBm output power 6.4 mA
ITRANSMIT,0dBm,SPA,1Mbps,HFXO64M
6.7 mA
ITRANSMIT,0dBm,SPA,1Mbps,HFXO64M,SYS_LDO Regulator = SYS_LDO 16.1 mA
ITRANSMIT,-20dBm,SPA,1Mbps,HFXO64M Radio transmitting @-20 dBm output power 3.8 mA
ITRANSMIT,0dBm,HPA,1Mbps,HFXO64M,SYS_LDO
1Mbps Bluetooth LE, HPA,
Regulator = SYS_LDO Radio transmitting @0 dBm output power 24.7 mA
ITRANSMIT,6dBm,HPA,1Mbps,HFXO64M,SYS_LDO Radio transmitting @6 dBm output power 37.6 mA
ITRANSMIT,10dBm,HPA,1Mbps,HFXO64M,SYS_LDO Radio transmitting @10 dBm output power 54.3 mA
ITRANSMIT,15dBm,HPA,1Mbps,HFXO64M,SYS_LDO Radio transmitting @15 dBm output power 87 mA
ITRANSMIT,-10dBm,HPA,1Mbps,HFXO64M,SYS_LDO Radio transmitting @-10 dBm output power 17.3 mA
Radio Receiving Current Consumption
Table 36 Radio receiving current consumption at 3.3 V
IRECEIVE,1Mbps,64M_HFXO Radio receiving @ 1 Mbps Bluetooth LE mode System Clock = 64 MHz from HFXO clock 5.7 mA
IRECEIVE,1Mbps,16M_HFXO System Clock = 16 MHz from HFXO clock 5.2 mA
IRECEIVE,1Mbps,SYS_LDO, 64M_HFXO Regulator = SYS_LDO System Clock = 64 MHz from HFXO clock 13.7 mA
IRECEIVE,1Mbps,SYS_LDO,16M_HFXO System Clock = 16 MHz from HFXO clock 12.7 mA
ADC Current Consumption
Table 37 ADC current consumption
Symbol Condition 1 Condition 2 Min. Typ. Max. Unit
IADC,16MHz,128_POINTS CPU running, acquiring 128 points ADC sampling@16 MHz sample clock 120 uA
COMP Current Consumption
Table 38 COMP current consumption
Symbol Condition Min. Typ. Max. Unit
ICOMP COMP started 0.2 μA
BOD Current Consumption
Table 39 BOD current consumption
IBOD,Reset BOD running 200 nA
IBOD,Interrupt BOD interrupt enabled 50 nA
Typical Current Curves
Typical current curves indicate typical current under the conditions as stated below.
Sleep Mode
Typical conditions: VBAT = 3.3 V, system clock = 32.768 kHz@LFXO, Flash power-off.
The figure below shows the typical current curves of the device in sleep mode with full SRAM retention.
Figure 27 Typical current curves of the device in sleep mode
Active Mode
Typical conditions: VBAT = 3.3 V, system clock = 64 MHz@HFXO, regulator = DC-DC.
The figure below shows the typical current curves of the device in active mode (Coremark vs. While(1)) with various temperatures.
Figure 28 Typical current curves of the device in active mode
Radio Transmission
Radio Transmitting @ 15dBm Output Power
Typical conditions: System clock = 64 MHz @HFXO, regulator = SYS_LDO, RF power amplifier = HPA.
The figure below shows the typical current curves of the device at 15 dBm TX output power, considering various supply voltages and temperatures.
Figure 29 Typical current curves of the device at 15 dBm TX output power
