GR551x Overview
GR551x SoCs are available in multiple packages (see 表 1) that meet your diverse project demands.
| GR551x Series | GR5515IGND | GR5515IENDU | GR5515I0ND | GR5515I0NDA | GR5515RGBD | GR5515GGBD | GR5513BEND |
| RAM | 256 KB | 256 KB | 256 KB | 256 KB | 256 KB | 256 KB | 128 KB |
| Flash | 1 MB | 512 KB | N/A | N/A | 1 MB | 1 MB | 512 KB |
| Package (mm) |
QFN56 (7 x 7 x 0.75) |
BGA68 (5.3 x 5.3 x 0.88) |
BGA55 (3.5 x 3.5 x 0.60) |
QFN40 (5 x 5 x 0.75) |
| I/O Number | 39 | 39 | 39 | 39 | 39 | 29 | 22 |
- GR5515RGBD is not recommended for new designs.
- GR5515IENDU is embedded with wide-voltage Flash, with Flash power supply from 1.65 V to 3.6 V.
- GR5515I0ND supports external high-voltage Flash (typical: 3.3 V); GR5515I0NDA supports external wide-voltage Flash (range: 1.65 V–3.6V).
