Features
- A Bluetooth Low Energy
(Bluetooth LE) 5.1 transceiver integrates Controller and Host layers
- Supported data rates: 1 Mbps, 2 Mbps, Long Range 500 kbps, Long Range 125 kbps
- TX power: -20 dBm to +7 dBm
- -97 dBm sensitivity (in 1 Mbps mode)
- -93 dBm sensitivity (in 2 Mbps mode)
- -99.5 dBm sensitivity (in Long Range 500 kbps mode)
- -103 dBm sensitivity (in Long Range 125 kbps mode)
- TX current: 3.05 mA @ 0 dBm, 1 Mbps
- RX current: 3.9 mA @ 1 Mbps
- ARM®
Cortex®-M4F 32-bit micro-processor with floating point support
- Maximum frequency: 64 MHz
- Power consumption: 30 µA/MHz
- Memory
- 256 KB RAM with retention (four 8 KB RAM blocks and seven 32 KB RAM blocks) for GR5515 series SoCs, and 128 KB RAM with retention (four 8 KB RAM blocks and three 32 KB RAM blocks) for the GR5513 SoC
- 1 MB Flash for GR5515 series SoCs (except for GR5515I0ND and GR5515I0NDA which require external QSPI Flash with various model options, and GR5515IENDU with a 512 KB embedded Flash) and 512 KB Flash for the GR5513 SoC
- Power management
- On-chip DC-DC Converter
- Supply voltage: 1.7 V to 3.8 V. The supply voltage of GR5515I0ND/GR5515I0NDA (when the external Flash of GR5515I0NDA supplied by high voltage) shall equal the working voltage of external QSPI Flash.
- I/O voltage: 1.8 V to 3.3 V (Typical) (for GR5515I0ND, or GR5515I0NDA/GR5515IENDU using high voltage for the Flash, VDDIO0 shall be bonded to VIO_LDO_OUT internally and I/O LDO is set to off mode in the application firmware by default, so VIO_LDO_OUT shall be connected to VBATL.)
- OFF mode: 0.15 µA (Typical); nothing is on except VBAT, chip in reset mode
- Ultra deep sleep mode: 0.65 µA (Typical); I/O LDO off, no memory retention; woken up by AON GPIO or AON Timer
- Sleep mode: 1.3 µA (Typical) when I/O LDO and BOD/BOD2 turned off, lowest voltage level for memory retention, and 32 KB memory retention; woken up by AON_RTC, AON GPIO, or Bluetooth LE Event
- Peripherals
- 2 x QSPI interfaces, up to 32 MHz
- 2 x SPI interfaces (1 SPI Master Interface with 2 slave CS pins + 1 SPI Slave Interface), up to 32 MHz
- 2 x I2C interfaces at 100 kHz, 400 kHz, 1 MHz, 2 MHz
- 2 x I2S interfaces (1 I2S Master Interface + 1 I2S Slave Interface)
- 2 x UART interfaces, one with DMA channel.
- 13-bit ADC, up to 1 Msps, 8 channels (5 external test channels and 3 internal signal channels), supporting both single-ended and differential inputs
- ISO 7816 interface
- 6-channel PWM
- Built-in temperature and voltage sensors
- 4 x Hardware timers
- 1 x AON hardware timer
- 2 x Watchdog timers (1 System Watchdog Timer and 1 Always-on watchdog timer)
- Calendar timer
- Wake-up comparator
- Up to 39 multiplexed GPIO pins
- Security
- Complete secure computing engine:
- AES 128-bit/192-bit/256-bit symmetric encryption (ECB, CBC)
- Keyed Hash Message Authentication Code (HMAC)
- PKC
- TRNG
- Comprehensive security operation mechanism:
- Secure boot
- Encrypted firmware runs directly from Flash
- Packages
- QFN56: 7 mm x 7 mm
- BGA68: 5.3 mm x 5.3 mm
- BGA55: 3.5 mm x 3.5 mm
- QFN40: 5 mm x 5 mm
- Operating temperature range: -40°C to +85°C
