RTC_CTRL
- Base Address: 0xA000C500
- Offset: 0x18
- Reset Value: 0x00003100
31:14 |
Reserved bits |
13 |
WRAP_INT_EN |
0x1 |
Wrap-around interrupt enable. Value:
12 |
ALARM_INT_EN |
0x1 |
Timer alarm interrupt enable. Value:
11 |
Reserved bits |
10:8 |
CLK_SEL |
0x1 |
Timer clock select. Refer to 表 27. |
7:4 |
WRAP_CNT |
Wrap-around counter |
3 |
Reserved bits |
2 |
ALARM_VAL_LOAD |
W |
Alarm value load. Write 1 to load the value. |
1 |
VAL_LOAD |
W |
Up counter value load. Write 1 to load the value. |
0 |
EN |
Enable calendar timer. Value:
VAL_SET
- Offset: 0x90
| 31:0 | VAL_SET | RW | 0x0 | This register is shared with multiple timers. To apply the value, set the value then assert corresponding load registers. |
VAL_RD
- Offset: 0x94
| 31:0 | VAL_RD | R | 0x0 | This register is to read the current value and shared with multiple timers. |
